thesingh 0 Posted January 29, 2014 I know its not possible to install these DDI clocks on a 8v or 16v Corrado and it is only available on the G60 and VR6. To my knowledge no one has converted these clocks to work on a 8v/16v. The question I want to know is, how do they work that these clocks are exclusive to the VR6/G60 clocks? By no means I am an electrician or a Corrado guru but in my head its just dial plate and lighting. Sorry if it sounds like a daft question, I have tried to google, search on the forum and even email DDI them self but cant seem to find an answer. Thanks Quote Share this post Link to post Share on other sites
Roger Chatfield 0 Posted January 29, 2014 Sorry for my ignorance but what are DDI clocks? Rog. Quote Share this post Link to post Share on other sites
clumpy1 11 Posted January 29, 2014 Aftermarket illuminated Dial's Rog you may be able to get them here http://www.spoonfedtuning.com/ Quote Share this post Link to post Share on other sites
seanl82 23 Posted January 29, 2014 Here you go mate. http://www.dubdesignindustries.com/catalog/index.php?cPath=69_75_78 Edit; ahh, beat me to it! Quote Share this post Link to post Share on other sites
thesingh 0 Posted January 29, 2014 Set of these bad boys. Quote Share this post Link to post Share on other sites
Jim 2 Posted January 29, 2014 I'm not sure it's an electrical or connectivity issue - more simply that 8v/16v/G60/VR6 all have different rev limits - so the rev limit / redline will be incorrect if you fit them to an 8v/16v! Quote Share this post Link to post Share on other sites
Hofmiester 10 Posted January 29, 2014 To be honest, I had them and took them out. They are quite badly made and so prone to flickering, look cheap in that the face design has a fairly naff font....plus there is no needle stop so the needle just hangs there at the bottom. Not great and will probably fall into the depths of chavdom like the White faced dials on the 90s Quote Share this post Link to post Share on other sites
thesingh 0 Posted January 29, 2014 I'm not sure it's an electrical or connectivity issue - more simply that 8v/16v/G60/VR6 all have different rev limits - so the rev limit / redline will be incorrect if you fit them to an 8v/16v! Is that the only issue? Quote Share this post Link to post Share on other sites
dragon green 5 Posted January 29, 2014 Yes, As Jim says,the rev counter will be wrong,everything else will be good Quote Share this post Link to post Share on other sites
thesingh 0 Posted January 29, 2014 Thanks guys. I think im going to get these fitted. To be honest, I had them and took them out. They are quite badly made and so prone to flickering, look cheap in that the face design has a fairly naff font....plus there is no needle stop so the needle just hangs there at the bottom. Not great and will probably fall into the depths of chavdom like the White faced dials on the 90s Has any one else had the issue Hofmeister had experienced? Quote Share this post Link to post Share on other sites
seanl82 23 Posted January 29, 2014 (edited) Don't think it's been mentioned clear enough. Bear in mind that your rev counter will indicate the wrong amount of revs. The counter is calibrated differently, it doesn't just go round a bit further on the valver. This may cause issues come MOT time with the tester doing the fast idle indicated on the clocks for a vr at 2.5k, but in reality a valver will be closer to 3k. I THINK there is actually a rev detector on the test equipment, but if not this could mean the difference between a pass and a fail on emissions. Not worth the hassle imo. Edited January 29, 2014 by seanl82 Quote Share this post Link to post Share on other sites
robrado974 1 Posted January 30, 2014 After market......... Leave it on the display rack . Quote Share this post Link to post Share on other sites
thesingh 0 Posted January 30, 2014 Don't think it's been mentioned clear enough. Bear in mind that your rev counter will indicate the wrong amount of revs. The counter is calibrated differently, it doesn't just go round a bit further on the valver. This may cause issues come MOT time with the tester doing the fast idle indicated on the clocks for a vr at 2.5k, but in reality a valver will be closer to 3k. I THINK there is actually a rev detector on the test equipment, but if not this could mean the difference between a pass and a fail on emissions. Not worth the hassle imo. Your right that is more hassle than its worth. Thank you for clearing that with me. Quote Share this post Link to post Share on other sites
G60 CS 0 Posted January 30, 2014 there's a polish company that all the European guys use that can make them up to suit any car, Im getting some custom ones done when I move my rev counter and speedo round the other way ;) Quote Share this post Link to post Share on other sites
dragon green 5 Posted January 30, 2014 I can vouch for the spoonfed ones,(with illuminated needles) Quote Share this post Link to post Share on other sites
fla 9 Posted January 30, 2014 I can vouch for the spoonfed ones,(with illuminated needles) Look fantastic, but wasn't he the chap that turned out to be less than pleasant though (to Abdul)? Quote Share this post Link to post Share on other sites
thesingh 0 Posted February 7, 2014 That looks good.. What kind of cost are we looking at? Any details for him? Quote Share this post Link to post Share on other sites
dragon green 5 Posted February 7, 2014 (edited) http://www.spoonfedtuning.com/ The needles where done by a man named Luis Amoa (USA) Edited February 7, 2014 by dragon green Quote Share this post Link to post Share on other sites
thesingh 0 Posted February 7, 2014 They look awesome. but its for G60 :( I will email them see if they can do something for my 8v. Quote Share this post Link to post Share on other sites
