science 0 Posted May 30, 2011 bristolbaron said: I bought a facelift Octavia - 2000 onwards - panel yesterday and offered it up to the car. It physically fits, screws into place, sits well against the roof line, however it has a late 6 wire loom with a circular switch. the rado has a three wire loom with toggle switch. I couldn't work out a way of getting the wiring to work with the rado loom.. and if i did, then I'd still be left trying to fit the octavia panel to the rado panel which would involve a lot of cutting. I tried swapping the motors, however the octavia motor is offset and screws in with 3 screws, rather than the rados two so they wont swap. . I've had a look at the loom on mine and it's 4 wire into the switch and 6 wire in the sunroof motor. Given that this is right loom, do you think the Octavia motor would fit under the Corrado panel? Quote Share this post Link to post Share on other sites
Marshall936 0 Posted May 31, 2011 I just got a passat estate roof, only to find that when it was delivered the glass is far too big :( Gutted!!! ---------- Post added at 12:35 PM ---------- Previous post was at 12:25 PM ---------- In fact i've just spotted the glass from an ibiza for sale, if i just bought the glass is it possible to transfer that onto my current sunroof?? Quote Share this post Link to post Share on other sites
MikeVR6 0 Posted May 31, 2011 krishen said: Do you guys have quite a bit of wind noise with the moonroof? Mine does so just wondering if thats normal or should i try and replace the seal? Yes, although with the sunblind closed it's a bit quieter. I fitted a new outer seal and that reduced the noise a bit. It's still noisier than the original roof though. Just turn the stereo up :) ---------- Post added at 07:31 PM ---------- Previous post was at 07:22 PM ---------- Marshall936 said: I just got a passat estate roof, only to find that when it was delivered the glass is far too big :( Gutted!!! ---------- Post added at 12:35 PM ---------- Previous post was at 12:25 PM ---------- In fact i've just spotted the glass from an ibiza for sale, if i just bought the glass is it possible to transfer that onto my current sunroof?? What year Passat Estate? There's good info on Moonroof fitting here... http://forums.motivemag.com/showthread.php?3808393 Quote Share this post Link to post Share on other sites
matty golf 0 Posted June 5, 2011 any 1 know if a mk 4 polo roof fits and also can you put electric motors on manual roofs Quote Share this post Link to post Share on other sites
Marshall936 0 Posted June 9, 2011 MikeVR6 said: Yes, although with the sunblind closed it's a bit quieter. I fitted a new outer seal and that reduced the noise a bit. It's still noisier than the original roof though. Just turn the stereo up :) ---------- Post added at 07:31 PM ---------- Previous post was at 07:22 PM ---------- What year Passat Estate? There's good info on Moonroof fitting here... http://forums.motivemag.com/showthread.php?3808393 So according to that a mk3 golf and a jetta will fit? Quote Share this post Link to post Share on other sites
krishen 2 Posted June 9, 2011 Marshall936 said: So according to that a mk3 golf and a jetta will fit? Im pretty certain the Golf one will NOT fit. Think its too 'curved'. Quote Share this post Link to post Share on other sites
nicksxjr 0 Posted June 11, 2011 davidwort said: mk3 panel won't fit at all, very different shape. i took at mk3 roof from a gti and it fits and works fine ?? Quote Share this post Link to post Share on other sites
nicksxjr 0 Posted June 11, 2011 not at work but il see what i can do when im home tomorow i have photos some where of all the interior out as i was doing it bit by bit. Quote Share this post Link to post Share on other sites
matty golf 0 Posted June 11, 2011 just put an ibiza moon roof in mine but it dont seem to be runni square with the runners??? Quote Share this post Link to post Share on other sites
Marshall936 0 Posted June 13, 2011 Got myself a mk3 golf sunroof and its slightly more 'curved' but fits pretty well and works fine :) Quote Share this post Link to post Share on other sites
krishen 2 Posted June 14, 2011 Have you guys got any pics? Might help people in future wanting to change to moonroofs. Quote Share this post Link to post Share on other sites
Kev_VR6 0 Posted June 14, 2011 I've gone for the Passat B3 roof and am getting the bodyshop to fit for me while it's in. I'll get pics up soon as I get it back... Quote Share this post Link to post Share on other sites
Marshall936 0 Posted June 17, 2011 Here's mine: Quote Share this post Link to post Share on other sites
GlosterOx 0 Posted June 18, 2011 Is it watertight due to the different curvature? Ian. Quote Share this post Link to post Share on other sites
Marshall936 0 Posted June 18, 2011 Havent had any drips? think theres drainage pipes on all 4 corners too :) Quote Share this post Link to post Share on other sites
_Meth 0 Posted June 20, 2011 probably be a bit more noisy I would imagine Quote Share this post Link to post Share on other sites
mr lobitos 0 Posted July 7, 2011 sorry to bother, have stripped out headlining to fit passat moonroof tomorrow, question is after reading through quite a few posts , there is a few mentions of fitting washers for spacing so roof sits properly , is this correct and if so how many and on which bolts, advice needed Quote Share this post Link to post Share on other sites
krishen 2 Posted July 7, 2011 When i fitted mine didn't need any spacers. And it sits fine and works perfectly. Mine is off a passat (i think). Quote Share this post Link to post Share on other sites
_Meth 0 Posted July 9, 2011 You will see when you bolt it up, but you will probably need some washers / spacers for the front bolts as the front may sit a bit higher than you want. Thus making it a bit noisier and possibly leaky. Quote Share this post Link to post Share on other sites
Kev_VR6 0 Posted July 30, 2011 Picked my car up earlier today - had the body shop fit the moonroof for me and it looks great. It was the Passat B3 Estate version. Here's a couple of pics of it... [ATTACH=CONFIG]48263[/ATTACH][ATTACH=CONFIG]48264[/ATTACH] Quote Share this post Link to post Share on other sites
Peebee 0 Posted November 28, 2012 Nice one mate, I've got the same in mine, personally looks much better than the original tin ones. Quote Share this post Link to post Share on other sites
BigTartanJudge 0 Posted November 29, 2012 Interesting, that looks like a proper rubber seal, which is unusual as the Passat ones come with a fabric-type seal which is rubbish... Quote Share this post Link to post Share on other sites
fendervg 33 Posted November 29, 2012 You shouldn't need any washers - there are adjusting screws front and back for proper alignment Quote Share this post Link to post Share on other sites
