Motoriousss 10 Posted January 15, 2020 Hey everyone Looking to buy my first VR6: https://www.facebook.com/marketplace/item/389717998400288 However, not sure what to look out for on its underside as its my first "classic" Also its MOT history isn't encouraging. Please take a look and let me know! https://www.check-mot.service.gov.uk/ N646 OYU And finally does the engine sound normal? [video=youtube_share;JFNl0OOoYVk] Any help would be appreciated! Quote Share this post Link to post Share on other sites
Dox 28 Posted January 15, 2020 http://the-corrado.net/showthread.php?29449-Re-Corrado-storm-vr6 Pretty sure its this car, Jon still posts here so he can confirm it if he sees this post? The lad who bought the car from Jon wanted the private plate E 57ORM I think, the car went to a lad in Leeds then looks to have been sold on again Quote Share this post Link to post Share on other sites
Nmdsec 10 Posted January 15, 2020 Yes agree think this is Jon’s,chap who bought sold the gauges out of it also and then moved it on Quote Share this post Link to post Share on other sites
1xshaunx1 27 Posted January 15, 2020 Both ends of the sills having looked at the mot history, you have to remove the front wing to fix the front of the sills and not sure if you can still get the repair panel either. Also they’ve pulled blue smoke on acceleration which to me could be ovaling of piston bores, shot rings or valve stem seals or combination of them, head off. The vr6 is a bit noisy in general the chains can slap about if they or the tensioner is worn. Go through the receipt for the engine work and see what was replaced, if it wasn’t rebored it may need it now. Quote Share this post Link to post Share on other sites
Jon_vr6 1 Posted January 15, 2020 1xshaunx1 said: Both ends of the sills having looked at the mot history, you have to remove the front wing to fix the front of the sills and not sure if you can still get the repair panel either. Also they’ve pulled blue smoke on acceleration which to me could be ovaling of piston bores, shot rings or valve stem seals or combination of them, head off. The vr6 is a bit noisy in general the chains can slap about if they or the tensioner is worn. Go through the receipt for the engine work and see what was replaced, if it wasn’t rebored it may need it now. It was rear sills which were repaired for mot twice but rotted again 2 years later. Needs to be properly repaired and a full respray. Stealth rebuilt the engine with a rebored bottom end. 6k is a joke really but if that's what they are asking up to them I've washed my hands with it. Quote Share this post Link to post Share on other sites
MikeVR6 0 Posted January 22, 2020 Nearside Rear wheel bearing has slight play (2.6.2) Offside Rear wheel bearing has slight play (2.6.2) Nearly every MOT I've had this. The rear wheels have passive rear steering. They're supposed to have "play!" I'd walk away from that car at £6k. More like £2500 and that's only because it's a Storm. Quote Share this post Link to post Share on other sites
ger040 3 Posted January 23, 2020 (edited) walk away from that car 6k !!!- has money pit written all over it - much better cars out there check gumtree - vr6 in hillsborough northern ireland now reduced to £5500 - if i was in the market id be all over this Edited January 23, 2020 by ger040 Quote Share this post Link to post Share on other sites
fendervg 33 Posted January 23, 2020 MikeVR6 said: Nearside Rear wheel bearing has slight play (2.6.2) Offside Rear wheel bearing has slight play (2.6.2) Nearly every MOT I've had this. The rear wheels have passive rear steering. They're supposed to have "play!" I'd walk away from that car at £6k. More like £2500 and that's only because it's a Storm. It's not really "rear steering", that was just marketing speak - the rear beam axle has a slight amount of movement in it alright, but bearings shouldn't be so loose that they result in "passive steering" at the back. The wheel bearing thing is just because they are cup and cone integral to the disk and need to be adjusted from time to time to take any play out of them to allow for wear - most people (including me) forget, so hence why MOT/NCT testers will often comment on them as having excessive play. This is an outdated design, used on all the older VWs etc. and has been replaced by a more sensible cartridge bearing in newer models. So if you see this, it most often just means pack new grease in there and tighten, otherwise replace the bearings. Quote Share this post Link to post Share on other sites
MikeVR6 0 Posted January 23, 2020 (edited) ger040 said: walk away from that car 6k !!!- has money pit written all over it - much better cars out there check gumtree - vr6 in hillsborough northern ireland now reduced to £5500 - if i was in the market id be all over this Gumtree VR6 That's right on the money if it's as good as it looks. I've never seen a Rado with those Recaros before (needs a handbrake cover mind). You'd also get a wee trip to N.Iron and the beautiful Hillsborough (The Queen has her local residence there). Bring a raincoat, you're guaranteed rain. Ryanair/Easyjet over and Ferry from Belfast or Dublin back. I've done the reverse trip to buy almost every car I've owned. Less than £200 and a bit of an adventure and long drive home to get to know your new car. Quote It's not really "rear steering", that was just marketing speak - the rear beam axle has a slight amount of movement in it alright, but bearings shouldn't be so loose that they result in "passive steering" at the back. The wheel bearing thing is just because they are cup and cone integral to the disk and need to be adjusted from time to time to take any play out of them to allow for wear - most people (including me) forget, so hence why MOT/NCT testers will often comment on them as having excessive play. This is an outdated design, used on all the older VWs etc. and has been replaced by a more sensible cartridge bearing in newer models. So if you see this, it most often just means pack new grease in there and tighten, otherwise replace the bearings. Aha! Mystery solved. Ok, I'll get them greased up pronto. Thanks! :cheers: Edited January 23, 2020 by MikeVR6 Quote Share this post Link to post Share on other sites
Keyo 49 Posted January 23, 2020 Yeah the set of seats alone would probably fetch 1.3k plus. Quote Share this post Link to post Share on other sites
fendervg 33 Posted January 23, 2020 Yeah, that looks like it's worth a visit if it's as good as it sounds - good asking price too. Those seats are US/Canada spec "Red Dot" Recaros, am I wrong? Quote Share this post Link to post Share on other sites
Keyo 49 Posted January 23, 2020 MikeVR6 said: Are we talking about the Zender ones on the Storm? I'd happily take 1.3k from someone for those. They're sh1t3 lookin' Especially with the waaaay too low stance and stretched tyres. No the Stock option LHD Recaros - half leathers, possibly the only set on a RHD car in the world I imagine. I believe from seeing these seats in the past that they were a LHD euro option but maybe available in the North American market. Quote Share this post Link to post Share on other sites
MikeVR6 0 Posted January 23, 2020 For some reason I read "Seats" as "Wheels" :) Yeah the Recaros are worth a few bob for sure. But the wheels are an acquired taste and probably worth a few quid too. Not in keeping with a Storm IMO and definitely not with stretched tyres. Quote Share this post Link to post Share on other sites
MikeVR6 0 Posted January 23, 2020 fendervg said: Yeah, that looks like it's worth a visit if it's as good as it sounds - good asking price too. Those seats are US/Canada spec "Red Dot" Recaros, am I wrong? Worth a look for you. Folk in England won't drive any distance to buy a car. You gotta travel to get the good ones! Just get plenty of pics sent to you and ask the right questions before you set off. Quote Share this post Link to post Share on other sites
