robrado974 1 Posted November 20, 2014 (edited) I thought I'd solved this , but after the heavy rain we've had it's wet by the door again . Am I right in thinking if it was the foliage or the sunroof tube the glove box would be wet and the sunroof panel if it was the tube ? . I will have to check the membrane again . It's right on the lip of the carpet where the door shuts and going into the middle . I will get it sorted on Sunday . Kind regards Rob Edited December 21, 2014 by robrado974 Quote Share this post Link to post Share on other sites
diarmaid16 1 Posted November 20, 2014 Not too sure about the first two options Rob but would make sure the membrane is sealed properly first. Had leaks twice before and new membrane sorted both of them. Quote Share this post Link to post Share on other sites
Ray1965 10 Posted November 20, 2014 (edited) Rob what seal did you use . i did mine and used silicon first and it was a big fail. I got some of this and has done the job spot on, the flexi stuff and can be pulled off and re-stuck its what the manufacture uses when new i believe. http://www.ebay.co.uk/itm/221224948406?_trksid=p2060778.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT Edited November 20, 2014 by Ray1965 Quote Share this post Link to post Share on other sites
carrots 1 Posted November 20, 2014 i used duck tape on mine the proper stuff costs a bit more but it sticks beter Quote Share this post Link to post Share on other sites
robrado974 1 Posted November 20, 2014 I used duct tape too , I will have to check it again . I'm sure it's coming through there . If it was foliage it would be around where the passenger feet would be and in the glove box and shelf . If it was the tube the panel would be wet and the seat too . Thanks for the replies gents . Quote Share this post Link to post Share on other sites
seanl82 23 Posted November 20, 2014 Yeah your first post seems correct Rob. I'd bank on it being the door membranes too. I used Tiger seal on mine which worked well, but tbh its not pretty and I wish I'd used something else. That butyl tape would probably be much better. Quote Share this post Link to post Share on other sites
carrots 1 Posted November 20, 2014 yer that butyl tape looks good for money,i had extra holes so the tape sorted them Quote Share this post Link to post Share on other sites
robrado974 1 Posted November 20, 2014 Just looked at the link ray and Sean . I use that stuff at work all the time lol . I've got loads of it . Quote Share this post Link to post Share on other sites
seanl82 23 Posted November 20, 2014 Nice cheap fix then mate! :thumbleft: Quote Share this post Link to post Share on other sites
fla 9 Posted November 20, 2014 its a nightmare Rob, i dont envy you this. I also used the butyl tape but i have made up separate strips to cover the holes in the door rather than one big piece over it. Put some newspaper around the doorframe in the inner seal, but away from the outside. Close the door from inside so you know that the paper is correctly placed. Use a hosepipe and then examine the paper from the other door. Hopefully you'll be able to identify it from there. If its not leaking from there at least it will eliminate the frame seal as a source. I've put some neoprene tape around my door frame as it was leaking from the top. Doesn't look nice but its better than a leaking door! Also, if possible try it with the car pointing both uphill and downhill. Quote Share this post Link to post Share on other sites
robrado974 1 Posted November 20, 2014 Thanks for the info Hasan , I will do this first , good idea . I was going to pull up the carpet and sprinkle talc on the floor , but your idea will be quicker . Quote Share this post Link to post Share on other sites
8vMatt 1 Posted November 20, 2014 Oh bloody troubles Rob! You sure it's the membrane leaking? When I had mine, it didn't have any plastic sheet behind the doorcards. It was also dry. What about leaking door rubbers? Is it in that location? Hope you sort it quick. Quote Share this post Link to post Share on other sites
robrado974 1 Posted November 20, 2014 It's towards the front more than the back Matt . About 3/4 of the way along . Quote Share this post Link to post Share on other sites
robrado974 1 Posted November 22, 2014 Well I can see where it's leaking in . First of all I noticed the tiny rubber seal on the plastic triangle on the exterior was squashed inside the triangle . This was pushing the corner below the wing mirror out . So I sorted that . Then I checked the membrane , there was dribbles of Water coming out of the bottom . So I re sealed it and it still leaks ! . I'm off to purchase some more tomorrow and try again . Quote Share this post Link to post Share on other sites
8vMatt 1 Posted November 22, 2014 How can it be so important to have the plastic membrane on the doors when mine had nothing and the doorcards were always bone dry? Quote Share this post Link to post Share on other sites
Sean_Jaymo 0 Posted November 23, 2014 You must have some good wiper seals on yours. Most people's are in a very tired condition after nearly 20 years. Quote Share this post Link to post Share on other sites
GrahamU 6 Posted November 23, 2014 Rob what seal did you use . i did mine and used silicon first and it was a big fail. I got some of this and has done the job spot on, the flexi stuff and can be pulled off and re-stuck its what the manufacture uses when new i believe. http://www.ebay.co.uk/itm/221224948406?_trksid=p2060778.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT That looks quite close to the proper VW stuff This is what I'll be using for alot of the sealing on mine, its amazing stuff for sealing and for holding bits in place and stopping squeaks and rattles VW part number is AKD-497-010-04-R10 Quote Share this post Link to post Share on other sites
robrado974 1 Posted December 21, 2014 Yep thats virtualy the same stuff i use at work and what i used to do mine . I returned to the car on saterday to find a round shaped mist on the passenger side of the windscreen . Sure enough its leaking again !! . I will have a look over the xmas period . I sealed this nice n tight , i cant understand why ive got water coming in again . Quote Share this post Link to post Share on other sites
carrots 1 Posted December 22, 2014 I think mines still letting a little bit of water in somewhere,I've not got a screw holding the plastic triangle in supper that don't help Quote Share this post Link to post Share on other sites
robrado974 1 Posted December 22, 2014 Make sure you have the metal lug for the triangle as well Carrots . Quote Share this post Link to post Share on other sites
carrots 1 Posted December 22, 2014 Don't think I have I lost one screw because threads are worn in triangle Quote Share this post Link to post Share on other sites
Shep___ 10 Posted January 3, 2015 I've got a very wet rear passenger side carpet, but only in the footwell itself. The carpet around the door and seat is dry, as is the front. I can't see how it is getting down there, when everything above is dry... has anyone got any ideas? It is usually parked facing uphill. Quote Share this post Link to post Share on other sites
robrado974 1 Posted January 3, 2015 I would check the foliage panel Shep , usually parked up hill ?, that would be my first port of call . Quote Share this post Link to post Share on other sites
fla 9 Posted January 3, 2015 Could be the door seal. Water will find the entry point and run over the sill and into the back. Put some newspaper between the door and the seal and also on the inner sill. Close the door on the paper and hose down from the outside. You'll see immediately the exact point of entry. Quote Share this post Link to post Share on other sites
Shep___ 10 Posted January 4, 2015 Thanks for the replies! The Scuttle panel over the foliage cover was out of place so *seems* like an easy fix.. I have replaced it after a clean up. It's amazing how much crap was around the rubber seals. Now to dry it off and see.. Quote Share this post Link to post Share on other sites
