Keyo 47 Posted December 12, 2020 So my car is in the body shop for some winter loving. Bonnet off plus front and rear bumpers spray paint (stone chips) + all new bumpers irons brackets, clips and bolts. To my horror got a call off the body shop and said you need a new radiator. Picture below of these chinesium alloy radiator (it was the only off the shelf option at the time 3 years ago- Im not one to cheap out on parts. ) All these alloy rads look the same but have different branding on the graphics of advert. You can see the frame has failed and bowed at the bottom and also leaking. Im hoping this radiator from German company Dasis which is OE fitment is better then the alloy one. Pictures below - I was thinking about getting an alloy neck fitting but decided to go with a vag one as im sure I have seen mixed reviews on the billet ones ? Let me fit the Dasis radiator and I will give a review of fitment at least. Can get one from Autodoc for £100 or an English seller that delivers next day for £120.00. https://www.dasis.de/en/ Quote Share this post Link to post Share on other sites
seanl82 23 Posted December 12, 2020 That's shocking, even for aftermarket on the alloy rad. Hella rads were the recommended when I replaced mine in 2014. Still looks like new now - though I've only put about 2k miles on the car since then tbf. Quote Share this post Link to post Share on other sites
Keyo 47 Posted December 12, 2020 (edited) On 12/12/2020 at 1:12 PM, seanl82 said: That's shocking, even for aftermarket on the alloy rad. Hella rads were the recommended when I replaced mine in 2014. Still looks like new now - though I've only put about 2k miles on the car since then tbf. Yes Hella rads would of been my first choice- they were actually manufactured on behalf of Hella from a German company called AKG - I called them but no one in the office at the time because of Covid- so took the Dasis- I really hope its a good one - manufactured in Germany so fingers crossed. This is the firm that made the Hella rad. https://www.akg-group.com/products/radiators/ Edited December 12, 2020 by Keyo Quote Share this post Link to post Share on other sites
Bruno 4 Posted December 12, 2020 About 8 years ago whilst doing a review of VAG I happened to stumble on the fact that the Corrado OEM rads came with Valeo, Hella and Nissens - the European market. My original rad kept developing problems with the side caps, so I bought a PWR radiator about 10 years ago. Small problem with the top right fitment, it fouled a lip next to the battery housing, but 5 mins with a dremel was enough. Bought a Valeo copper radiator for my wife's Corrado. She used to do a lot of long high speed journeys from London to Newcastle three times a week, and that radiator ran the engine a lot cooler, on extended idle oil temps were a lot lower. Although it was almost £300 at the time, it was really worth the money. The welds were excellent. Do let us know how you get on with that Dasis. Quote Share this post Link to post Share on other sites
Keyo 47 Posted December 12, 2020 (edited) On 12/12/2020 at 2:30 PM, Bruno said: About 8 years ago whilst doing a review of VAG I happened to stumble on the fact that the Corrado OEM rads came with Valeo, Hella and Nissens - the European market. My original rad kept developing problems with the side caps, so I bought a PWR radiator about 10 years ago. Small problem with the top right fitment, it fouled a lip next to the battery housing, but 5 mins with a dremel was enough. Bought a Valeo copper radiator for my wife's Corrado. She used to do a lot of long high speed journeys from London to Newcastle three times a week, and that radiator ran the engine a lot cooler, on extended idle oil temps were a lot lower. Although it was almost £300 at the time, it was really worth the money. The welds were excellent. Do let us know how you get on with that Dasis. Will do Bruno I have checked the bolt fitment for the elbow neck and they are correct so that is a good start. That copper rad sounds awesome- Valeo still make a rad for the Mk2 Golf 16v and its only £32.00 what a bargain. Edited December 12, 2020 by Keyo Quote Share this post Link to post Share on other sites
Keyo 47 Posted December 12, 2020 (edited) Also to add you can still get the OE VAG fan switch late type for a VR for £36.00. - got mine delivered from Listers Straford upon Avon who also can supply the vag bolts and washers for the neck and the bottom housing rubber buffer o rings. Part list below (FAN SWICH LATE VR) I will mention it again best vag dealers for parts and leasing- not even my local city we have shitty Johnsons. Chap even calls you up and says have the parts now and will be posting today anything else I can help you with . Edited December 12, 2020 by Keyo Quote Share this post Link to post Share on other sites
fendervg 33 Posted December 12, 2020 No issues so far with the Hella/Behr unit I got from adrad.co.uk a couple of years ago - I don't think they have them at the moment though. Hopefully your replacement will hold up - they always look nice fresh out of the box before they've been fitted! GBP 115.15VOLKSWAGEN CORRADO (VW328) ADVANCED RADIATORS LTD Quote Share this post Link to post Share on other sites
Keyo 47 Posted December 12, 2020 On 12/12/2020 at 4:59 PM, fendervg said: No issues so far with the Hella/Behr unit I got from adrad.co.uk a couple of years ago - I don't think they have them at the moment though. Hopefully your replacement will hold up - they always look nice fresh out of the box before they've been fitted! GBP 115.15VOLKSWAGEN CORRADO (VW328) ADVANCED RADIATORS LTD Will the OE radiator slam panel brackets work with Dasis rad looking at the pictures ? Cheers Quote Share this post Link to post Share on other sites
fendervg 33 Posted December 12, 2020 They look like they should - but hard to tell unless you have them side by side or actually trial fit it unfortunately. Quote Share this post Link to post Share on other sites
Bruno 4 Posted December 13, 2020 It should fit nicely. I see it even has the hangers for the later version of aircon condenser, so yours was meant for a post 1993 VR6. The bottom pins did not change for VR6 Corrados even through the face lift. The top turret didnt change - only the aircon pipe hangers and condenser hangers. Please post here when you've fitted it I need know how you get on with that one. Have a contact in the US who is worried about the pattern radiators available for his SLC over there and is scared of buying one from the UK without knowing that it will actually fit properly. Looks like the Valeo VR6 copper ones are still around but terribly expensive. Quote Share this post Link to post Share on other sites
Keyo 47 Posted December 13, 2020 Will do Bruno I have not seen a Valeo one for sale chap but please post a link if you have seen one. Thanks Quote Share this post Link to post Share on other sites
Bruno 4 Posted December 14, 2020 EAN is 3276427346060. The Valeo part No is VALEO 734606. Cannot seem to find anybody with this in stock in the UK. Some Polish sources, but I don't read Polish. The original copper version had this VAG part: 535121253, made in France, by Valeo. However I do not think VAG fitted them to Corrados as production radiators. The ones made in Germany were aluminium and had an E on the end; the final version had an M on the end, it was aluminium, made in Denmark, by Nissens. The E and M versions were fitted as production rads. Quote Share this post Link to post Share on other sites
Keyo 47 Posted December 14, 2020 (edited) That Rad is for an Auto Brruno. you can still buy it mate. VALEO Radiator, engine cooling Copper, Automatic Transmission Article number: 734606 Construction year to:07/1995 Engine Code:ABV Transmission Type:Automatic Transmission Vehicle Equipment:for vehicles with air conditioning (manually controlled) Suspension:for vehicles with heavy duty suspension Climate Zones:for hot climate zones Material:Copper Width [mm]:317 Outlet Ø [mm]:32 Inlet Ø [mm]:32 Thickness [mm]:33 Height [mm]:675 Weight [kg]:4,15 Housing Type:Synthetic Material Housing VALEO:Radiator, engine cooling Item number:734606 Our price:560,04 £ Manufacturer part number:734606 Manufacturer:VALEO EAN number:3276427346060 Condition New Use number: VALEO 734606 EAN: VALEO 3276427346060 2 years warranty 14 14 Days Returns Policy 200 Safe Order 200 days Add to wish list https://www.autodoc.co.uk/valeo/1098315?gadw=1&gclid=CjwKCAiAt9z-BRBCEiwA_bWv-JKMNvuPCXD5wsGgk4SnhPIRPn4TC-u89zcdWM3rAxqO2EfCAZl0ChoCgLEQAvD_BwE Edited December 14, 2020 by Keyo Quote Share this post Link to post Share on other sites
1xshaunx1 27 Posted December 15, 2020 On 12/14/2020 at 10:44 PM, Keyo said: That Rad is for an Auto Brruno. you can still buy it mate. VALEO Radiator, engine cooling Copper, Automatic Transmission Article number: 734606 Construction year to:07/1995 Engine Code:ABV Transmission Type:Automatic Transmission Vehicle Equipment:for vehicles with air conditioning (manually controlled) Suspension:for vehicles with heavy duty suspension Climate Zones:for hot climate zones Material:Copper Width [mm]:317 Outlet Ø [mm]:32 Inlet Ø [mm]:32 Thickness [mm]:33 Height [mm]:675 Weight [kg]:4,15 Housing Type:Synthetic Material Housing VALEO:Radiator, engine cooling Item number:734606 Our price:560,04 £ Manufacturer part number:734606 Manufacturer:VALEO EAN number:3276427346060 Condition New Use number: VALEO 734606 EAN: VALEO 3276427346060 2 years warranty 14 14 Days Returns Policy 200 Safe Order 200 days Add to wish list https://www.autodoc.co.uk/valeo/1098315?gadw=1&gclid=CjwKCAiAt9z-BRBCEiwA_bWv-JKMNvuPCXD5wsGgk4SnhPIRPn4TC-u89zcdWM3rAxqO2EfCAZl0ChoCgLEQAvD_BwE Out of stock Quote Share this post Link to post Share on other sites
Bruno 4 Posted December 16, 2020 Odd. Just had a gander at the one we have. No additional ports for autobox cooling. Same part number. Dont understand why autodoc gave it that profile. But do let me know how you get on with yours. Quote Share this post Link to post Share on other sites
fla 9 Posted December 16, 2020 i think for the auto it's only the top and bottom hoses that are different to allow another route to the cooler. The rads are (should be) identical. Quote Share this post Link to post Share on other sites
Keyo 47 Posted December 16, 2020 On 12/16/2020 at 10:31 AM, fla said: i think for the auto it's only the top and bottom hoses that are different to allow another route to the cooler. The rads are (should be) identical. I was thinking that pretty sure you could mod it - maybe all air on rads came in copper as well for extra cooling ? Quote Share this post Link to post Share on other sites
fla 9 Posted December 16, 2020 Yes generally copper which is then plated to prevent excess corrosion form copper salts forming. I think they use TSA. I deal with some heat exchanger manufacturers although this is for industrial plant, but i'll see if they can look into some rads for us. If anyone has an old rad they could measure up i'll ask the question. Quote Share this post Link to post Share on other sites
ger040 3 Posted December 16, 2020 pity the corrado vr6 is model specific for radiators - have not seen a top manufactured one (eg Hella) for long time new Plenty for the golf and even t4 van Quote Share this post Link to post Share on other sites
Keyo 47 Posted December 16, 2020 On 12/16/2020 at 6:22 PM, ger040 said: pity the corrado vr6 is model specific for radiators - have not seen a top manufactured one (eg Hella) for long time new Plenty for the golf and even t4 van Sure for a Mk2 golf you are spoilt rotten at a cost of a three course meal for a top quality rad. - Quote Share this post Link to post Share on other sites
Bruno 4 Posted December 18, 2020 On 12/16/2020 at 11:18 AM, Keyo said: I was thinking that pretty sure you could mod it - maybe all air on rads came in copper as well for extra cooling ? The SLC ones were all alluminium. They really had problems with those. Quote Share this post Link to post Share on other sites
Keyo 47 Posted December 21, 2020 (edited) Update, Fitted the Dasis Radiator today and the fit is excellent to OE spec- all parts lined up including the top brackets - time will tell how well it cools and lifespan. One thing I did notice was the aftermarket fan switch sensor in the rad I took out had a copper washer- however the genuine vag one did not have a washer and etka does not show the fan switch as having any kind of o ring washer- its not leaking either after fitting. Anyone confirm that the vag one does not have a copper washer as per etka. Cheers. Edited December 21, 2020 by Keyo Quote Share this post Link to post Share on other sites
1xshaunx1 27 Posted December 21, 2020 Fitted mine with some pipe thread Sealant. Have you had the front wings sprayed again mate Quote Share this post Link to post Share on other sites
Keyo 47 Posted December 21, 2020 (edited) On 12/21/2020 at 7:39 PM, 1xshaunx1 said: Fitted mine with some pipe thread Sealant. Have you had the front wings sprayed again mate No chap had them taken off as having a comprehensive underseal and under panel inspection. Yeah chap I was tempted to do that to mine will do no harm - for the life of me I dont think the oe one is meant to have an o ring - the aftermarket ones seem to have a shorter and less complicated thread that come with the o ring. Main job paint front bumoer + rear bumper + bonnet spray as stone chipped and swirling. the wings are actually in good condition surprisingly. Couple of rust patches on the underbody on the rear arches needed cutting out- also on the bottom of the a pillars - got in there early to stop it in its path. Edited December 21, 2020 by Keyo Quote Share this post Link to post Share on other sites
1xshaunx1 27 Posted December 21, 2020 I think I have fitted with a copper washer before though I fitted Wahler fan switch 6017.95D Quote Share this post Link to post Share on other sites
