Sean_Jaymo 0 Posted June 23, 2013 There should be a thin clip that you need to slide out and then it should separate easily. Quote Share this post Link to post Share on other sites
STU175 0 Posted February 27, 2014 im at a motorfactors to pick up some brake unions and have told him i need 10mm brake unions. he has asked if they are 10x1 or 10x1.5 ? this is the pitch of the thread. any one give me an answer? all i can find online is they are 10mm? Quote Share this post Link to post Share on other sites
P3rks 11 Posted February 27, 2014 MK4 rear calipers have a thread pitch of either 10x1 or 10x1.5 I remember when doing research that there was no defined answer to which calipers used which thread. Luckily for me my hoses came with a set of each thread. For what they cost you're best of getting both sizes. Quote Share this post Link to post Share on other sites
Mk3highline 10 Posted April 21, 2015 Are The brake hoses the same length I'm getting some made with the mk4 ends for new calipers Quote Share this post Link to post Share on other sites
Mk3highline 10 Posted April 23, 2015 Ordered trw callipers And just for info the mk4 seems to use the same pads as the mk3 vr6 besides that the later ones(mk4) has a thicker pad by 1mm Anyone confirm this? Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted April 23, 2015 I'm wondering about pads too, when i originally did the mk4 upgrade i though it was all fine, but when removing the rear brakes recently it seemed like something was wrong. The pad wasn't making proper contact with the disc and ended up with the discs rusting up. Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted April 23, 2015 See the big channel worn out of top of pad, this was where the disc has rusted up Quote Share this post Link to post Share on other sites
Mk3highline 10 Posted April 23, 2015 Thank you I'm getting http://www.rsdlimited.com/About.html He used to work for vw Motorsport or something and will see what best option is Quote Share this post Link to post Share on other sites
Mk3highline 10 Posted April 29, 2015 Also found out today that some mk4 rear calipers have an m14 banjo bolt instead of the common m10 so the normal kits won't fit Quote Share this post Link to post Share on other sites
Geeba 0 Posted January 16, 2017 Has anyone tried fitting the MK4 golf vented discs? http://www.eurocarparts.com/ecp/c/Volkswagen_Golf_2.8_2002/p/car-parts/regular-service/car-service-parts/brake-discs/?104440869&1&ff9b04ecde992bc183f688acd6f8d3b249e499ca&000027 Quote Share this post Link to post Share on other sites
fla 9 Posted August 30, 2020 Just done one side. The banjo bolt on the caliper needs to be done up really tightly otherwise it leaks v slightly. Ive use crush washers each side but it just seems to need to be tightened excessively....any suggestions or is this normal? Quote Share this post Link to post Share on other sites
fla 9 Posted August 31, 2020 On 8/30/2020 at 6:19 PM, fla said: Just done one side. The banjo bolt on the caliper needs to be done up really tightly otherwise it leaks v slightly. Ive use crush washers each side but it just seems to need to be tightened excessively....any suggestions or is this normal? Turns out that this is actually because the banjo bolt bottoms out in the caliper. Just used another crush washer on top. I'll post some pics shortly When you get your calipers i would suggest a trial fit of the hose off the car to see if yours also have the same issue. Screw it in without the hose or washers and see how far down the bolt goes. Then try it with two washers and the hose and then add another if necessary Quote Share this post Link to post Share on other sites
1xshaunx1 27 Posted September 1, 2020 I purchased these, no problems at all. What did you get Fla Quote Share this post Link to post Share on other sites
Dox 31 Posted September 1, 2020 (edited) I think I'd be tempted to grind the bolt to reduce its length over extra washers providing there's still enough thread located inside the calliper? I sold Fla Golf estate rear callipers years and years ago, maybe these are the ones? Measure the pistons as estates are reputed to have larger pistons and are sought after - I didn't know this at the time. I'm sure I sent them with the OE bolts so maybe compare the lengths? Edited September 1, 2020 by Dox Quote Share this post Link to post Share on other sites
fla 9 Posted September 1, 2020 5 minutes ago, Dox said: I think I'd be tempted to grind the bolt to reduce its length over extra washers providing there's still enough thread located inside the calliper? I sold Fla Golf estate rear callipers years and years ago, maybe these are the ones? Measure the pistons as estates are reputed to have larger pistons and are sought after - I didn't know this at the time. I'm sure I sent them with the OE bolts so maybe compare the lengths? I think these got lost in my garage somewhere prior to our house extension work. Ended up buying another returned set off ebay Quote Share this post Link to post Share on other sites
fla 9 Posted September 1, 2020 4 hours ago, 1xshaunx1 said: I purchased these, no problems at all. What did you get Fla Yes, bought the same ones Quote Share this post Link to post Share on other sites
Dox 31 Posted September 1, 2020 1 minute ago, fla said: I think these got lost in my garage somewhere prior to our house extension work. Ended up buying another returned set off ebay That's a shame, I was hoping you would end the myth of estates having a larger piston in the UK - I've owned a couple and broke both without measuring them Quote Share this post Link to post Share on other sites
1xshaunx1 27 Posted September 1, 2020 3 hours ago, Dox said: That's a shame, I was hoping you would end the myth of estates having a larger piston in the UK - I've owned a couple and broke both without measuring them I’ve got 41mm pistons on mine. Off a Skoda vrs estate I think. Ordered TRW and brand new Lucas came. What make are yours Fla. TRW BHN203 is the right rear one with 41mm piston Quote Share this post Link to post Share on other sites
Dox 31 Posted September 1, 2020 I’ve got 41mm pistons on mine. Off a Skoda vrs estate I think. Ordered TRW and brand new Lucas came. What make are yours Fla. TRW BHN203 is the right rear one with 41mm pistonMK1 VRS estate had 256mm vented rear as did the hatch So not a bolt on fit like the solids as they need the cassette type rear bearings mod. Could be lesser model estate though?Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
1xshaunx1 27 Posted September 1, 2020 3 hours ago, Dox said: MK1 VRS estate had 256mm vented rear as did the hatch So not a bolt on fit like the solids as they need the cassette type rear bearings mod. Could be lesser model estate though? Sent from my iPhone using Tapatalk Apparently they are to fit a 98-01 octavia vrs 4x4 Quote Share this post Link to post Share on other sites
fla 9 Posted September 1, 2020 10 hours ago, Dox said: That's a shame, I was hoping you would end the myth of estates having a larger piston in the UK - I've owned a couple and broke both without measuring them Theres still some stuff needing sorting - I'll have a rummage and see if they're in the chaos somewhere.. Quote Share this post Link to post Share on other sites
Dox 31 Posted September 1, 2020 3 hours ago, 1xshaunx1 said: Apparently they are to fit a 98-01 octavia vrs 4x4 The UK got a VRS 2wd 180 bhp (AUQ engine K03S turbo), 1.8T 4 x 4 150bhp (AUM engine K03, then K03S turbo too, but de-tuned), 1.9 tdi 4 x 4 We never got a MK1 VRS 4 x 4 from the factory Quote Share this post Link to post Share on other sites
1xshaunx1 27 Posted September 5, 2020 On 9/1/2020 at 8:49 PM, Dox said: The UK got a VRS 2wd 180 bhp (AUQ engine K03S turbo), 1.8T 4 x 4 150bhp (AUM engine K03, then K03S turbo too, but de-tuned), 1.9 tdi 4 x 4 We never got a MK1 VRS 4 x 4 from the factory The ones I’ve fitted were TRW , BHN202 & BHN203. Both brand new OEM Lucas in a TRW box. If you ever bought a track rod end from the VW dealer they sold you a TRW one. Dox you appear to be right about the description I gave, but that’s what one of the sellers on eBay listed it as. I suppose I got lucky they fit and work, and they do work real good and the handbrake is now ace. I thought they might do though going by the handbrake bracket which is the early type. I’ve since gone on TRW’s website and they are to fit amongst other things a range of mark 4 golf estates, so you seem to be correct in thinking they had a larger piston in the estates as well, hats off sir. Quote Share this post Link to post Share on other sites
1xshaunx1 27 Posted September 5, 2020 10 minutes ago, 1xshaunx1 said: The ones I’ve fitted were TRW , BHN202 & BHN203. Both brand new OEM Lucas in a TRW box. If you ever bought a track rod end from the VW dealer they sold you a TRW one. Dox you appear to be right about the description I gave, but that’s what one of the sellers on eBay listed it as. I suppose I got lucky they fit and work, and they do work real good and the handbrake is now ace. I thought they might do though going by the handbrake bracket which is the early type. I’ve since gone on TRW’s website and they are to fit amongst other things a range of mark 4 golf estates, so you seem to be correct in thinking they had a larger piston in the estates as well, hats off sir. They were about £90 each delivered. Quote Share this post Link to post Share on other sites
culshaw 1 Posted September 11, 2020 I've just done this on my mk4, I needed both rear calipers and got them from eurocarparts. Replacements came as reconditioned VW ones. Pot luck got lucky I guess. Quote Share this post Link to post Share on other sites
