fla 9 Posted December 22, 2014 (edited) Just replaced the cigarette lighter socket with a usb charging socket (acknowledgement to KipVR) However, the two leads to the socket are a continuous live rather than a switched live. I've also linked the heater panel inverter to this so its constantly on. Could anyone suggest a switched live for both the usb and centre panel lighting? Thanks Edited January 15, 2015 by fla Quote Share this post Link to post Share on other sites
swiftkid 1 Posted December 22, 2014 Has the USB got a light or something that will drain power? I would have thought you would just use the existing live to the heater control light for the inverter or did you want the light on constantly? Quote Share this post Link to post Share on other sites
fla 9 Posted December 22, 2014 Yes the led on the usb port is constantly on. Sorry my post is a bit confusing - these are two separate issues. I guess teh illumination is easy to solve, like you say i'll connect to the heater panel lighting. I'll put an ammeter between the power and the usb to see the current drain. If its just for the led it'll be mA so not an issue i guess.If its 10s of mA then i'll have to reroute the power source. Quote Share this post Link to post Share on other sites
Tigerfish 10 Posted December 22, 2014 The switched 12v for the radio shouldn't be far away from the cigarette lighter. Quote Share this post Link to post Share on other sites
Jon_vr6 1 Posted December 22, 2014 Use the ashtray light for the illumination power Quote Share this post Link to post Share on other sites
davidwort 0 Posted December 23, 2014 I'm confused, why not just use one of these? [ATTACH=CONFIG]80368[/ATTACH] http://www.amazon.co.uk/NoveltyThunder-Cigarette-Lighter-Charger-Generation/dp/B00I1OII7Y/ref=sr_1_16?ie=UTF8&qid=1419323876&sr=8-16&keywords=in+car+usb+socket Quote Share this post Link to post Share on other sites
seanl82 23 Posted December 23, 2014 ^ This is what I use. Runs the satnav and charges the phone when required. Maybe not as neat as having a dedicated one hidden somewhere, but easily removed when not in use. Quote Share this post Link to post Share on other sites
fla 9 Posted December 23, 2014 Its more cosmetic I guess. Kips solution is very flush and looks OEM. I also used a plug in USB before but thought that this would be a good updated alternative. Quote Share this post Link to post Share on other sites
fla 9 Posted December 23, 2014 The switched 12v for the radio shouldn't be far away from the cigarette lighter. So you can swop the yellow here for the brown to the USB? Thanks Quote Share this post Link to post Share on other sites
Dox 23 Posted December 23, 2014 If you delete the cig lighter socket what if you need to use a tyre inflator or similar? Would the USB sockets fit in a switch blank? Quote Share this post Link to post Share on other sites
coullstar 0 Posted December 23, 2014 Get a foot pump then. Quote Share this post Link to post Share on other sites
davidwort 0 Posted December 23, 2014 travel kettle, mini-fridge and and car vac? I need mine for lighting my montecristos Quote Share this post Link to post Share on other sites
Dox 23 Posted December 23, 2014 Get a foot pump then. http://www.ebay.co.uk/itm/Wind-up-USB-Power-Charger-for-DV-Mobile-Phone-Mp4-Generator-Handle-Pocket-Size-/310839111444?pt=UK_MobilePhones_MobilePhoneAccessories_MobilePhoneChargers&hash=item485f746f14 Quote Share this post Link to post Share on other sites
fla 9 Posted December 23, 2014 :) I've got an extension socket wired in, just trying to work out a good location. There's also the voltmeter there which i had wired to the cig socket but will be re-routed to perhaps the glovebox light or other low current switched circuit. Quote Share this post Link to post Share on other sites
Stonejag 10 Posted December 24, 2014 The other reason not to use an adapter is that the socket is quite a loose fit and they keep falling out - at least on my car. Been considering doing this for a while - didn't know it'd been done already! Will have to have a look around. Stone Quote Share this post Link to post Share on other sites
Jamie 1 Posted December 24, 2014 When I get around to it I'm going to convert the coin holders in front of the gear lever to USB sockets Quote Share this post Link to post Share on other sites
Sean_Jaymo 0 Posted December 24, 2014 Is there enough space to do that? I've never looked but the diagnostics plug is under there. Quote Share this post Link to post Share on other sites
Jamie 1 Posted December 24, 2014 Yeah plenty of room. I don't have a diagnostic socket but even if there was, I reckon there'd be space Quote Share this post Link to post Share on other sites
fla 9 Posted December 25, 2014 The other reason not to use an adapter is that the socket is quite a loose fit and they keep falling out - at least on my car. Been considering doing this for a while - didn't know it'd been done already! Will have to have a look around. Stone I thought mine was the only one that was like this! Hugely annoying - plugs would fall out all the time! Quote Share this post Link to post Share on other sites
seanl82 23 Posted December 25, 2014 My holder kept falling out. I drilled a small hole in the bracket bit that sits behind the ashtray and put a small interior screw in it to secure. Can't see the additional screw as that's hidden behind the ashtray case too. Quote Share this post Link to post Share on other sites
fla 9 Posted January 6, 2015 well the additional socket (fitted in the passenger side under dash) will take its power from the feed to the crossover. Will this affect the performance of the audio at all and is this a safe source? I cant see this one being used much but its there just in case. Quote Share this post Link to post Share on other sites
Sean_Jaymo 0 Posted January 6, 2015 Why not take it from the glove box light? Definitely no issues with audio then. But then USB takes such a tiny current that I'm sure only the best ears would pick that out in a Corrado. Quote Share this post Link to post Share on other sites
fla 9 Posted January 6, 2015 Thanks sean. I'll take the power for the voltmeter from there but the charging socket is rated at 2 amps so perhaps the glove box wiring may be undersized for that. What do you think? Quote Share this post Link to post Share on other sites
Sean_Jaymo 0 Posted January 6, 2015 (edited) 2 amps at 12v is pretty much nothing really. That wiring will be fine unless you are running motors or heaters from your USB. I think USB works at 5v as well so even less of a draw. Edited January 6, 2015 by Sean_Jaymo Quote Share this post Link to post Share on other sites
Sean_Jaymo 0 Posted January 6, 2015 A quick Google comes up with this; A device may draw a maximum of 5 unit loads (500*mA) from a port in USB 2.0; 6 (900 mA) in USB 3.0. As power is equal to current times voltage, all you have to do is multiply*5V*per the current your device is drawing from the port. This is true, however, for the regular USB standard. Quote Share this post Link to post Share on other sites
