daves16v 1 Posted February 7, 2012 Fitted my OEM gauge at the weekend but didn't run it up to temp. Today I ran it up to temp to check another problem and now the oil pressure light is flashing when it's fully warm. The gauge is reading about 2bar at idle which I think is about right. I've double checked everything including the position of the dual pole sender on the oil filter housing. The sender is a 10 bar item and there is plenty of oil in the engine, I didn't have a problem before the gauge install. Increasing engine speed cures things but then back at idle the light is flashing again. Was ok during warm up which I expected as the pressure is usually higher. I'm running out of ideas. Any suggestions? Thanks Quote Share this post Link to post Share on other sites
Rams 0 Posted February 7, 2012 (edited) I am thinking it might be the connection on the dual pole sender or how the wire is attached. I take it you have checked the earth? I found the crimps aren't great with the size of the wire kit so maybe try soldering if you haven't already? What was the other problem you mentioned? Edited February 7, 2012 by Rams Quote Share this post Link to post Share on other sites
16VG60 1 Posted February 7, 2012 Sounds to me like your low oil pressure warning setting, which is part of the dual Pole sender unit, has a low pressure setting which is too high for your engine. Ideally you need 2bar at 2000rpm when the oil is at 80 degrees C. If the low pressure warning is set too high, but your actual Pressure is ok, this would explain why when you increase the idle the warning ceases. The low pressure setting of your sender is stamped into the hex nut at its base. Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
Rams 0 Posted February 7, 2012 When I ordered mine they did ask questions about psi and at what stage it needs to alert. Your sender is Warning you at low revs as the rating of the sender is to make that alert. When you rev, pressure increases and the sender is thinking its within parameters and doesn't alert. So 16VG60 has probably hit the nail on the head! Quote Share this post Link to post Share on other sites
RW1 0 Posted February 8, 2012 What pressure setting is the pressure switch in the sender? Its usually stamped on the sender unit body like the pressure switch you took out About 0.5bar normally. It may be that this pressure switch is faulty in the new sender and is contacting even though the idle pressure is 2 bar. . Quote Share this post Link to post Share on other sites
daves16v 1 Posted February 8, 2012 Thanks for the info chaps, I'll take a look at the sender. Quote Share this post Link to post Share on other sites
daves16v 1 Posted February 8, 2012 Looks like I've got the wrong sender as it's low pressure is stamped on the side at 2bar. Thanks again for the help. Quote Share this post Link to post Share on other sites
16VG60 1 Posted February 8, 2012 Hopefully you might be able to exchange it. Albeit inconvenient, far better this than a real oil pressure issue. Glad your sorted now. Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
fla 9 Posted February 21, 2012 i have a VDO sender with the following specs: 0-10bar 0.5 +/- 0.15 bar also these markings, 604 3019 and at the top G (i assume ground?) and WK (??) will this be suitable for the Audi gauges (3-gauge setup)? On the topic of gauges, fitting the oil temp gauge - is this just a question of a switched live and wiring directly to the oil temp spade on the oil filter housing? Quote Share this post Link to post Share on other sites
ChrisL 19 Posted April 4, 2012 (edited) My Oil pressure gauge has started to act up a bit. Turned the ignition on today and the gauge needle goes straight over to the maximum (10bar) and stays there. any ideas please? Edited April 4, 2012 by ChrisL Quote Share this post Link to post Share on other sites
huggy 0 Posted April 5, 2012 G is not for ground One terminal goes to the oil warning light the other to the gauge, I can't remember which way round it is, but I will check for u The problem may not be the pressure at which the sender actuates, but how it actuates from what I recal there should be a connection to ground bellow 1.4 - 2bar (normaly closed) and an open (no connection) to ground above 2bar the oil light will only come on above 2500rpm if I recal. If this is the issue with yours, you can change the sender or fit a relay, the relay will be the cheaper option if you can't get a refund for the sender, and being an electrical inst tutor I can provide u with a wiring diagram ---------- Post added at 8:32 AM ---------- Previous post was at 8:30 AM ---------- If it goes to the 10bar and has been working either the sender is screwed / cloged or the wire to the sender has a short to ground Quote Share this post Link to post Share on other sites
Wesleyvr6 10 Posted October 20, 2012 Dave did you ever sort this problem? Quote Share this post Link to post Share on other sites
daves16v 1 Posted October 21, 2012 Dave did you ever sort this problem? Yeah, got the wrong sender, all working fine now. Quote Share this post Link to post Share on other sites
Wesleyvr6 10 Posted October 21, 2012 Do you have a part number Dave for the one you now have? As I think I've been sold the wrong one! Quote Share this post Link to post Share on other sites
daves16v 1 Posted October 21, 2012 Wes, bought from Merlin Motorsport 09/02/12 Stock Code - 360081030009C Description - VDO Oil Pressure Sender 10 Bar M10x1 W/C 0.5 Cost delivered - £69.07 Hope this helps Dave Quote Share this post Link to post Share on other sites
