Portent 0 Posted July 18, 2012 I've fitted an uprated loom recently but I'm not yet happy with the placement of the relays. I've mounted them in a box but there seems no obvious place to locate the box. Where do you guys put yours? It's a superb upgrade though. I wish I'd done it ages ago. Quote Share this post Link to post Share on other sites
seanl82 23 Posted July 19, 2012 Most put it in front or on the side of the battery stuck with sticky pads or similar mate. Depends what motor you have with regards to space, but inner chassis leg is even an option. Just in front of the battery would be my reccommendation though, as you can route and hide cabling in existing runs if its all wrapped up nicely. Quote Share this post Link to post Share on other sites
carrots 1 Posted July 19, 2012 mine just dangle there because the cable is to short to mount them Quote Share this post Link to post Share on other sites
fendervg 32 Posted July 19, 2012 I have them ahead of the battery in a water tight sealed box to keep the dirt and rain out. I remember on my MkII Golf, there were actually a couple of captive bolts on the inside of the drivers wing where you could mount the relays. Quote Share this post Link to post Share on other sites
fla 9 Posted July 19, 2012 by the battery in a watertight box. But Fishwick has run cables inside his car and kept the relays inside, which is perhaps the best option. Quote Share this post Link to post Share on other sites
Roger Blassberg 0 Posted July 19, 2012 My instinct was to run the cables to relays mounted on the spare locations on top of the relay plate. But there is the counter-arguement to that which is to keep the cable runs as short as possible to minimise voltage drop. I have mine in the engine compartment as high as possible, in fact cable tied to an aircon hose, nice and cool. Best wishes RB Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted July 19, 2012 Fishwick has run cables inside his car and kept the relays inside, which is perhaps the best option. Yep, fit and forget ;) Quote Share this post Link to post Share on other sites
Portent 0 Posted July 19, 2012 Thanks. I've currently mounted it in a box and mounted that on the battery but it's not as tidy as I'd like. I'm not too keen on just leaving it laying around in front of the battery as I think that might cause problems in the future. I'll have a look for those bolts on the inner wing. I'd far prefer it is securely fastened somewhere and not dangling where water can collect. I'd also like it visible so that anyone in the future can easily trace it back to the fuse and relays if they lose the lights. Quote Share this post Link to post Share on other sites
bmwcompact 10 Posted July 19, 2012 I bought one recently from KUR2Y. I pmed him to say I was impressed with the build and improvement to the lights. However I too thought there was no suitable mounting location (2L 16V). I suggested that he canvass a few folks for a suitable location for the relays and then modify his looms to suit. He seemed happy to do this. So whats the solution? Quote Share this post Link to post Share on other sites
