bigchagg 0 Posted September 1, 2014 (edited) Ok iv just read this thread and im trying to run 7.5 x 17 with et35 shud be ok apparently however when test fitted the front they wouldn't fit as the calipers hit the inside face of the rim. Anyone know why? Do have to fit an 8mm spacer? Iv got a vr6. Edited September 1, 2014 by bigchagg Quote Share this post Link to post Share on other sites
clumpy1 11 Posted September 1, 2014 Ok iv just read this thread and im trying to run 7.5 x 17 with et35 shud be ok apparently however when test fitted the front they wouldn't fit as the calipers hit the inside face of the rim. Anyone know why? Do have to fit an 8mm spacer? Iv got a vr6. What's the wheel's? Quote Share this post Link to post Share on other sites
bigchagg 0 Posted September 1, 2014 The wheels are a set of bbs rs reps Quote Share this post Link to post Share on other sites
clumpy1 11 Posted September 1, 2014 The wheels are a set of bbs rs reps I'll pass this to BristolBaron I can't get how if they are ET35 and 5x100 fitment they would foul on your brake caliper if you had big brake's yes but you haven't :scratch: Quote Share this post Link to post Share on other sites
Sean_Jaymo 0 Posted September 1, 2014 Cheap/low quality reps must have less spoke clearance. My 16x7 et 35 wheels only have 5/6 mm of clearance in places. Quote Share this post Link to post Share on other sites
coullstar 0 Posted September 2, 2014 They do, its the dish on them. To get a good dish with that width the wheel face sits very close to the hub face therefore close to the calipers. If its front you want hubcentric and I think the minimum you can get with them is 8mm wide. Quote Share this post Link to post Share on other sites
bigchagg 0 Posted September 2, 2014 They do, its the dish on them. To get a good dish with that width the wheel face sits very close to the hub face therefore close to the calipers. If its front you want hubcentric and I think the minimum you can get with them is 8mm wide. Yes this is what's happening. I'm gonna play around with some spacers this week and see fits best. Quote Share this post Link to post Share on other sites
TomBarker1991 10 Posted October 8, 2014 Looking at some wheels for my 1.8 16V fronts are 16" 8.5J ET50 and the rears are a 16" 9J ET50 my arches are already rolled but can be pulled but just wondering if an ET50 would give me any clearance issues over the the front 256mm's and or what spacers I might need! Quote Share this post Link to post Share on other sites
leon263 0 Posted October 8, 2014 Standard wheels will be 6.5, ET43. Simple maths says that you will have 32mm less clearance behind the fronts and they will extend another 18mm. You will have 39mm less clearance behind the rears which will extend another 25mm. I'd think that you will certainly need spacers behind the wheels to clear the struts and obviously the width of the spacer will bring the wheel out by the same amount. I'm not quite sure how you would work out the width of the spacers without having a selection of them to try. Perhaps some-one else who has a similar set-up will jump in and help. Quote Share this post Link to post Share on other sites
ross k 10 Posted October 8, 2014 I had 9x16 et15 on my 16v and there was maybe 4mm between the trailing arm and wheel so you would need spacers to bring the et to around et15 to get them on the back to clear the trailing arm hope that helps with standard rolled arches you will need to run 205/40 tyres to prevent rubbing Sent from my LT15i using Tapatalk 2 Quote Share this post Link to post Share on other sites
TomBarker1991 10 Posted October 8, 2014 Cheers for the replies by the sounds of it I'm going to be looking at 30-35mm spacers all round which is more than I would be happy using! Quote Share this post Link to post Share on other sites
Gibbo 10 Posted October 27, 2014 Hi can someone please tell me if a set of Lenso bsx 16x7.5 et25 with 195/45/16 will fit my vr6 without any arch work? Thanks. Quote Share this post Link to post Share on other sites
BILLCOR 1 Posted October 27, 2014 Shouldn't be a problem Quote Share this post Link to post Share on other sites
Gibbo 10 Posted October 27, 2014 (edited) Thanks :thumbleft: forgot to say it will be on coilovers as well but unsure how low it will be until I get it back from the garage. Edited October 27, 2014 by Gibbo Quote Share this post Link to post Share on other sites
clumpy1 11 Posted October 27, 2014 You will be fine bud mine on KW V1's 8x16" ET15 205/45/16's [ATTACH=CONFIG]80007[/ATTACH] Quote Share this post Link to post Share on other sites
Declan Sedrick Lehane 10 Posted October 28, 2014 (edited) Will either of these fit on the VR6? I know I'd need adapters, could they work? 8,5x17 5x112 ET13 the hub hole 66,5mm or 8,5x17 5x112 ET28 or 7x17 5x112 ET-45 or also, how would these look: 7,5x17 5x100 ET32 The diameter of the center bore: 57,1mm. Edited October 28, 2014 by Declan Sedrick Lehane Quote Share this post Link to post Share on other sites
BILLCOR 1 Posted October 28, 2014 Think you'll struggle with the first two due to needing adaptors and the already low ET. set three will be fine with 20/25mm adaptors and set four near perfect and fit straight on Quote Share this post Link to post Share on other sites
Declan Sedrick Lehane 10 Posted October 28, 2014 what would the last set look like? Will they will the arches well enough? Cars Lowered and ideally would like it sitting rather flush! Quote Share this post Link to post Share on other sites
BILLCOR 1 Posted October 28, 2014 what would the last set look like? Will they will the arches well enough? Cars Lowered and ideally would like it sitting rather flush! These are BBS RC's, 17x7.5 ET35, so your gonna have a whole 3mm more poke, you could always add a 5-8mm spacer Quote Share this post Link to post Share on other sites
Declan Sedrick Lehane 10 Posted October 28, 2014 Cheers for that!! I just don't know if 17's are too much for the Raddo! Quote Share this post Link to post Share on other sites
A5 VRX 0 Posted October 28, 2014 Cheers for that!! I just don't know if 17's are too much for the Raddo! All depends on the fit, ET's, tyres widths etc. Some look over wheeled but most when thought about look just right. 17's gives you that little bit more clearance too Quote Share this post Link to post Share on other sites
BILLCOR 1 Posted October 28, 2014 Cheers for that!! I just don't know if 17's are too much for the Raddo! As said, It depends on the wheel, the RC's do tend to look bigger for some reason, dont know if its the long spoke design. Which wheels were you considering? Here's another pic of the RC's and also bare in mind, my car wasn't that low, if you get the tyres slightly tucked, 17's look great The last two are 17x8.5 ET35 CH's Quote Share this post Link to post Share on other sites
Declan Sedrick Lehane 10 Posted October 28, 2014 Thats the thing, some photos I see they look amazing, some look over wheeled! I was thinking the following Borbet's? [ATTACH=CONFIG]80023[/ATTACH] Quote Share this post Link to post Share on other sites
A5 VRX 0 Posted October 28, 2014 If they are not that wide they should tuck well (if 7.5) I've got BBS RC's in 16 x 7.5 form which I want to sell to go 17's soon, I just think that you need to think a little more when it comes to getting 17's to sit 'right' Bill- CH's looked the biz Quote Share this post Link to post Share on other sites
Declan Sedrick Lehane 10 Posted October 28, 2014 I want them sitting flush so may need a little play if I get them! Quote Share this post Link to post Share on other sites
