GrahamV
SOLD - VR6 1993 Surplus Parts
SOLD see my other Parts for sale Thread
Corrado VR6 original working and serviceable Used and New Parts - UPDATED- 19/9/18.
Collection-North Staffordshire ST13 or post at cost using Royal Mail/parcel force £4 for small light packages to £17 for long heavier ones.
Glass collection only.
If collecting paid for parts, other items listed may come without charge to enthusiast for small charity donation on first come basis; Payment takes precedence over any request for further information, photos etc.
Please request/reply on this thread and I will PM cost confirmation.
Regards Graham V
[ATTACH=CONFIG]94612[/ATTACH] [ATTACH=CONFIG]94621[/ATTACH]
[ATTACH=CONFIG]92023[/ATTACH] [ATTACH=CONFIG]92248[/ATTACH]
1 Aerial OE look without spiral wired mast NEW £9.00
1 VR6 & Storm Rear die cast badge set Unused £20.00 pair
1 Radiator main fan motor assembly 3 stage,4 pin, 357 959 455L £20.00 RESERVED Rogerb
1 Radiator temp sensor £2.00
1 Coolant temp sensor 4 pin blue @£4.00
1 Oil pressure sensor £3.00
1 Heater Foliage fresh air mesh pollen filter plastic cover £5.00
20 Wheel bolts M12 x 1.5 NEW MK1, 4 bolt pattern £6.00 set
1 Exhaust silencer round, fits after CAT pattern part NEW £6.10 carriage on this is £13.90
1 set Lowering Springs, both Front & rear Eibach as NEW https://www.vwheritage.com/wc412e8513140-eibach-suspension-coil-spring-kit-25mm-lowered-vw-spare
@£180 set inc carriage.
Actual lowering from 1992 OE spec is more like 40mm-50mm front and rear
1 pair Front strut mounting top bush NEW OE (not vr) 357412329 @£40 pair
2 Suspension front turret top blank caps 1H0412359 £ 5.00 pair
1 Scuttle water tray seal rubber 535819521 @£5.00
1 RH Inner door drop glass felt scraper seal £10.00
Collect only for glass
1 RH Drop Glass Green film tint 535845022 NEW OE £50.00
1 LH Drop Glass Green tint 535845021A £10.00
2 RH Drop Glass Green tint 535845022A £10.00
1 Tailgate glass green tint 2 filaments need easy repair 535845501A £20.00 RESERVED RogerB
2 LH door bump protector strip NEW NOS MK1 535 853 515 2BC £15.00ea (MK1 slimmer, not so deep as VR6 onwards MK2)
1 RH rear 1/4 side moulding bump Protector black £15.00
1 RH wing side moulding bump protector black £6.00
1 Power steering pump 535145157 for refurbishment- current VW part no. 6N0145157X exact as Polo-(VW is £100 surcharge) £30.00
1 Indicator stalk no hazard cowl £5.00
1 LH Mirror Casing, black trim broken and no motor (fits TVR’s) £10.00
1 set Fanfare horns no bracket £10.00
1 Fuel flap rubber retainer wire £1.00
1 Gear box selector plastic remote guide £5.00
1 Gear box overhaul parts-1st syncro and others £15.00 set
1 Air box hose 100mm clip £2.00
2 Servo vac hose clips new £1.00
1 Door check strap foam £1.00
1 set Lifting bars- direct fit to bumper mounts for fully rotating a Corrado upside down on CJ Autos CT04 https://www.cjautos.eu/Standard_NBN_chassis_tilter_p/ct04.htm
tilter rotisserie £110.00 - collect only
1 First aid box with few bits in & scissors, appears nicotine stained, £10.00
Edited by GrahamV
Most items sold opened new thread
Hi graham , are the MK2 parcel straps the same as a Corrado?, I had one snap on Saturday, I grabbed a spare from the shed and it’s shorter than the oem one . I will take them if they are the same
Rob
Yes, as they came off my VR6 as a pair.
The hole is a different shape, that’s all
I will double check and PM you tomorrow all being well.
Rob
Ok , will Confirm by PM
I'll take the bonnet heated water jets and the rad top elbow please
Hi mate, if those rainwater protectors (trim from bottom of screen, right?) are free of cracks or damage I'll have all 3, please!
Yes, and all clips present and one is new NOS
Will check and PM tomorrow all being well
Thanks
1LH & RH Door aperture seals good £15.00 pair
1 LH Inner door drop glass felt scraper seal £10.00
2 Door check strap foam seals £1.00
I'll take the above please Graham.
Let me know postage costs and payment details please.
1 LH Outer door drop glass Slot scraper seal £15.00
If it is straight and flat, I'll take it please. Unfortunately on tappatalk I can't open the pictures
Cressa
Sent from my SM-G900F using Tapatalk
OK,
Will PM tomorrow all being well
Yes straight and flat
Cressa
Can i add the fuel filter clamp bracket to my order please Graham?
Confirmed
Will PM later
1 LH & RH Door aperture seals good £15.00 pair
1 Fuel Filter clamp bracket re finished £3.00
PayPal'd. Muchas gracias.
Hi Graham
1 x Bonnet insulation after market thick cut waffle pattern- unused £8.00
Is this still available and for the early bonnet.
If so I will take it.
Thanks Dazz
Sorry it’s for late bonnet.
Hi Graham
Thanks Dazz
