daves16v
Black Metallic VR - SOLD!
Pete, cheers mate, ordered it.
James, yeah glad it's done, can relax now.
I've borrowed another sensor off LaserMark but after checking all three for resistance I doubt the sensors are duff, they all read the same. Going to strip the covers off again to get at the trigger. Don't you just love cars!
Dave, well done on getting that all done! It's a big job!
I have a very similar cam problem. It's not the sensor/ecu/wiring/timing, so reckon it must be the trigger wheel. Quite frustrating really, as I asked a local specialist to change it for me. They took it all apart and checked the timing, but said the trigger wheel 'looked OK' so they left it, even though I asked them to change it as it's a cheap part. Is it fairly straightforward to take the rocker etc off? Never messed with the engine internals before, so I'm slightly nervous about tackling it myself. Really don't want to pay for all the labour again!
Andy, it's easy enough removing inlet mani, cam cover and the end cover, the problem comes undoing the sprocket bolt. It wouldn't budge on mine, hence having to use the one off my breaker. If it had come off then I doubt I'd have this problem.
Oh and you need to use joint sealant when refitting the end cover, not sure if the VW stuff is a must or some other brand will do?
Even if you were able to crack off the bolt, I'd be surprised if the pickup hasn't of broke upon removal anyway
Changed the 'phase sender' (the bit the cam sendor reads) last night, started it up and no error so it's all good, just need to take it for a blast later today.
Good stuff!
I've had to take a rear cam down to a tyre place before to get the bolt air gunned off! The bolt shoulder grips onto the cam trigger's washer.
  CazzaVR said:
Sounds good Dave! Do you have a part number and price? :-)
021905163
£10.73+vat
Took it out last night for a good run, seems to go well. Has it made a difference? Yeah I think so but as it was off the road for 4 months then the first proper drive was after the the cams were fitted I'd kind of forgot how it drove before the cams. Think I'll get it remapped now to release the cams potential.
The engine does sound very quiet now.
Just need to sort out a front ABS sensor and 4 wheel alignment then that'll be it for a while, I'll just enjoy it.
Edited by daves16v
glad you got it sorted. I'll keep an eye on this now as its something i'm contemplating doing next winter, It will be interesting to see if it makes a difference as I'm hear different things at the moment.
Oh yes it's sorted 100%, it was way down on power before, the error code has disappeared too.
  CazzaVR said:
Sounds like it's sorted Dave. Ordered one this morning- on back order :roll:
Might have one in my tool box. I'll check tonight.
Yeah got one. It was working when I took it out so should be fine. I always changed it when swapping cams as a matter of course! PM your address and I'll post it on Monday.
Time for a small update......................I got Best Engine Bay at the recent VR6 owners club rolling road day at Stealth Racing.
Im sure im not the only one who will say both congratulations and its not really a surprise.. The attention to detail is superb..
Not surprising really it is immaculate with some well thought out upgrade's well deserved.
Thanks guys, I've been at it again today.
1) Powder coated lower manifold to match the upper.
2) Refurbed injectors.
3) Rear engine hoist bracket.
That hoist bracket looks the business mate.
Have you had a closer look at the colour and texture match between the cam cover and lower inlet?
It's pretty close to be honest.
And we'll deserved too, Dave :)
