g0ldf1ng3r
g0ldf1ng3r's VR6
  On 8/28/2020 at 11:03 AM, g0ldf1ng3r said:
morning cressa
thanks m8 - can i disconnect the vac line with the white unit in situ?
Yes mate, give it a gentle wiggle whilst pulling 😂😂 I sprayed some WD40 in the pipe to help mine go back on
( all of that sounded wrong )
ha ha ha love it m8!! LOL
tidy thanks, will get some time on it over the weekend hopefully
appreciate your help
hi all
can anyone help with figuring out if a wheel would fit & if spacers would be needed pls
wheel spec is 16" , 6.5J, ET49
im on coilovers so can adjust height as needed, its just the offset im unsure of
  On 9/12/2020 at 10:23 AM, g0ldf1ng3r said:
hi all
will they fit seems to imply they will be ok, just sit inwards a touch - 6mm i think
From my understanding ...... A standard speedline is ET43, so Et49 is 6mm further from the centre of the wheel to its mounting plate . But is that positive offset or negative... I hate wheels..
The bigger the et the more it’s sits into the arch. The smaller the number the more the wheel pushes out of the arch.
That why wheels with big lips/dishes generally have a low offset and rub your arch’s
thanks shaun, 1st time someone has explained that so it makes sense lol
hmmm, now should i load the credit card up or not
hi all
If these are what you are going for I would allow for 5-6mm spacers and longer bolts.
as the wheels are the same size ( 6.5” wide) as standard speedlines but bigger et they will sit 6mm further in and may catch your coil overs, it will look funny even if they bolt on without catching anything on think.
My 17” BBS have spacers to punch them out a bit.
I was going to add rim width makes a difference too, a rim with the same offset  but 2 inches wider would poke out an inch further out and an inch closer to the strut, nothing is straight forward....
thanks, i thought that might be the case - i already run 10mm spacers on the front so as the speedlines clear my 4 pot brakes
the center bore is listed as 56mm but i think ours are 57.1 - im guessing a hub-centric spacer could give me the clearance whilst addressing the center bore difference too
out of interest how do you find running 17's?  i was under the impression 16's are better for ride quality
I doubt you’ll get 10mm to fit as the boss on the rear disk is 18 - 20mm or so. 56mm will bind before the wheel meets the spacer?
You could get a spacer bored to 56mm and 57.1  I’ll get a photo later of my spacers on the 17’s.
17’s offer a lot more grip but aren’t very speed bump friendly
I think it would be cheaper to get the wheels machined to 57.1.
My wheels came from rimstyle and they sorted the machine work and spacers. The wheels and spacers were machined so the centre bore spacer fits the Corrado disc boss as I think they had a bigger bore Than 57.1934DD4C9-6A9B-4833-87A5-1A9D51D1654E.thumb.jpeg.3117bcdce4016b4cb80078f41ff9ebff.jpeg8CF85CD4-7A5E-4247-835D-E70C440C4824.thumb.jpeg.45ff850fa9bcd8b5c4a43836efbf3e8a.jpegBF6C3418-FE1D-4911-ABC8-289F151D5DBB.thumb.jpeg.c1b32133a17187cf96ee4997e319fb20.jpeg95B0B197-7218-4A45-A9AA-E5E9C29D8FAF.thumb.jpeg.bd48f682c4cc5af573bbb38a27ccb96f.jpeg39A1E24C-174D-4EDD-AB34-7EAEF1B15084.thumb.jpeg.6247fce310f56662b974b75d19977105.jpeg
just seen these wheel replies thanks guys
the ones i was looking at something doesnt feel right so ive sacked it off for now
small update
the fog lenses that were given to me from the chap i brought the VR6 off all those years ago gave me a box with new fog lenses in there - sadly, when the paint shop came to fit them they are not right as they are not tapered
so, cracked fogs are detracting from my lovely fresh paint 😞
but i saw these on FB this morning & the poster gave me the link for them - i thought id share with here as ive just ordered some Hella covers 😄
https://www.etsy.com/uk/listing/807159510/vw-corrado-vr6-g60-16v-8v-hella-fog-lamp?ga_order=most_relevant&ga_search_type=all&ga_view_type=gallery&ga_search_query=vw+corrado+vr6+hella&ref=sr_gallery-1-1&organic_search_click=1
Was there not a guy from Germany selling copies of the lenses? Used to post on forum before it went paid - they’ll show up on eBay.de
Think the username was sprinter?
  On 10/2/2020 at 3:56 PM, Cressa said:
I got these clear ones earlier this year. Happy with them. 😊
as in the lenses themselves cressa?
where from pls?
Just lens covers mate, to protect them. I can have a look to see where from if you want
ahh ok, thanks m8
appreciate the offer but no need as ive ordered some of the black with white lettering ones from the guy on etsy
had a look at ebay.de for corrado parts & jesus momma the sellers must be smoking crack or something with the prices they are asking - talk about taking the piss with enormous price tags eg 479 euro for both fogs in housing = absolute joke!!
  On 10/3/2020 at 9:38 AM, g0ldf1ng3r said:
ahh ok, thanks m8
Agreed. ^this.
But I think you can get the glass on its own, and the complete unit wasn’t cheap when it was available from VAG.
The late fogs are an absolute pain, as they will all crack, and there’s no perfect solution. Replacing the lenses involves a lot of labour as you need to break the glass, clean and seal etc. Also watch out as a lot of the replacements will only work with LEDs, not halogen bulbs, due to the heat.
Classics should really get these remade.
  On 10/3/2020 at 9:48 AM, fendervg said:
Agreed. ^this.
i was looking for lenses only, they show some but 239 euro is unacceptable https://www.ebay.de/itm/VW-Corrado-Nebelscheinwerfer-Blinker-US-beige-fog-light-535947699B-535941700B/163475078383?hash=item260fdfbcef:g:O1AAAOSw0eNdSEp5
if i put new lenses in i would never use the fogs themselves so as to avoid heat cracking but for now i will just cover them over
hmmmm i wonder if i could gently grind a chamfer onto the hella lenses that the guy gave me when i brought the VR6 - gotta be worth a go as they are just going to sit there otherwise
does anyone know, or can find out, if ETKA or similar show the fog lense dimensions?
quick update - will get some pics soon
but my god why had i not fitted lupo wipers before now - what a difference!
also had to install some blade located washer jets as didnt want to cut the carbon fiber bonnet & they wash great as they move with the wipers & cover the entire screen
highly recommended!!
where from pls?
i really must get a pic of the VR6 front end with the Hella covers on, they make it look great
Sounds great, I’ve had lupo wipers for years but I like the sound of the washers on the blades, my Citreon(Learner Car) has them and I like it a lot, definitely interested to see what you’ve done 😁👍
