CazzaVR
OEM VW Parts Price Enquiries
For £120 you can! Not sure if the stealer can get them i got mine from a German website and silenced the swarm of angry bees under the bonnet!
I've just been quoted £93 + VAT for a VR6 main radiator hose (part number 535121101H). Ouch!
Right, Ive been shopping at my local dealers, so have some prices to update on here.
V535 807 181 front splitter reinforcement £27.81
V021 133 073 C throttle body gasket VR6 £4.92
V021 133 917 HT front lead holder VR6 £13.22
V021 133 824 cable holder/manifold VR6 £4.96
N101 473 01 nut holder front splitter £0.62
N015 946 1 screw for front splitter £0.24
N904 338 01 bolt for front splitter £2.11
535 121 101 L top hose VR6 £93.47
1H0121157H water hose / (throttle valve housing > heat exchanger>cylinder head) £40.81
G12 ++ £7.45
All prices are plus VAT and what ever you get off from your friendly parts man, or is that just me ?
Ill update when I buy more stuff from VW
535 837 184 A - o/s door door pin lever (the rod from the catch to the pin) 7.19
4A0 919 040 C - dash bulb 1.58
17/12/2010:
536 819 831 - heater controls flap bowden cable 10.23
357 837 084 - o/s door inner lock lever (the plastic bit that the c/locking rod attaches to) 0.48
31/12/2010:
N0 199 123 - rear carrier bolt 2.07
535 955 121 - front wiper crank 2.99
536 955 325 - front wiper link rod 11.24
20/01/2011:
1H0 422 804 A - Track rod (right) 65.52
191 407 181 D - Rear front wishbone mount 10.33
07/04/2011:
6K0 919 243 - bulbholder 4.12 (already down, new price)
357 919 243 - Late heater controls bulb/holder/ashtray bulb holder 4.12 (already down, new price)
7L6 947 175 A01C - cigarette lighter torch (not a Corrado part strictly speaking!) 18.38
31.05.2011:
535 868 523 01C - rear lower seat belt guide, black (the ones in the rear door cards) 5.77 each BACK ORDERED
253 260 130 7UK - 'Clip' - trim fasteners for centre tunnel lower cover (x4) and rear door cards (2 per door card) in beige 1.42 each
Prices are before discount and VAT
Parts for replacing the foliage seal (as per the wiki):
535853837 - Sleeve - £0.25
191819616 - Foliage seal - £4.20
535853832A03C - Clip - £0.47
g60 ign coil 211 905 115 d 56.83 + vat
i get 10% off as off 19/10/11 they had 7 -1 for me
Working for a ford main stealer I get roughly 40% off vr6 engine bits but they still wanted £130 inc vat for the aux belt tensioner! Anybody bought one recently? Genuine/non gen? How much? Good quality?
Enquired about a few bits I'm gonna need for MOT in a couple of weeks, and an oil pressure sensor today.
Items are for 1990 16v, all prices include VAT.
ARB Droplinks - 535411315 £47.64 each.
Rear wheel bearing kit - (No part number I'm afraid), but £31.69 each.
Oil pressure switch (Black 1.4 bar) 068919081D £12.67
Fittings to hold the engine plastics on top of a VR6 (the trisquare ones):
N 905 081 01 Bolt w/multi spline socket head M6x18: £0.72
021 133 915 B Shouldered nut w/multispline socket head M6: £3.25
Crank Position Sensor: 021 906 433 A is £114.19 inc vat
O-ring for above: 021 906445 is £2.08 inc vat
This is a great thread, just what i need, i have been writing down all the bits i need and was trying to gather part numbers rather than spend a few days in the dealers looking at the computer pictures :lol:
My List, all for a 1995 VR6:
-Gearbox Mount
-Throttle Cable
-Steering Rack
-Steering Column
-Front Brake Dust Covers + Bolts
-ABS Sensors, Front & Back
-Aux Belt, No Aircon
-Bonnet Insulation
-Bonnet Alarm Sensor (vag5000)
-Mk4 Header Tank - £30?
-Lower Ball joint Bolts + Nuts, 3x per side
-Wishbone Bolts, 2x per side
-ARB end bolts
-Sump Bolts (i seem to have a mix of 10mm bolts and round allen key ones??)
-Front Suspension Strut lower bolts, 2x per side
-Subframe bolts(think there are 4, and also are longer ones availiable, the bentley manual mentions them)
-Coolant hose clips
I realise its a massive list and probably going to cost a small fortune, just not sure which bits are obselete, or ok to get from gsf/aftermarket.
I have loads of receipts and part numbers which i can add to this thread
Heres a few more;
W1HO 407 151A NSF wishbone £102.77 (ouch)
W1HO 407 152 OSF wishbone £102.77
W357 412 331A Strut Mounting £19.18
W1JO 412 249 Thrust Bearing (to go with mounting) £6.45
W1JO 412 341 Plate for mounting £6.83
W1HO 407 365 Ball joint £25.58
Sump Gasket £36
Tie Rod ends £26, thread nuts to go with them 63p each
All prices are plus VAT.
(March 2012 prices)
Just collected from TPS - prices ex. VAT with 9% discount applied:
191 615 612 B Rear brake disc splash plate (right) £14.60
191 615 611 D Rear brake disc splash plate (left) £14.60
191 501 639 B Cover for stub axle (w/ ABS) £2.71
-Gearbox Mount (
-Throttle Cable (£46
-Steering Rack (buy a recon unit from Eurocarparts)
-Steering Column (theres a group buy at the moment on here)
-Front Brake Dust Covers + Bolts (n 905 293 01 x4, 357 615 311 A x2)
-ABS Sensors, Front & Back (191 927 807 A x2, 191 927 807 D x2)
-Aux Belt, No Aircon (Eurocarparts, I say gates are the best make)
-Bonnet Insulation (535 898 123 A)
-Mk4 Header Tank - £30? (021 121 407 £28.01)
-Lower Ball joint Bolts + Nuts, 3x per side (+N 101 277 06 x6, 1J0 407 175 x2)
-Wishbone Bolts, 2x per side (N 904 840 03 x2, N 102 078 03 x2)
-ARB end bolts (N 019 504 3 x2)
-Sump Bolts (i seem to have a mix of 10mm bolts and round allen key ones??) (N 900 084 01 QTY 26 £56p each)
-Front Suspension Strut lower bolts, 2x per side (N 101 740 02 x2, N 903 237 04 x4)
-Coolant hose clips
with prices added to your list
Matt
  VR6Pete said:
im looking for a price on the sunroof seals ? can you still get these?
I've seen them a few months back in ebay selling them for £50
