graham1971 10 Posted May 11, 2016 Been trying for nearly 2 years to find a tidy gear shift surround trim panel for a '93 VR6 auto. Any ideas? Quote Share this post Link to post Share on other sites
easypops 8 Posted May 11, 2016 I have one here , it's in good condition but it has a hole where an alarm led was fitted Quote Share this post Link to post Share on other sites
graham1971 10 Posted May 12, 2016 Thanks for that but it's a late model VR6 Auto, its a different shape to that one and has no sport/eco switch. Looks like the one in a MK3 Golf but it's a slightly different size. Quote Share this post Link to post Share on other sites
easypops 8 Posted May 12, 2016 No worries mate, I wasn't sure if it was early or late :) Quote Share this post Link to post Share on other sites
Jim 1 Posted May 12, 2016 Annoyingly VW Classic Parts list these, but seemingly only for the style with the switch as well - the same as what easypops has. Quote Share this post Link to post Share on other sites
ed_d82 11 Posted May 12, 2016 Hi, don't mean to bomb your post but do you mean the entire unit or the piece plastic which displays the gear selection? If so, that's what I need too... I.e. not the entire surround but the piece which displays the gears (P/R/N/1/2/)... something has dropped on mine and knocked a small hope where 2nd gear is displayed. If anyone knows how to repair/replace would be interested to know! Quote Share this post Link to post Share on other sites
graham1971 10 Posted May 13, 2016 I just need the same bit as you really, mine has a crap repair by a previous owner. Anyone have a 3D printer? Quote Share this post Link to post Share on other sites
ed_d82 11 Posted May 14, 2016 I was looking at getting a vinyl sticker printed but should the gear selection illuminate? Mine doesn't currently but wondering whether it should and hence whether I need to get the vinyl sticker to be transparent. Quote Share this post Link to post Share on other sites
graham1971 10 Posted May 14, 2016 Mine still does illuminate so yes it should! Quote Share this post Link to post Share on other sites
fla 9 Posted May 14, 2016 there is s small bulb with a rigid green filter which provides illumination. I replaced mine with a red led which imho looked much nicer! Quote Share this post Link to post Share on other sites
ed_d82 11 Posted May 14, 2016 Seems I have more to do than just replacing the trim! how do you replace the bulb? Any help appreciated! Quote Share this post Link to post Share on other sites
SamG40 0 Posted May 19, 2016 I've got one in the garage but not sure if its off a golf so wouldn't fit a corrado. It has a crack in it anyway, I wanted it for the strip which I think is in good nick but could not work out how to get it off in one piece. I can get a picture if anyone is interested. Quote Share this post Link to post Share on other sites
graham1971 10 Posted May 20, 2016 I've tried a MK3 Golf one, it was the wrong size unfortunately and the number strip has different gaps so that can't be salvaged either! Quote Share this post Link to post Share on other sites
SamG40 0 Posted May 20, 2016 Have you tried heritage? Quote Share this post Link to post Share on other sites
graham1971 10 Posted May 20, 2016 Have you tried heritage? They only have the one for the early model like the one pictured above with the eco/sport switch. Quote Share this post Link to post Share on other sites
misterbeck 10 Posted October 30, 2016 Anyone had any luck with either repairing or sourcing one of these. I have been struggling with this for over a year. I don't need the entire surround but the piece which displays the gears (P/R/N/1/2/)... some of the numbers have cracks in the surface and so looking a bit tatty. Quote Share this post Link to post Share on other sites
spen 0 Posted October 30, 2016 I'm currently trying to source a printed vinyl type version as I've also been looking (with no luck) problem is the transparency for it to illuminate Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
robrado974 1 Posted October 30, 2016 Is the material that different to the material used , when people have changed the colour on the heater illumination?. Quote Share this post Link to post Share on other sites
spen 0 Posted October 31, 2016 Illumination is changed by the diffuser on the bulb inside, I think! Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
ed_d82 11 Posted November 20, 2016 Can anyone share what type of bulb is required for the auto box please? Keep struggling now it's winter and can't what gear to select! Quote Share this post Link to post Share on other sites
Stonejag 10 Posted November 28, 2016 The bulb is unfortunately a VW special - you can plug a standard bulb into the socket on the 'wrong' side (for LHD cars) but on the RHD version there's a small plastic cross piece that contains two wires with crimped-on contacts which are soldered to a small 12V bulb. I gave away my last spare but it's the same as automatic Mk3 Golfs so you may get lucky in a scrapyard. Worst-case you can solder a new bulb onto your adapter wires, although they do run hot and replacing it with an LED might be a better option. I did once dismantle a Mk3's shifter plate and scan it so I have a PDF of the correct font somewhere. Might be useful for someone to make a decal if you spaced it out correctly? Stone Quote Share this post Link to post Share on other sites
ed_d82 11 Posted December 3, 2016 Thanks Stone, useful information... I was thinking of speaking to an auto electrician and seeing whether they could do that for me, although the breakers yard is worth a shot. What type of LED do you think it would require? Any ideas? Thanks! Quote Share this post Link to post Share on other sites
fla 9 Posted December 3, 2016 I just used a 5mm red led with a resistor on mine when it was an auto, although it did have the clipol-on diffuser on top. Thats the easiest and simplest/ cheapest solution. Plus the light is nice and bright.so you can clearly see which gear you're selecting Quote Share this post Link to post Share on other sites
Red McGregor 10 Posted December 28, 2016 The LHD drive bulb can be made to fit - I did just this earlier in the year, it was surprisingly straightforward. I think I had to get the bulb from the USA if I recall correctly. Quote Share this post Link to post Share on other sites
