sime6920 0 Posted March 19, 2012 Hi all got vagcom lite located close to Eastbourne East Sussex if I can help any body let me know ! Quote Share this post Link to post Share on other sites
sexybourbon 0 Posted March 21, 2012 (edited) Can anybody help here please , i have had the cr on vag com and its thrown a engine speed sensor - 00513 (g2 8 ) 03-00- no signal When i had the car rolling roaded at stealth he said it was showing up a faulty cam position sensor so i changed that for a vrand new dealer one Is this the same code that would have been left behind when i changed the sensor or is this a totally different problem ? Ideally id just like to know what part is actually at fault if anyone knows Cheers guys Edited March 21, 2012 by sexybourbon Quote Share this post Link to post Share on other sites
RW1 0 Posted March 21, 2012 00513 - Engine running or just ignition? . Quote Share this post Link to post Share on other sites
sexybourbon 0 Posted March 21, 2012 Just the egnition on bud Quote Share this post Link to post Share on other sites
RW1 0 Posted March 21, 2012 Normal. It won't be there when the engine is running. Early diagnostics like the Corrado's didn't surpress the fault code when the engine is stopped. The code for the camshaft sensor is 00515. Quote Share this post Link to post Share on other sites
boredpilot 10 Posted April 20, 2012 Hi Can you add me to the list, just bought a cable that ive tested today. OBD2 cable end and Area to cover is Guernsey Channel Islands. Neil ---------- Post added at 1:05 PM ---------- Previous post was at 1:02 PM ---------- Hi Can you add me to the list, just bought a cable that ive tested today. OBD2 cable end and Area to cover is Guernsey Channel Islands. Neil Quote Share this post Link to post Share on other sites
MNuTz 0 Posted April 30, 2012 I really need to get my hands on a unit, 2 corrado's, one that won't start and one being rebuilt when funds allow + a golf with a few issues. What do I need to buy in order to use it? Quote Share this post Link to post Share on other sites
p0l1wrath 10 Posted April 30, 2012 (edited) Was just scrolling through some post on this thread as a mate of mine has a VAG-COM but only has the OBD II conector. On the first page of this thread stormseeker says that he made his own adapter to OBD I, made my own adapter last week before I went to look at a local VR6 that was for sale for jims16v Since he was last active in 2009, i dont think im gunna get a response out of him, but would like to know how he made this convertor, i dont wanna spend money on the real one but surely all it is, is 4 of the pins (or more?), on the OBD II connector connect to the 4 pins in the OBD I connector? Ive googled it but couldnt find anything on it? wondered if anyone on here has a solution? cheers Edited April 30, 2012 by p0l1wrath Quote Share this post Link to post Share on other sites
Critical_Mass 10 Posted April 30, 2012 Look on Ebay P0l1wrath, you can get ODB2 to 1 adaptors from there. Cheap. http://www.ebay.co.uk/itm/2X2-Adapter-Cable-OLDER-VW-AUDI-OLD-VAG-OBD2-OBDII-2-plus-2-OBD-/300690298924?pt=UK_Diagnostic_Tools_Equipment&hash=item460289d82c Quote Share this post Link to post Share on other sites
p0l1wrath 10 Posted April 30, 2012 oh cheers for that! when i searched i could only find ones that were like £20 probs just get one of those instead then :bonk: Quote Share this post Link to post Share on other sites
4eyes2wheels 0 Posted May 13, 2012 Got my VCDS Lite that scans the VR6 fine, but got a problem on the MkV R32 and it doesn't want to know. The Chassis list only goes as far as Golf/Bora MkIV - is this the obvious reason why? Is there a version that works with both OLD and NEW cars? Quote Share this post Link to post Share on other sites
RW1 0 Posted May 13, 2012 Got my VCDS Lite that scans the VR6 fine, but got a problem on the MkV R32 and it doesn't want to know. The Chassis list only goes as far as Golf/Bora MkIV - is this the obvious reason why? Is there a version that works with both OLD and NEW cars? The latest does at v11.11.3. Your problem is that VCDS Lite will not work with CANBUS diagnostics in more modern VAG car range like the R32. v11.11.3 will work backwards onto the VR6 though. VCDS-Lite Windows-based Diagnostic Software for VW / Audi / Seat / Skoda for non-dongle interfaces Some of the common differences between versions and between VCDS-Lite as Fully Registered versus Shareware: Shareware: Cannot do AutoScan Won't display text for all fault codes No Basic Settings (so no TBA, Xenon levelling, etc or checking timing on TDI's) No Adaptation Saving (so no changing of locking/lights/horn behavior) No Output Tests No tech support from Ross-Tech Limitations of VCDS-Lite compared to VCDS even if Fully Registered: No Generic OBD-II Won't work with CAN-Bus vehicles Fewer fault code definitions and label files No built-in Activation (you'll be limited to a single PC) No Advanced Measuring Blocks No Acceleration Measurement Quote Share this post Link to post Share on other sites
VW_OwneR_85 1 Posted May 23, 2012 Hi Can you add me to the list, just bought a cable that ive tested today. OBD2 cable end and Area to cover is Guernsey Channel Islands. Neil another guerner!!! welcome :) which corrado you got? iv seen a few around, Quote Share this post Link to post Share on other sites
boredpilot 10 Posted May 24, 2012 Mine is the Graphite Grey one, that you would see between the vale and the airport Quote Share this post Link to post Share on other sites
sam2.0 10 Posted July 25, 2012 I'm having no luck with my ebay cable (to use with VAG COM). Is it best to buy one of these (http://www.ebay.co.uk/itm/U480-Universal-OBD2-CAN-BUS-Fault-Code-Reader-Scanner-diagnostic-scan-tool-UK-/221039216694?pt=UK_Diagnostic_Tools_Equipment&hash=item3376f6c836)? Or anyone located near Oxford who maybe could help me out? Quote Share this post Link to post Share on other sites
elliott 10 Posted July 27, 2012 I'm having no luck with my ebay cable (to use with VAG COM). Is it best to buy one of these (http://www.ebay.co.uk/itm/U480-Universal-OBD2-CAN-BUS-Fault-Code-Reader-Scanner-diagnostic-scan-tool-UK-/221039216694?pt=UK_Diagnostic_Tools_Equipment&hash=item3376f6c836)? Or anyone located near Oxford who maybe could help me out? I just got one of those for the new CANBUS but i think it's OBDII only. Not sure but i could try it and see. The blue cable is a bit of a faf to get working. Quote Share this post Link to post Share on other sites
VW_OwneR_85 1 Posted August 4, 2012 (edited) can anyone tell me if these faults are wireing related ? this is from a 2001 BDE 2.8 from a 4motion into a corrado, immisions stuff should have been removed so im not sure if these lambda faults are important or not. my car cant idle to save its life! so im guessing its down to the maf fault, 17523 oxygen sensor heating : B1 S1 : short to ground p1115-002- lower limit exceeded 17527 O2 Sensor Heater Circ.,Bank2-Sensor1 Short to Ground 16486 Mass or Volume Air Flow Circ Low Input yea there wireing related !! arghh!!! Edited August 5, 2012 by VW_OwneR_85 Quote Share this post Link to post Share on other sites
Nosmonkey 10 Posted November 19, 2012 16 pin OBD2 connector, can cover north london :) Quote Share this post Link to post Share on other sites
ollielawson 0 Posted November 26, 2012 (edited) I have full vagcom with canbus for later VAG if needed or 2x2 for older stuff and happy to help anyone in Bournemouth / Poole (Dorset) Edited November 26, 2012 by ollielawson Quote Share this post Link to post Share on other sites
dil 0 Posted March 11, 2013 (edited) quick question i've never been able to scan the engine using 409.1 but i am able to scan the ABS unit, is this normal for an r32 conversion using mk4 loom? I am using an ebay jobbie cable (blue one), but it works perfectly on a vr6 golf. what i have tested Port 4 Earth?yes Port 7 Live?yes about 9.3 volts Port 16 Live?yes about 12.5 volts from what i have read these bunch of wires at the top of the fuse box are all OBD related? I assume one comes in from the ECU and one out to the port? Edited March 12, 2013 by dil additional info Quote Share this post Link to post Share on other sites
HF TURBO 10 Posted May 10, 2013 anyone in derby with vagcom and 2x2 connector? Quote Share this post Link to post Share on other sites
Tigerfish 10 Posted August 15, 2013 I've got a rosstech cable so can scan any vag car (also have obd2 readers for other cars). I'm in Basingstoke if anyone ever needs a scan. Quote Share this post Link to post Share on other sites
seanl82 23 Posted September 21, 2013 Willing to help anyone in need in the Fareham Hampshire area. Have VCDS with 16 pin OBD2 Style connector. Quote Share this post Link to post Share on other sites
Roger Chatfield 0 Posted October 31, 2013 Sean, when are next down in the motherland, I've an ABS problem I need scanning. Rog. Quote Share this post Link to post Share on other sites
seanl82 23 Posted October 31, 2013 Won't be down until just before Christmas mate. If you can hold out til then I don't mind bringing it down with me. Alternatively I can give it to an oppo of mine and you can pick it from him? Sure he wouldn't mind and you can hold onto it for a week or so if you need mate? Quote Share this post Link to post Share on other sites
