mrbeige 0 Posted March 23, 2005 I can't seem to find out technical info on my 9a engine :( , does anyone have a good weblink that has full internal dimensions for my engine, like con-rod dimensions, combustion chamber volume, etc? Quote Share this post Link to post Share on other sites
davidwort 0 Posted March 23, 2005 I can't seem to find out technical info on my 9a engine :( , does anyone have a good weblink that has full internal dimensions for my engine, like con-rod dimensions, combustion chamber volume, etc? Haynes Passat manual, can't remember the stroke but bore is 92.5mm I think. Compression should be 10.5:1, I'll check tonight if no-one else knows, info is probably in owners manual too. David. Quote Share this post Link to post Share on other sites
gradeAfailure 0 Posted March 23, 2005 I'll have a look in my Waynes manual when I get home and post up the specs... What info exactly did you want? Quote Share this post Link to post Share on other sites
mrbeige 0 Posted March 24, 2005 Stuff like conrod specs, little end bearing size, compression ratio, combustion chamber volume, CR, bore, stroke, etc Not necessarily your normal stuff! Quote Share this post Link to post Share on other sites
moneypit23 0 Posted March 24, 2005 I used this when i analysed my car for a project http://www.thecorrado.com/corrado2016v.pdf might have something useful in there Quote Share this post Link to post Share on other sites
gradeAfailure 0 Posted March 24, 2005 Tch, my Waynes manual for the Passat doesn't cover the VR6 or 16V engines... useless...! Sorry! Quote Share this post Link to post Share on other sites
h100vw 0 Posted March 24, 2005 Haynes never did a manual for the 9A. They do have a VW one, I got sent some photocopies of a couple of pages from it years ago by a very nice young lady. There was one on ebay last year, I sold it to a lad off the forum.:mrgreen: mrbeige why do you want all the info??? Gavin Quote Share this post Link to post Share on other sites
davidwort 0 Posted March 24, 2005 Haynes never did a manual for the 9A... My 1988-91 passat haynes manual covers the 9A, although a lot of the photos are geared towards the 8v passats. David. Quote Share this post Link to post Share on other sites
surfer.vr6 0 Posted March 24, 2005 http://www.corradoclub.org/Tech%20files ... %2016v.pdf Might help? Quote Share this post Link to post Share on other sites
h100vw 0 Posted March 24, 2005 Haynes never did a manual for the 9A... My 1988-91 passat haynes manual covers the 9A, although a lot of the photos are geared towards the 8v passats. David. It has the fluid specs and stuff but it's not got all the info for a full engine rebuild like you would find in the MK2 Golf manual. There is nothing on the ign and injection systems if I remember correctly, which is where the VW book comes in. For instance you can't even adjust the tickover on a 9A...... Gavin Quote Share this post Link to post Share on other sites
Henny 0 Posted March 24, 2005 h100vw, not entirely true... disconnect a plug lead and I'll wager it'll adjust the tickover... ;) :lol: Sorry, I'll get me coat... :oops: Quote Share this post Link to post Share on other sites
mrbeige 0 Posted March 29, 2005 I think I'm going to have to take it apart aren't I! What is the difference between the 9a block and the audi 6a block? Quote Share this post Link to post Share on other sites
davidwort 0 Posted March 29, 2005 I think I'm going to have to take it apart aren't I! What is the difference between the 9a block and the audi 6a block? not much, ancilliary bits really and the sump pan and oil pickup pipe, got one in my C (6A block), David. Quote Share this post Link to post Share on other sites
bristolbaron 11 Posted March 29, 2005 http://www.clubgti.com/forum/forum_post ... 52550&PN=1 Worth a look. doesnt give you tech details you're after, but theres plenty there! Quote Share this post Link to post Share on other sites
roo 0 Posted March 30, 2005 I found this page a while back, has most of the useful engine dimensions...good bedtime reading. http://not2fast.wryday.com/vw/stuff/vw_engines.shtml Not2Fast: VAG Engine Component Dimensions Quote Share this post Link to post Share on other sites
mrbeige 0 Posted March 31, 2005 Fantastic....good skills! That's one worth noting down I think 8) Quote Share this post Link to post Share on other sites
