k14rn 10 Posted July 28, 2019 Hi Looking for a radiator for VR6. any ideas where to buy one from? thanks. Quote Share this post Link to post Share on other sites
Cressa 45 Posted July 28, 2019 Hella replacement off of ebay. I paid less than £100 for mine last year, perfect fit and recommended Quote Share this post Link to post Share on other sites
tonedef 9 Posted July 28, 2019 I was looking a while ago, everyone currently out of stock and quoting September before they were expecting any in. I’m just running on the old leaking one a keeping an eye on coolant level for now. Quote Share this post Link to post Share on other sites
mooG60 11 Posted July 28, 2019 tonedef said: I was looking a while ago, everyone currently out of stock and quoting September before they were expecting any in. I’m just running on the old leaking one a keeping an eye on coolant level for now. It's the same story for the G60 and I have been running on a leaky rad since 2 weeks after getting the car. It's starting to get a bit irritating now to be fair. Quote Share this post Link to post Share on other sites
Corroda 11 Posted October 4, 2019 Anyone had any luck finding somewhere with OEM / Hella replacement radiator in stock for a VR6? Quote Share this post Link to post Share on other sites
Simeon 0 Posted October 4, 2019 Depending on where it's leaking, you may be better off getting it re-cored. Means your car will be off the road for a few days of course. Quote Share this post Link to post Share on other sites
Corroda 11 Posted October 4, 2019 Hi Simeon, thanks for the reply. I never thought or had any experience of re-coring the original. The radiator is not leaking yet, but has a bit of a bulge at the bottom, and I was looking to replace over the winter when I have the front end off the car, so there will be no problem having to wait a few weeks. Can anyone recommend somewhere? I will need to courier radiator back and forth as I live in the far north of Scotland, so no where is local 🤦🏻*♂️ Quote Share this post Link to post Share on other sites
vr6monkey 1 Posted October 4, 2019 Corroda said: Anyone had any luck finding somewhere with OEM / Hella replacement radiator in stock for a VR6? I believe the Hella radiators are now obsolete, I looked around and everywhere shows out of stock. I'm sure I also saw a post that someone had contacted Hella who confirmed they are no longer into coolant parts and no plans to make any more rads. Couple of us on CCGB FB have been considering get a price for a group buy for ali rads, but won't be cheap. Quote Share this post Link to post Share on other sites
Corroda 11 Posted October 5, 2019 I’d be happy to consider an aluminium radiator, but would like something that fits without modifying the car. The only radiators i’ve seen are for VR6 turbo conversion, and i’m not sure if they fit without modification. What are the pros and cons of the aluminium radiator over a re-core. Apologies if this has already been discussed to death on here. Quote Share this post Link to post Share on other sites
tonedef 9 Posted October 5, 2019 Potentially some available in December is the latest update I had. I’m SORNed now so it’s no longer affecting me but can see this causing issues for some. Quote Share this post Link to post Share on other sites
Corroda 11 Posted October 5, 2019 Hi tonedef. Are these from VW Heritage, or another supplier? Quote Share this post Link to post Share on other sites
Keyo 47 Posted October 5, 2019 (edited) Corroda said: I’d be happy to consider an aluminium radiator, but would like something that fits without modifying the car. The only radiators i’ve seen are for VR6 turbo conversion, and i’m not sure if they fit without modification. What are the pros and cons of the aluminium radiator over a re-core. Apologies if this has already been discussed to death on here. I have actually got one of these Alu radiators, however the last owner had it fitted a few months before I purchased the car so cant give links or advice on bracket fabrication, yes another thing that has been done to the Rado I'm selling ! It cools the car great to be honest and fits in there fine. The only thing that you have to mod is the brackets to house the radiator, they don't match the stock housing bracket points. I would post some pics on here to show you how it sits from looking above it in the Engine bay. The radiator trim piece fits on top of and it fits great under the slam panel. I have got the receipt of the mechanic who fitted it and he was Epsom way. Edited October 5, 2019 by Keyo Quote Share this post Link to post Share on other sites
Corroda 11 Posted October 5, 2019 Hi Keyo, thanks for that. I’m assuming yours is the GPI racing radiator? I don’t mind fabricating new lower brackets as long as hoses and cowl etc can remain stock, so photos would be helpful. I’m in no rush, so happy to weigh up the various options. Lovely motor by the way. If I hadn’t just bought one then I would have been very interested. GLWS. Quote Share this post Link to post Share on other sites
1xshaunx1 27 Posted October 5, 2019 I too have an aluminium radiator it’s an Arlows Racing one, I got it off EBay. The thing to watch out for is some don’t have different size inlet and outlet, the original has a larger bore bottom pipe connection. It was dearer but seemed better than the also European Woley radiator. Mine fits well to the bottom crossmember, however I did grind the little tabs off the back so the standard fan set up would fit once I’d dremeled the holes for the bolts for it as they were slightly off, same for the rad sender this fowled on the fan cowling so dremeled a bit off that there. Sealed the new rad sender with locatite 577. Done. That bit took 15 mins. Then made a couple of bracket to hold it to the slam panel when that was refitted. They took 1/2 hour messing about. The best thing about fitting one of these is that you haven’t got that plastic elbow thing just waiting to let go one day and it is better cooling. If you want some photos pm your email and I’ll send you some. Think it was 8 x m6 blots and washers and 2 strips of brass I cut off a bit of plate I had. Cheers Shaun Shaun Quote Share this post Link to post Share on other sites
nelik 10 Posted October 5, 2019 Maybe one of these will suit your needs. ebay radiator ebay radiator 2 Quote Share this post Link to post Share on other sites
Corroda 11 Posted October 5, 2019 Hi Nelik, well spotted. I’m just about to go on holiday, so will wait to order until I get back. Looks like I have a few options though: 1) wait to come in stock with Heritage, 2) buy standard radiator from eBay, 3) buy aluminium radiator from eBay, 4) add name to potential group buy. Thanks for all the help 👍 Quote Share this post Link to post Share on other sites
Jon_vr6 1 Posted October 5, 2019 (edited) Ive got one of the arlows radiators few slightly bent fins from storage but its brand new never fitted will put some pics up in a bit it has the important top radiator brackets already welded on and a couple of extra brackets as it was going to be for my old corrado which had slimline fans (these could be cut off if not needed. [url=https://ibb.co/t4kPR7w https://ibb.co/427cVBF https://ibb.co/n8x70hV https://ibb.co/PGCPzhH https://ibb.co/N1z6YvY https://ibb.co/x8Xdwfn]https://ibb.co/t4kPR7w https://ibb.co/427cVBF https://ibb.co/n8x70hV https://ibb.co/PGCPzhH https://ibb.co/N1z6YvY https://ibb.co/x8Xdwfn Cost me £212 excluding postage from netherlands and welding. So willing to sell it for £190 posted Edited October 5, 2019 by Jon_vr6 Quote Share this post Link to post Share on other sites
Keyo 47 Posted October 5, 2019 Corroda said: Hi Keyo, thanks for that. I’m assuming yours is the GPI racing radiator? I don’t mind fabricating new lower brackets as long as hoses and cowl etc can remain stock, so photos would be helpful. I’m in no rush, so happy to weigh up the various options. Lovely motor by the way. If I hadn’t just bought one then I would have been very interested. GLWS. Im not sure which radiator brand it is as the mechanic charged labour only on invoice and the seller didn't have the receipt for it. Shaun member on here has seen it and he might be able to tell you if mine is the same as his. Can't post pictures on here chap its a buggeror would of. I can say I went for a good drive in the Rado today and she was steady at good speeds at 88 degrees with the alloy radiator and of course you gain weight savings to the heavy nose of a VR6. Well worth checking if your grill has the three opening slits as well because mine dropped by 5 degrees running with that grill at least and that is been modest. Quote Share this post Link to post Share on other sites
Corroda 11 Posted October 5, 2019 Thanks guys. I’m swayed towards the alloy radiator. I have both the one slat, and three slat grilles, so hopefully I can get a combination that suits the frozen north 😂 Jon, I’ve sent you a PM. Quote Share this post Link to post Share on other sites
Corroda 11 Posted October 5, 2019 Thanks for all your help guys. I’ve now got a new radiator 👍 Quote Share this post Link to post Share on other sites
jarques2005 10 Posted October 13, 2019 How different are these to a 9A (16v) engine radiator? Quote Share this post Link to post Share on other sites
1xshaunx1 27 Posted October 13, 2019 The vr6 radiator is bigger and the slam panel is different. Quote Share this post Link to post Share on other sites
2elliot 0 Posted December 5, 2019 Corroda said: Thanks for all your help guys. I’ve now got a new radiator 👍 Which radiator did you go for and does it fit? Thanks Quote Share this post Link to post Share on other sites
Corroda 11 Posted December 8, 2019 It’s an Arlows alloy radiator that I bought off the forum. It looks good quality, but I have not got round to stripping down the front end of the car yet. I think a few people on here have fitted this radiator and may be able to provide feedback on how well it fits. Quote Share this post Link to post Share on other sites
Dunebug 10 Posted December 11, 2019 I’m also having problems finding a radiator for my vr6; I’m having problems sealing the radiator top flange. Found an ally one from a company called Worley on eBay, anyone had any experience with them ? Cheers Quote Share this post Link to post Share on other sites
