Alty 10 Posted November 22, 2013 Got the back stripped out and plan on building a false floor etc. but has anyone found a just a good but cheaper alternative to dynamat ? Quote Share this post Link to post Share on other sites
n3p 3 Posted November 22, 2013 Apparently flashing tape works well and is cheaper. Available at B&Q etc... If you use it, let me know how you get on. Sound proofing is on my never ending list of things to do! Quote Share this post Link to post Share on other sites
Alty 10 Posted November 22, 2013 Are we talking Flashband ? like this http://www.travisperkins.co.uk/p/evo-stik-flashband-grey-600mm-x-10m/531345/3893480 If so I work for Travis Perkins ! Staff discount FTW! Quote Share this post Link to post Share on other sites
n3p 3 Posted November 22, 2013 Certainly looks like it, but can't say for sure. Google is your friend :) Quote Share this post Link to post Share on other sites
fla 9 Posted November 22, 2013 don't use it, its not nearly as good as the proper stuff - also you'll need twice as much to get a similar effect and its heavier. I tried both(although I used Damplifier) so that's my own experience/error! Incidentally it does also depend what you want to do - this only reduces panel vibration and wont really stop road noise. For that you need a sound blocker (for low frequencies) which is that heavy bitumen black layer with the padding behind it. You then need to separate that from the floor itself and you can use something like Cloud 9 underlay. That will stop the bulk of the road noise, assuming that's what you're looking to do? I've got about 10 sheets of damplifier left over if you're interested? Quote Share this post Link to post Share on other sites
Alty 10 Posted November 22, 2013 The more I read on this the more I think I should just get my wallet out and pay for some dynamat! Thanks for the offer though. Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted November 22, 2013 Are you sound proofing for audio reasons or just trying to make the car quieter? I dynamatted mine years ago (including the roof to stop that vibrating from the bass) and it made little difference to overal refinement, but it did work well on thinner panels near speakers to stop them flapping about. To make the car quieter, I recommend this fire and water resistant foam. http://www.efoam.co.uk/fireseal-foam.php I used the 12mm thick stuff and stuck it to every panel on my MK4 over the summer and it made a huge difference :) Quote Share this post Link to post Share on other sites
Alty 10 Posted November 22, 2013 I'm doing this to reduce road noise + the Fing exhaust noise! I'm getting old! a false floor will be going in anyway but I thought it would be a good idea to put something onto the metal work first. Quote Share this post Link to post Share on other sites
EJ Taylor 22 Posted November 22, 2013 Use silent coat mate! £90 for 40 sheets, we use it all the time at Oxford Car Audio. what i have used on the rado. If you were in the oxford area i could sort you a better price, due to the weight there isnt much point in me posting it as its cost silly amounts to send! Quote Share this post Link to post Share on other sites
EJ Taylor 22 Posted November 22, 2013 http://www.caraudiodirect.co.uk/silent-coat-40-sheet-bulk-pack-of-car-sound-proofing-deadening-vibration-2mm-mat Forgot the link sorry Quote Share this post Link to post Share on other sites
EJ Taylor 22 Posted November 22, 2013 Company on ebay doing the 40 sheet bulk back for £79.49 and free postage. would go for that http://www.ebay.co.uk/itm/Silent-Coat-2mm-Bulk-Pack-40-Sheets-Car-Sound-Deadening-Vibration-Proofing-Mat-/151155678947?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item2331949ee3 Quote Share this post Link to post Share on other sites
dragon green 6 Posted November 22, 2013 I used dynamat,and then put dynaliner over the top of it. I've used fatmat,but not as good as dynamat/dynamat lite To stop excessive exhaust drone,I found the best mod was to soundproof the underside of the parcel shelf Quote Share this post Link to post Share on other sites
Alty 10 Posted November 22, 2013 EJ Taylor said: Company on ebay doing the 40 sheet bulk back for £79.49 and free postage. would go for that http://www.ebay.co.uk/itm/Silent-Coat-2mm-Bulk-Pack-40-Sheets-Car-Sound-Deadening-Vibration-Proofing-Mat-/151155678947?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item2331949ee3 Looks good thanks for the help. dragon green said: I used dynamat,and then put dynaliner over the top of it. I've used fatmat,but not as good as dynamat/dynamat lite To stop excessive exhaust drone,I found the best mod was to soundproof the underside of the parcel shelf Back is completely stripped out :D Quote Share this post Link to post Share on other sites
EJ Taylor 22 Posted November 22, 2013 Alty can you post up some photos or send me some of the process and the end result as im currently designing mine to do the same. Quote Share this post Link to post Share on other sites
Alty 10 Posted November 22, 2013 Yeah sure no problem But I will say I'm not in a rush by any means :-) Quote Share this post Link to post Share on other sites
VR6 Gar 10 Posted November 22, 2013 Another vote for Silentcoat. Even though the boot of mine had already been covered in an unknown type(2mm) I recently add some 4mm silentcoat over the top of it in the boot. It made a huge difference and drastically reduced the drone from the exhaust. If your exhaust isn't too loud you will get away with the 2mm stuff otherwise you will need to either double layer it or buy some 4mm just for the boot area. Quote Share this post Link to post Share on other sites
EJ Taylor 22 Posted November 22, 2013 just bare in mind all this sound deadening is added weight, this is something i thought of after i was 80 sheets in. haha Quote Share this post Link to post Share on other sites
Alty 10 Posted December 3, 2013 [ATTACH=CONFIG]76617[/ATTACH] Will be on this at the weekend I'll send pictures when I'm finished! Quote Share this post Link to post Share on other sites
davidwort 0 Posted December 3, 2013 headlining felt from scrapped large cars and vans was always my favourite, don't use in damp locations like the inside of doors but great for rear quarters, centre tunnel, under dash and floor and anywhere you can stuff and glue it out of sight, it's light compared to the thin sheet high mass stuff which I only use in certain locations it's more suited to. Quote Share this post Link to post Share on other sites
EJ Taylor 22 Posted December 4, 2013 Alty said: [ATTACH=CONFIG]76617[/ATTACH] Will be on this at the weekend I'll send pictures when I'm finished! thats the stuff!! :afro: davidwort said: headlining felt from scrapped large cars and vans was always my favourite, don't use in damp locations like the inside of doors but great for rear quarters, centre tunnel, under dash and floor and anywhere you can stuff and glue it out of sight, it's light compared to the thin sheet high mass stuff which I only use in certain locations it's more suited to. cheap skate :shades: Quote Share this post Link to post Share on other sites
