g-dub 0 Posted October 4, 2004 just wanna know the best runin for my car, had a new S/C and had just completed 1000 mile before i crashed the car, the engine had been sitting for about 10 months but was turned over a few times, shall i do another 1000 miles or can it be less also should i use different oils, for the process one to do the runin and then is it semi sinthetic afterwards cheers Quote Share this post Link to post Share on other sites
munkay 0 Posted October 4, 2004 It'll be fine if you have done 1000 already. Just take it easy and always make sure your temps are 90c plus before going over 3ki odd. You'll be fine with semi as well. Just worry about not crashing again :D Quote Share this post Link to post Share on other sites
bcstudent 0 Posted October 4, 2004 screeeeeeeeeeeccccchhhhhhh.........*BANG* sob sob Quote Share this post Link to post Share on other sites
vr6storm 0 Posted October 4, 2004 if its been sitting for 10 months and only been turned over a few times i would for the sake of £30-ish quid still give it an oil and filter change Quote Share this post Link to post Share on other sites
munkay 0 Posted October 5, 2004 Yeah definitely - I assumed when you mentioned the oil you were going to do this. Drive a few miles with the old oil first though before changing it maybe. Quote Share this post Link to post Share on other sites
stevemac 0 Posted October 6, 2004 if its been sitting for 10 months and only been turned over a few times i would for the sake of £30-ish quid still give it an oil and filter change Agreed - just to be on the safe side :wink: (use Synta Silver oil) Quote Share this post Link to post Share on other sites
Henny 0 Posted October 7, 2004 yup, personally, I'd run her up to temp while she's standing, switch off and drain the oil. Change the filter and replace the oil (don't forget the bung first though!) and then drive as normal... 8) Quote Share this post Link to post Share on other sites
g-dub 0 Posted October 9, 2004 great, i thought i was gonna have to spend a week going up and down the M6, and yup the engine will be fully serviced (plugs, leads, oil/filter, fuel filter) before and oil change every month after, next question then, got a polished and ported head and a cam to go in how many miles running in should i cover before fitting this (i know i could have done this in the first place but just wanted to get it running first), probably gonna go to the No-rice RR before to see what it'll put out any way and as for crashing again, i drive like a sunday driver now im so scared of the road, my wife drives more eratticly than me Quote Share this post Link to post Share on other sites
h100vw 0 Posted October 9, 2004 Just stick it all together and drive it. It's no more likely to go wrong if you put the head on now or in 25 miles, assuming you do it right. :mrgreen: Even Henny with a good engineering background has stuff go wrong on him. Usually materials not workmanship. :roll: Gavin Quote Share this post Link to post Share on other sites
Henny 0 Posted October 9, 2004 Even Henny with a good engineering background has stuff go wrong on him. Usually materials not workmanship. :roll: Ain't that just the truth... :roll: :? Out of the problems I've had with my car over the last year and a bit, only 1 of 'em has been caused by a lack of knowledge rather than an actual material failure... :| I'm with Gav here... get the head on! Quote Share this post Link to post Share on other sites
g-dub 0 Posted October 9, 2004 well gonna leave the standard head on so i can RR and take it down the strip and see whats what, then do the head and cam and see if the money was worth it, then go see misure darren, then go see misure vince, then misure.... you get the picture! and as the RR is only 5 mins and pod only 15mins away i can nip between each mod, it's not so bad here! Quote Share this post Link to post Share on other sites
