Kevin Bacon 5 Posted May 10, 2008 OK, done mine today and it was dead easy :) I think most people know how to remove rear brakes, but here's a few pics to give you an idea of what's involved and what they look like. The only things worthy of note are; you have to cut off the shield plate and you also need to reposition the handbrake cable retaining clip to give it enough slack to account for the caliper's new height. I would recommend getting a wind back tool aswell, makes life a lot easier 8) I tarted the brakes up a bit with some smoothrite too. They still look tiny in my wheels though.....but not as small as the original saucers :lol: On the road with new pads, I can already feel the rear brakes contributing more to the overall braking and it makes the car feel more stable when you jump on them. Should be even better when bedded in! Quote Share this post Link to post Share on other sites
dinkus 10 Posted May 10, 2008 Oooh me like... Quote Share this post Link to post Share on other sites
StormchargedVR6 0 Posted May 10, 2008 Nice work Kev, did you get new bearings in the kit. I need bigger fronts first :? Quote Share this post Link to post Share on other sites
alex303 0 Posted May 10, 2008 cheesewire did you find it necessary to adjust the brake bias regulator after fitting the kit? i'm just wondering if you still need to do this when running uprated front stoppers too. tks Alex. p.s. looks very smart! Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted May 11, 2008 Forgot to say..... these Irwin "easy outs" are a god send when removing the rear carriers!! Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted May 11, 2008 Yep, bearings included in the kit! The only things not included are pads and, err, instructions! I haven't adjusted my rear bias valve. I think it's seized anyway :lol: Quote Share this post Link to post Share on other sites
VRTrickster 0 Posted May 11, 2008 Very good cheese! Ill have to do a thread on my 280mm vented rear conversion with 4Motion calipers. Nice work :) Quote Share this post Link to post Share on other sites
Joe M 0 Posted May 12, 2008 Forgot to say..... these Irwin "easy outs" are a god send when removing the rear carriers!! They do look handy, I used a torx socket when I last took the carriers off. How much did the rear 280 kit cost then? Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted May 12, 2008 Joe, GWerks did a GB on them @ £205 all in. Just thought I'd start this thread rather than clog up the GB thread. VRTrickster, 280mm vented rears with bigger calipers! Do tell more! Mind you, the rear wheels are driven on a 4Motion and is a heavier car therefore need the extra braking power. Could be a tad overkill on a FWD, but who cares? :lol: Quote Share this post Link to post Share on other sites
VRTrickster 0 Posted May 12, 2008 Joe, GWerks did a GB on them @ £205 all in. Just thought I'd start this thread rather than clog up the GB thread. VRTrickster, 280mm vented rears with bigger calipers! Do tell more! Mind you, the rear wheels are driven on a 4Motion and is a heavier car therefore need the extra braking power. Could be a tad overkill on a FWD, but who cares? :lol: Yeah I know what you mean, they are a bit OTT, but at least they are there for when I do up the power :) I got the spacer brackets and special hubs of John at JMR Racing in Littlehampton. I brought the calipers by mistake off VR6OC, and didnt want to give up making them fit! I Heard that someone had carried out the conversion, which happened to be John. He can get made up brackets for 256 or 280 vented discs. Im not sure if the the hubs are actually rear discs machined into hubs on a lathe? The disc face ends up being exactly where it normally sits, which is good! Im going to probably do a thread when I put it all back together. Ive just taken the axle off, stripped off, and dropped it of to be zinc then power coat finished. Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted May 12, 2008 Yeah let us know more because the MK4 rear setup is miles better. Proper bearings and the discs pop onto hubs like they do on the fronts. Much nicer! Quote Share this post Link to post Share on other sites
KADVR6 0 Posted May 12, 2008 nice to see your still getting your hands dirty kev, surprised you had time to do this job instead of "detailing" :lol: karl Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted May 12, 2008 Nah that's the dirt off the Polo before I started work on the brakes mate :lol: Quote Share this post Link to post Share on other sites
VRTrickster 0 Posted May 14, 2008 Yeah let us know more because the MK4 rear setup is miles better. Proper bearings and the discs pop onto hubs like they do on the fronts. Much nicer! Yes the discs do pop on to the hub, but the hub still uses the taper style bearings. Thats why I thought they might be machined rado discs. Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted May 15, 2008 Do they? Bums. I thought they might be like Ford Focus rear hubs (also uses "MK4 calipers") which are a catridge bearing instead of taper jobbies. Well, my rear 280s are bedded in and with DS2500 pads front and rear..... stopping power is rather fruity :D The control from the back under hard braking is so much better now. Defo a worthwhile mod! Quote Share this post Link to post Share on other sites
NormanCoal 0 Posted May 15, 2008 I'm really suprised that you guys havent gone for the MK4 style rear brakes, the bearing setup is so much better, and all the parts are available from VW models Quote Share this post Link to post Share on other sites
dinkus 10 Posted May 15, 2008 I'm really suprised that you guys havent gone for the MK4 style rear brakes, the bearing setup is so much better, and all the parts are available from VW models It's definitely an interesting idea, especially if it's a bolt-off, bolt-on type swap. Is there much angle-grinder/machining involved? How much do the parts cost? What are the part numbers? I'd definitely be game, price-permitting... Quote Share this post Link to post Share on other sites
yeti 0 Posted May 15, 2008 i heard from speaking to a mechanic who converted the rear of his ibiza 1.8t to mk4/tt vented that fitting the callipers and discs involved a fair bit of machining... i thought ibiza's shared many parts with mk3 golfs so they woudl be a similar PITA to fit... hence the 280's! Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted May 15, 2008 Trickster said the MK4 rear hubs are still taper bearings? If they're cartridge bearings like the front then it's worthwhile, but if not, then it's not imo. Quote Share this post Link to post Share on other sites
Guest Posted May 15, 2008 Nice paint job on the disk centre but I'm sticking with silver for mine. And talk of the shield has reminded me I need to find my new ones and put thicker paint on before fitting.... Oh so much to do and so little time :grin: Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted May 15, 2008 Silver paint, or leaving it, err, silver? :lol: I was going to just leave it, but then I had visions of that big expanse of metal turning a nice rust colour, so painted it. I've been smelling hot Smoothrite the past few days, so I guess they're working! Quote Share this post Link to post Share on other sites
Guest Posted May 15, 2008 Silver paint, or leaving it, err, silver? :lol: I was going to just leave it, but then I had visions of that big expanse of metal turning a nice rust colour, so painted it. I've been smelling hot Smoothrite the past few days, so I guess they're working! Silver :) You will be concoursing next doing little tricks like that :wink: Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted May 15, 2008 Blimey, that'll mean getting the sponge out.... and cleaning underneath aswell..... :) Quote Share this post Link to post Share on other sites
VRTrickster 0 Posted May 15, 2008 Trickster said the MK4 rear hubs are still taper bearings? If they're cartridge bearings like the front then it's worthwhile, but if not, then it's not imo. Good to hear you liking the brakes cheese! No, Im not saying that Mk4 rear hubs have tapered bearings. I think the hubs I have are machined from rado discs, into hubs, see what I mean? I think its best I get some pictures up to show you, but I cant do that until I get back to the car next weekend, sorry :) Quote Share this post Link to post Share on other sites
