Rathion 0 Posted September 14, 2014 Hi. I'm Ian long time Corrado owner but recently acquired one of the more well known ones on this forum. James's VRT build L898 KVT. After nearly buying it when it was for sale the last time when it was still quite local to me, I waited too long and it went all the way down to Exeter. So me being me and doing things the hard way I went all the way to Exeter to bring it back! I drove it home (Aberdeenshire) from Exeter and it was fine for approx 550 miles. Then suddenly whilst driving along the revs just died straight to zero. Pulled over, car re-started straight off. Didn't miss a beat the rest of the journey home (over 100 miles). Went out to start car couple of days later. It started but cut out fairly quickly. Wouldn't really idle for any length of time at all and wouldn't really run even with throttle applied. It just died abruptly after varying amounts of time. Things appeared to improve after a little heat got into the car although I'm not sure if this was just coincidental or not. Anyway managed to drive it for 10 miles or so and it seemed ok. Next morning same thing, and the same again the day after that. Thought it was maybe a crank sensor or ignition switch problem so tried replacements. No change. Swapped out all relays. No change. So It's pretty much got me beat. I went poking around and had the fusebox hanging down and it seemed to run ok. Figured bingo bad connection in the back of the fusebox. Left it another day and tried again. Back to same problem. Seems to me like something is sending a "kill" message to the ECU. As when it dies it dies almost instantaneously, whether on throttle or not. Hopefully I'll get it running properly this week sometime. If anyone has any idea then I'm open to suggestion!. Anyway not to let a car that won't run hold me back I set about swapping the interior for a standard leather one I had on the way for my old Corrado that I was just starting to put back on the road (separate thread to come some day) Will update thread with pics soon and hopefully more goodies as soon as time and funds allow. Thanks for reading Ian Quote Share this post Link to post Share on other sites
20vtvw 0 Posted September 14, 2014 Glad this has stayed within the forum ,gutted for you tho that it's playing up already ,,the joy of vrt and corrados! Is this running on obd2 now? Could be immobiliser? Also mine did the same thing with a duff maf ,started and then cut out straight away , Hope you sort it soon,good luck. Quote Share this post Link to post Share on other sites
Rathion 0 Posted September 14, 2014 Thanks. As far as I'm aware it runs OBD2 with custom C2 Motorsport software and the immobiliser has been deleted. Going to make it slightly harder to diagnose I think though as it's a custom build. Probably something simple that I've overlooked. Looking forward to it though as it was brilliant on the drive home. Quote Share this post Link to post Share on other sites
clumpy1 11 Posted September 14, 2014 Thanks. As far as I'm aware it runs OBD2 with custom C2 Motorsport software and the immobiliser has been deleted. Going to make it slightly harder to diagnose I think though as it's a custom build. Probably something simple that I've overlooked. Looking forward to it though as it was brilliant on the drive home. Not looking to dampen your high spirit's but I was exactly the same with mine after the drive home and having a play with an Audi R8 then the sensible what's going on kick's in after a couple of issue's and having to end up getting it re mapped. I really hope you get a quick and easy fix to this mate. Quote Share this post Link to post Share on other sites
Rathion 0 Posted September 14, 2014 Cheers clumpy. I know what these things are like. It's most likely to be a very frustrating car but hopefully always worth it in the long run. I've read all the threads about it on here and all 3 owners seemed to have a love/hate relationship with it. Hopefully i can stick it out for a while yet. Quote Share this post Link to post Share on other sites
clumpy1 11 Posted September 14, 2014 Good luck matey I've Had a couple of issue's with mine I'm not saying it is the case with your car but it seem's issue's/prob's get passed on alot probably alot due to cost and recouping cost's when coming to sell. Way of the world these day's unfortunately. Quote Share this post Link to post Share on other sites
Roger Chatfield 0 Posted September 14, 2014 Nice car, I had a look around this when Gareth had it, hopefully you'll get the little problems sorted out. Rog. Quote Share this post Link to post Share on other sites
Sean_Jaymo 0 Posted September 14, 2014 Nice car. One of my favourite. Have you had the chance to scan it for faults? Maybe a few hundred quid spent with a reputable auto electrician might be well spent to diagnose any current or potential problems. But as before, lovely car. Quote Share this post Link to post Share on other sites
Rathion 0 Posted September 14, 2014 My buddy is an RAC patrol so he's coming out this week to scan it for me. It's not getting me down....yet! Quote Share this post Link to post Share on other sites
clumpy1 11 Posted September 14, 2014 Keep it up buddy for sure lnhappen mate . Quote Share this post Link to post Share on other sites
coullstar 0 Posted September 14, 2014 Ian, I've got full Vagcom if you need it done. Would be good to see the car again as well. Not sure on the running issues, never happened with me. I did have an issue once with an inline fuse connection that was under the rear seats driver side. Work checking. That. Quote Share this post Link to post Share on other sites
Rathion 0 Posted September 14, 2014 Cheers Graeme. I'll see how this week goes and if I'm struggling I'll maybe give the Vag-com a go. I'll def pop past with it soon though either way. I think it's linked to the intermittent problem Gareth had. Will suss it one way or another. Wish it would just not start all together though as it would be much easier to diagnose. Quote Share this post Link to post Share on other sites
coullstar 0 Posted September 14, 2014 Oh yeah check the Vagcom connections the two prong type. Quote Share this post Link to post Share on other sites
Rathion 0 Posted September 16, 2014 First chance to try and fix it tonight and result!! A chip (I suspect the C2 motor sports chip) inside the ECU was slightly dislodged. Luckily car wasn't starting at all and not speaking to scanner so we went straight to ECU to check for power and when we moved it things sparked into life. Got it started and could make it cutout just by tapping ECU. Stripped it down and there's a large chip inside but it looks like it's on an adapter plate thing. Tapped it and it seated properly. Seems fine now. Very happy chappy. Quote Share this post Link to post Share on other sites
Rathion 0 Posted September 16, 2014 As mentioned before I managed to get hold of a leather interior for it and fitted it last week. Few before and after pics. Gareths seats, Nice, and perfect for the ahem thinner gentleman! Standard rears and door cards New leather all round. Still using the cloth armrest at the moment as most will know it's a custom job as the battery lives there. Still to decide how to proceed here. Thanks for looking, Lots more to come I hope. Quote Share this post Link to post Share on other sites
sexybourbon 0 Posted September 16, 2014 Good news on the chip , nice easy fix , it doesn't happen often so you gotta remember the times it does lol Quote Share this post Link to post Share on other sites
VR6 Gar 10 Posted September 17, 2014 Great result Ian, recon it must have been the pot hole I hit back in December that dislodged it. Random how it fixed itself for 7 months but as you said that is Corrados for you. Looking good with the leather, I was planning the same and was going to remove the leather from an armrest and fit it over the cloth then bond with tigerseal or similar. Shame the Konigs are a bit snug for you but I am sure someone on here would snap them up. Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted September 17, 2014 If it cuts out again, check for a dry joint on the decryptor board that C2 will have soldered onto ECU motherboard. It's the 44 pin chip socket. Quote Share this post Link to post Share on other sites
MarkFoster 0 Posted September 17, 2014 If it cuts out again, check for a dry joint on the decryptor board that C2 will have soldered onto ECU motherboard. It's the 44 pin chip socket. ....How do you know these things?! Lol :) Quote Share this post Link to post Share on other sites
Rathion 0 Posted September 18, 2014 Cheers Kevin. I'll keep that in mind. Chip was definitely not seated properly though so hopefully thats that. At least for the moment. Quote Share this post Link to post Share on other sites
Jmccall85 10 Posted September 19, 2014 Mind seeing this on Scottish vag while back very nice car Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted September 20, 2014 ....How do you know these things?! Lol :) Experience mate, oh the bitter, bitter experience :D Quote Share this post Link to post Share on other sites
GrahamU 5 Posted September 20, 2014 If it managed to dislodge once then it could easily do it again, might be an idea to tie the chip in, some cotton will do it, just thread it under the chip carrier and over the top of the chip. Tieing in chips used to be common practice when in a carrier before surface mount components became common place A small blob of nail varnish on the knot will ensure it doesnt come out again Remember to ground yourself when opening an ECU just in case of static Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted September 20, 2014 Good idea. Or maybe a pea sized blob of butyl to hold the chip down. When I had my OBD2 rechipped, I had issues with poor quality chip holders and dry joints. The only time my Corrado broke down in 9 years was because of a dry joint on a rechip! Quote Share this post Link to post Share on other sites
GrahamU 5 Posted September 20, 2014 Unfortunately alot of these tuners have never been taught how to solder properly I had an APR chip on my Bora that was absolutly awful Quote Share this post Link to post Share on other sites
