GrahamV 10 Posted January 16, 2018 (edited) SOLD see my other Parts for sale Thread Corrado VR6 original working and serviceable Used and New Parts - UPDATED- 19/9/18. Collection-North Staffordshire ST13 or post at cost using Royal Mail/parcel force £4 for small light packages to £17 for long heavier ones. Glass collection only. If collecting paid for parts, other items listed may come without charge to enthusiast for small charity donation on first come basis; Payment takes precedence over any request for further information, photos etc. Please request/reply on this thread and I will PM cost confirmation. Regards Graham V [ATTACH=CONFIG]94612[/ATTACH] [ATTACH=CONFIG]94621[/ATTACH] [ATTACH=CONFIG]92023[/ATTACH] [ATTACH=CONFIG]92248[/ATTACH] 1 Aerial OE look without spiral wired mast NEW £9.00 1 VR6 & Storm Rear die cast badge set Unused £20.00 pair 1 Radiator main fan motor assembly 3 stage,4 pin, 357 959 455L £20.00 RESERVED Rogerb 1 Radiator temp sensor £2.00 1 Coolant temp sensor 4 pin blue @£4.00 1 Oil pressure sensor £3.00 1 Heater Foliage fresh air mesh pollen filter plastic cover £5.00 20 Wheel bolts M12 x 1.5 NEW MK1, 4 bolt pattern £6.00 set 1 Exhaust silencer round, fits after CAT pattern part NEW £6.10 carriage on this is £13.90 1 set Lowering Springs, both Front & rear Eibach as NEW https://www.vwheritage.com/wc412e8513140-eibach-suspension-coil-spring-kit-25mm-lowered-vw-spare @£180 set inc carriage. Actual lowering from 1992 OE spec is more like 40mm-50mm front and rear 1 pair Front strut mounting top bush NEW OE (not vr) 357412329 @£40 pair 2 Suspension front turret top blank caps 1H0412359 £ 5.00 pair 1 Scuttle water tray seal rubber 535819521 @£5.00 1 RH Inner door drop glass felt scraper seal £10.00 Collect only for glass 1 RH Drop Glass Green film tint 535845022 NEW OE £50.00 1 LH Drop Glass Green tint 535845021A £10.00 2 RH Drop Glass Green tint 535845022A £10.00 1 Tailgate glass green tint 2 filaments need easy repair 535845501A £20.00 RESERVED RogerB 2 LH door bump protector strip NEW NOS MK1 535 853 515 2BC £15.00ea (MK1 slimmer, not so deep as VR6 onwards MK2) 1 RH rear 1/4 side moulding bump Protector black £15.00 1 RH wing side moulding bump protector black £6.00 1 Power steering pump 535145157 for refurbishment- current VW part no. 6N0145157X exact as Polo-(VW is £100 surcharge) £30.00 1 Indicator stalk no hazard cowl £5.00 1 LH Mirror Casing, black trim broken and no motor (fits TVR’s) £10.00 1 set Fanfare horns no bracket £10.00 1 Fuel flap rubber retainer wire £1.00 1 Gear box selector plastic remote guide £5.00 1 Gear box overhaul parts-1st syncro and others £15.00 set 1 Air box hose 100mm clip £2.00 2 Servo vac hose clips new £1.00 1 Door check strap foam £1.00 1 set Lifting bars- direct fit to bumper mounts for fully rotating a Corrado upside down on CJ Autos CT04 https://www.cjautos.eu/Standard_NBN_chassis_tilter_p/ct04.htm tilter rotisserie £110.00 - collect only 1 First aid box with few bits in & scissors, appears nicotine stained, £10.00 Edited September 24, 2018 by GrahamV Most items sold opened new thread Quote Share this post Link to post Share on other sites
robrado974 1 Posted January 16, 2018 Hi graham , are the MK2 parcel straps the same as a Corrado?, I had one snap on Saturday, I grabbed a spare from the shed and it’s shorter than the oem one . I will take them if they are the same Rob Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
culshaw 1 Posted January 16, 2018 I'll take the bonnet heated water jets and the rad top elbow please Quote Share this post Link to post Share on other sites
GrahamV 10 Posted January 16, 2018 Yes, as they came off my VR6 as a pair. The hole is a different shape, that’s all I will double check and PM you tomorrow all being well. Hi graham , are the MK2 parcel straps the same as a Corrado?, I had one snap on Saturday, I grabbed a spare from the shed and it’s shorter than the oem one . I will take them if they are the same Rob Quote Share this post Link to post Share on other sites
GrahamV 10 Posted January 16, 2018 Ok , will Confirm by PM I'll take the bonnet heated water jets and the rad top elbow please Quote Share this post Link to post Share on other sites
Guy 0 Posted January 16, 2018 Hi mate, if those rainwater protectors (trim from bottom of screen, right?) are free of cracks or damage I'll have all 3, please! Quote Share this post Link to post Share on other sites
GrahamV 10 Posted January 16, 2018 Yes, and all clips present and one is new NOS Will check and PM tomorrow all being well Hi mate, if those rainwater protectors (trim from bottom of screen, right?) are free of cracks or damage I'll have all 3, please! Quote Share this post Link to post Share on other sites
robrado974 1 Posted January 16, 2018 Yes, as they came off my VR6 as a pair. The hole is a different shape, that’s all I will double check and PM you tomorrow all being well. Thanks Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
gazvr6 10 Posted January 16, 2018 1LH & RH Door aperture seals good £15.00 pair 1 LH Inner door drop glass felt scraper seal £10.00 2 Door check strap foam seals £1.00 I'll take the above please Graham. Let me know postage costs and payment details please. Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
Cressa 37 Posted January 16, 2018 1 LH Outer door drop glass Slot scraper seal £15.00 If it is straight and flat, I'll take it please. Unfortunately on tappatalk I can't open the pictures Cressa Sent from my SM-G900F using Tapatalk Quote Share this post Link to post Share on other sites
GrahamV 10 Posted January 16, 2018 OK, Will PM tomorrow all being well 1LH & RH Door aperture seals good £15.00 pair 1 LH Inner door drop glass felt scraper seal £10.00 2 Door check strap foam seals £1.00 I'll take the above please Graham. Let me know postage costs and payment details please. Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
GrahamV 10 Posted January 16, 2018 Yes straight and flat Will PM tomorrow all being well 1 LH Outer door drop glass Slot scraper seal £15.00 If it is straight and flat, I'll take it please. Unfortunately on tappatalk I can't open the pictures Cressa Quote Share this post Link to post Share on other sites
gazvr6 10 Posted January 16, 2018 OK, Will PM tomorrow all being well Cheers Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
gazvr6 10 Posted January 17, 2018 Can i add the fuel filter clamp bracket to my order please Graham? Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
neil20vtc 0 Posted January 17, 2018 I'll take the door strikers please Sent from my SM-G935F using Tapatalk Quote Share this post Link to post Share on other sites
GrahamV 10 Posted January 17, 2018 Confirmed Will PM later 1 LH & RH Door aperture seals good £15.00 pair 1 LH Inner door drop glass felt scraper seal £10.00 2 Door check strap foam seals £1.00 1 Fuel Filter clamp bracket re finished £3.00 Can i add the fuel filter clamp bracket to my order please Graham? Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
GrahamV 10 Posted January 17, 2018 Confirmed Will PM later I'll take the door strikers please Quote Share this post Link to post Share on other sites
GrahamV 10 Posted January 17, 2018 All PM’s sent and goods packed awaiting further instructions Quote Share this post Link to post Share on other sites
robrado974 1 Posted January 17, 2018 Dough sent , thanks graham Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
Guy 0 Posted January 18, 2018 Yes, and all clips present and one is new NOS Will check and PM tomorrow all being well PayPal'd. Muchas gracias. Quote Share this post Link to post Share on other sites
Dazz_G60_Wales 0 Posted January 18, 2018 Hi Graham 1 x Bonnet insulation after market thick cut waffle pattern- unused £8.00 Is this still available and for the early bonnet. If so I will take it. Thanks Dazz Quote Share this post Link to post Share on other sites
GrahamV 10 Posted January 18, 2018 Sorry it’s for late bonnet. Hi Graham 1 x Bonnet insulation after market thick cut waffle pattern- unused £8.00 Is this still available and for the early bonnet. If so I will take it. Thanks Dazz Quote Share this post Link to post Share on other sites
Dazz_G60_Wales 0 Posted January 18, 2018 Sorry it’s for late bonnet.Bugger - ok cheers Gra Sent from my LG-D855 using Tapatalk Quote Share this post Link to post Share on other sites
GrahamV 10 Posted January 19, 2018 List updated All items not listed now allocated and despatched Quote Share this post Link to post Share on other sites
robrado974 1 Posted January 19, 2018 Nice one , thank you Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
