TanVr6 0 Posted April 21, 2015 Hi guys! Beautiful weather now for cruising in the C! Only problem is my rear tyres are getting shredded by the arches catching the edge of tyres with normal driving with only me in the car (13stone) They are 215/40/17 on the rear 205/40/17 fronts Fk coilovers fitted before me (over 6 yrs ago) Bbs Rs rims. Quote Share this post Link to post Share on other sites
MZpog 10 Posted April 21, 2015 I your not running a staggered setup, then I'd swap your wheels from front to back to see if the 205 fit better (I had no rubbing issues with 205/40/17's). Quote Share this post Link to post Share on other sites
fla 9 Posted April 21, 2015 There is a portion at the bottom of the arch towards the front of the car that catches the tyres - i've tried to get this rolled by Archenemy but they said it couldnt be done. I believe this needs to be either removed or the arches pulled, or indeed use 205 tyres on the rear. That will give a stretch which is not really for me, tbh. Quote Share this post Link to post Share on other sites
Wullie 1 Posted April 21, 2015 Use wheels that fit??? :scratch: Quote Share this post Link to post Share on other sites
MZpog 10 Posted April 21, 2015 Use wheels that fit??? :scratch: :thumbleft: Quote Share this post Link to post Share on other sites
bristolbaron 11 Posted April 21, 2015 The simple answers are: Raise car height. Bring wheels further in. Fit narrower tyres. Roll/flare arches. Which option or combination of options you do is up to you and depends on what 'look' you want from the car. Quote Share this post Link to post Share on other sites
TanVr6 0 Posted April 21, 2015 (edited) Well I don't want it to be too high. (Plus the suspension at the moment is a little bouncy) Rollin arches sounds good but don't want it to modify the outside appearance I'm being told different things from garages who have looked at it. Saying paint might crack!?! Arches will flare slightly?! Has anyone rolled their arches at the rear and got any experiences? Edited April 21, 2015 by TanVr6 Quote Share this post Link to post Share on other sites
TanVr6 0 Posted April 21, 2015 I think the cheapest option is to fit my old 205/40/17s With a stretch, and if still catching then adjust suspension or change to a better setup?!? Quote Share this post Link to post Share on other sites
sexybourbon 0 Posted April 21, 2015 Id get the arch lips rolled flat for a start , there is a difference between tolling them flat and flaring them You could always take the disk off the rear and get a machine shop to take 3mm or so of the mounting face , this would help bring the wheel in With all that and maybe using the other tyres you should be ok If its not id just change set up as if its rubbing with just you in it then it mist be quite bad pkus look at the state of your tyres , i wouldnt want to be going quick on those tyres Quote Share this post Link to post Share on other sites
TanVr6 0 Posted April 21, 2015 Any trustworthy places in the midlands I can go to for rolling the arches guys? Quote Share this post Link to post Share on other sites
Supercharged 2 Posted April 21, 2015 Those tyres aren't that wide - must be the wheel offset that's wrong... Quote Share this post Link to post Share on other sites
Supercharged 2 Posted April 21, 2015 ... Yep looking at the first pic the car would fail an MOT with wheels sticking out further than the arches! ET must be under 20 Quote Share this post Link to post Share on other sites
subcool 0 Posted April 21, 2015 You need 35 tyre profile with 215's shouldn't rub! Quote Share this post Link to post Share on other sites
Wayne2015 10 Posted April 21, 2015 When I bought my C, It was the same 205/40R17, On low coilovers, With 2.5cm spacers! :eek: Got garage to remove spacers Increase height (not too high and not too low) Can now go over speed bumps and bumpy roads without a scrape! :dance: Think it still looks good :thumbleft: ;) Quote Share this post Link to post Share on other sites
zak 0 Posted April 21, 2015 What's the wheel offset and size? Quote Share this post Link to post Share on other sites
TanVr6 0 Posted April 22, 2015 I have another old winter set just for getting through mot. But these summer wheels are what makes my C special and part of the family! Quote Share this post Link to post Share on other sites
TanVr6 0 Posted April 22, 2015 I bought them off a guy from here I'm hoping he replies and answer the question to offset? They are 17" 5x100 The dishes at the back have been changed from the original to 0.5" stainless steel polished from Dave in London (just Matz) Quote Share this post Link to post Share on other sites
TanVr6 0 Posted April 22, 2015 You need 35 tyre profile with 215's shouldn't rub! I got some 35 profiles, I will get them fitted today with some luck, however I think they will still rub n shred the rubber as the suspension is either too low or bounces to much as the fk setup is softer than most. But will try anyway!!!! Argh!!!!!! You have to love em n hate em! Quote Share this post Link to post Share on other sites
Wayne2015 10 Posted April 22, 2015 I have another old winter set just for getting through mot. But these summer wheels are what makes my C special and part of the family! Deffo :thumbleft: U and i on same page! ;) Quote Share this post Link to post Share on other sites
Yandards 0 Posted April 22, 2015 I don't know who is doing the MOT tests on your car but they need their license removing as that's just plain dangerous. Hopefully you can get it sorted without too much hassle but you run the risk of a high speed tyre failure which may result in you killing someone driving around like that. Quote Share this post Link to post Share on other sites
Wayne2015 10 Posted April 22, 2015 I bought them off a guy from here I'm hoping he replies and answer the question to offset? They are 17" 5x100 The dishes at the back have been changed from the original to 0.5" stainless steel polished from Dave in London (just Matz) Is there nothing stamped on back of wheels to state offsets? Quote Share this post Link to post Share on other sites
Dox 23 Posted April 22, 2015 Does it matter what the figure is? currently there's too much poke, its either adjust the arches, fit a narrower axle (if avaiable) or get the wheel centres machined to reduce said poke. I presume there's no spacers fitted? A pic of a G60 rear axle, stub axle flange to stub axle flange, narrower than a VR6 axle? Quote Share this post Link to post Share on other sites
Wayne2015 10 Posted April 22, 2015 I don't know who is doing the MOT tests on your car but they need their license removing as that's just plain dangerous. Hopefully you can get it sorted without too much hassle but you run the risk of a high speed tyre failure which may result in you killing someone driving around like that. U got a point! Tan! Make sure your summer wheels are legal 1st!!! :eek: Quote Share this post Link to post Share on other sites
TanVr6 0 Posted April 22, 2015 I don't know who is doing the MOT tests on your car but they need their license removing as that's just plain dangerous. Hopefully you can get it sorted without too much hassle but you run the risk of a high speed tyre failure which may result in you killing someone driving around like that. Thanks for the information. What if I run a stretched tyre, would that be dangerous? They don't stick out much, just slightly. Quote Share this post Link to post Share on other sites
mic_VR 3 Posted April 22, 2015 Thanks for the information. What if I run a stretched tyre, would that be dangerous? They don't stick out much, just slightly. Don't think the stretch is the issue. I'm running 17x8's with a 205 tyre and it's completely fine even though it's a fair bit of stretch. It's the cutting done by the arch. One particularly big bump and it'll cut through. If you're worried about getting the arches pulled or rolled, you can always get a decent bodyshop to cut off the excess lip and reseal the arch. That's what I've got on mine. I'll get a pic for you later if I get chance. Quote Share this post Link to post Share on other sites
