fendervg 32 Posted May 11, 2020 (edited) These are all the bits I have collected so far - some are duplicates: Edited May 11, 2020 by fendervg Quote Share this post Link to post Share on other sites
Keyo 47 Posted May 11, 2020 (edited) 10 minutes ago, fendervg said: These are all the bits I have collected so far - some are duplicates: Good stuff mate, I spoke to Vince earlier and he agreed with you to for the billet ones , also agreed no need to change the cables which I'm happy about because of cost . What you want though mate is that clip on the bottom of the shaft and the tube but you cant get it, hopefully yours will be in good condition. Think you might have the bottom shaft clip furthest bag right top - where you get that from ? Edited May 11, 2020 by Keyo Quote Share this post Link to post Share on other sites
fendervg 32 Posted May 11, 2020 Think it came with this kit - rhat's where the clips came from anyway - if they are the right ones: https://www.ebay.ie/itm/VW-Corrado-Mk3-Golf-Jetta-vr6-Passat-02A-Shift-Cable-Bushing-Box-Rebuild-Kit/361824103274?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649 http://www.mk1autohaus.com/ Search functionality is a bit rubbish on the actual site. Quote Share this post Link to post Share on other sites
Keyo 47 Posted November 4, 2020 On 5/9/2020 at 10:06 PM, Keyo said: I don't think you can mate you cant get the tube or the end clip on the shaft they are obsolete unless you can find some links would be if good is you can- Considering it. Have come across this short shift kit from Germany and has the obsolete parts. https://www.tzr-motorsport.de/epages/61911476.sf/de_DE/?ObjectPath=/Shops/61911476/Products/0599[14] description Manufacturer: - GEMA Motorsport suitable for: - VW Corrado Bj. 1988 - 1995 - MKG: KR / 9A / PG / ABV Description: The shift path shortening is for VW cable manual gearbox (02A). The standard shift gate is disassembled and replaced by the new shift gate. The shortened shifting lever and another redirection shorten the shifting distance by 35%, since the Corrado already has a shorter shifting distance. The new shift unit has a thread for the shift knob of M12 x 1.5. Technical specifications: - 50% reduction in switching travel - M12 x 1.5 shift knob thread Assembly instructions: - no welding work on the bodywork necessary. - 1: 1 exchange for the series part. Scope of delivery: - 1x switching path shortening including assembly instructions Update don't buy this sits to high in a corrado to work smoothly- go for Dave short shift kit or 02J tower change- also a Mk 4 handbrake and gaiter is a nice mod will need a little modding to fit. . The short shift is advertised for a Corrado but the seller expects you to bend the ball housing down which is not happening on my car- seller told me in Germany on phone on all VR6 models they sit a little lower so work perfect but just Corrado sits higher )so why don't you put that on sale description ) hey ho !!! Quote Share this post Link to post Share on other sites
fla 9 Posted August 8, 2023 On 5/11/2020 at 10:28 AM, fendervg said: These are all the bits I have collected so far - some are duplicates: Fender? Could you advise where you got the bushings from at all please? Struggling to find them. Dont need the milled bracket spacers, just the nylon fittings. Thanks Quote Share this post Link to post Share on other sites
fendervg 32 Posted August 8, 2023 3 minutes ago, fla said: Fender? Could you advise where you got the bushings from at all please? Struggling to find them. Dont need the milled bracket spacers, just the nylon fittings. Thanks Let me take a look through my emails and I will check - I think a combination of dieslegeek and fleabay, but I will see if I can find some receipts. Quote Share this post Link to post Share on other sites
fendervg 32 Posted August 9, 2023 I bought these parts back in early 2020, so not everything might still be available. Most of the bits came from dieselgeek: 02A Cabin-Side Bushing Set for 1989-1999 cable shift Volkswagens $29.00 02A Plastic Cable Holder 1J0 711 256 $39.00 02A Super Slider for 1993-1999 VW $29.00 02A Shift Cable End Bushing Set for 1989 - 1999 MK3 and MK4 cars 1 $29.00 mk1autahaus_2003 (not longer online under that name) VW Corrado Mk3 Golf Jetta vr6 Passat 02A Shift Cable Bushing & Box Rebuild Kit $39.00Unit price $39.00 This last one includes the seals Quote Share this post Link to post Share on other sites
fla 9 Posted August 9, 2023 (edited) useful info, many thanks. Didnt realise they charge that much just for essentially machined plastic! Although the Autohaus one seems good value. I'll see if they're trading under a different name Edited August 9, 2023 by fla Quote Share this post Link to post Share on other sites
fendervg 32 Posted August 9, 2023 Yep, not cheap - kits for the Mk2 are cheap as chips, and you could even get a refurb/repair kit direct from VAG at one point. Quote Share this post Link to post Share on other sites
Dox 23 Posted August 9, 2023 https://www.mk1autohaus.com/ https://www.mk1autohaus.com/ you missed the O out, auto haus Quote Share this post Link to post Share on other sites
fendervg 32 Posted August 9, 2023 Just now, Dox said: https://www.mk1autohaus.com/ https://www.mk1autohaus.com/ you missed the O out, auto haus Good spot. Hopefully this helps someone. Quote Share this post Link to post Share on other sites
Dox 23 Posted August 9, 2023 Just now, fendervg said: Good spot. Hopefully this helps someone. It helps me, never heard of them 😆 👍 Quote Share this post Link to post Share on other sites
fendervg 32 Posted August 9, 2023 hah! not sure if they still sell on eBay. but at least the web site is there. Quote Share this post Link to post Share on other sites
