CaiosG60 PWR 0 Posted April 12, 2005 Think the dif on my gearbox has imploded! The car started to click a little last weak when traveling along. Then over the weekend when reversing the car it was clicking and shuddering quite violently. Took it to my mechanic today, I’d persuaded myself it was a drive shaft or inner cv joint on the way over. Appeared to click most under high torque. So we put it up on the ramp, in first clutch up wheels spining freely. Everything looked okay around the drive shafts, but still this clicking now and again. He said that he reckons that the dif was mangled. I wasn’t to sure and didn’t want to jump to any conclusions. Then we needed to get my mates G60 on the ramp to drill out a snapped bottom pulley bolt. :? Went to get mine off the ramp and it just locked up and I couldn’t get it out of reverse either!! Gear stick was stuck solid. So we attached a tow bar to the rear towing eye and started dragging it off the ramp with both of the front wheels locked. This luckly did free the car and I could get the gear stick out of reverse. I’ve driven the car about 1 mile and it drives fine just little clicks now and again. Not even going to try reverse again though!! So do you agree that the dif is totally shot? :? :x What gear box shall I put on? Thinking off fitting a MK3 16v for the better ratios. Will it be a strait swap? :-P Quote Share this post Link to post Share on other sites
mysticalz 0 Posted April 12, 2005 whaen did that happen cai poor baby hope its ok Quote Share this post Link to post Share on other sites
mysticalz 0 Posted April 12, 2005 by the way its al hear Quote Share this post Link to post Share on other sites
20v turbo 0 Posted April 12, 2005 put a 20v one in cheap as chips,all you have to do is get some new drive flanges in and then it's a staight swap,supposedly the same ratio's as the mk3 16v box but newer and more available. Quote Share this post Link to post Share on other sites
marcus 0 Posted April 12, 2005 Just out of curiosity how loud is this clicking because i get a slight clicking noise now and again? Quote Share this post Link to post Share on other sites
CaiosG60 PWR 0 Posted April 12, 2005 Nice one Andy, Thought I'd be able to get a 16v cable box from any local scrappie for sod all. Whats the going rate on a 20v gearbox? There's different types isnt there? I know to avoid 6 speed and the ones from Passats but what else? I'll have to see what the guy who'll end up doing it says. He'll probably have a winge at changing the flanges. Whats involved in doing that? Sounds a lot better idea than mk3 16v though. 20v box should be stronger and lower miles. marcus when the clicking started it sounded just like a CV or ball joint does when they go. But in reverse it was scary loud and violent. Hole car shudders and with bonet up looks like engines gona jump out of the car!!! Quote Share this post Link to post Share on other sites
20v turbo 0 Posted April 12, 2005 seen the 20v box's go for £100/£200,i think as long as it is of a 20v turbo you should be ok (i'll look into gearbox code's later for you)as for the drive flanges it's just a case of unbolting it (1 bolt down the middle)and swaping it for a 100mm one,swap the slave cylinder's over and then it bolt's straight on 8).the only down side is the drive flanges are about a £120 for the pair :shock: .its a lot better gearchange with the 02J box aswell. Quote Share this post Link to post Share on other sites
CaiosG60 PWR 0 Posted April 12, 2005 uuuum, sounds a bit more than I was hoping. But it'd be good to turn it into a positive thing for the car. Would be worth the extra cost. :-) I'll phone around tomorrow and get some prices of things. If you could let me know the part numbers of potential gear box's and the necessary flanges that'd be great. Cheers Quote Share this post Link to post Share on other sites
CaiosG60 PWR 0 Posted April 13, 2005 So far cheapest is "Breaking VWs" in Huddersfield. 20v 5 speed gearbox £250 or £300 for low millage one £150 for Corrado 16v cable change. There saying £20 delivery which sounds good. Both seam a bit expensive though. Also £220 deliverd for Golf 16 mk3 (AGC??) from somwhere in essex. Quote Share this post Link to post Share on other sites
CaiosG60 PWR 0 Posted April 13, 2005 Are ratios in 16v Corrado same as 16v golf mk3? Is it the same gearbox? A passat turbo diesl engine has just been deliverd to my garage for £300. It looks absoultly mint!! So I'm thinging maybe to phone the people who sent it, MDH and ask them for the gearbox that was with it. The engine was a AAZ one so from old passat not new one. Dont know what the gearbox code will be. Does anyone know what this gearbox is like? ratios, strengh, etc Quote Share this post Link to post Share on other sites
CaiosG60 PWR 0 Posted April 13, 2005 Tracked down a 20v non-turbo box for £230 delivered. Dont know anything about this though. Its at http://www.vw-audi-specialists.co.uk Quote Share this post Link to post Share on other sites
Henny 0 Posted April 13, 2005 Cai? Turbo diesel gearbox will have completely the wrong gear ratios for a G60... :| Quote Share this post Link to post Share on other sites
CaiosG60 PWR 0 Posted April 13, 2005 Okay, cheers henny. Gears to short on tdi box? What do you reckon I get? That 20v non-turbo box seams the best value at the moment. Just need to find out if it is the same as the 20v turbo ones. Quote Share this post Link to post Share on other sites
Henny 0 Posted April 13, 2005 MKIII 16V is supposed to be as strong as the G60 box and have better ratios than the original G60 one, but I've yet to see anyone show that the internals WILL take the extra horses the G60 kicks out over the 16V over time.... :? I have no idea about the 20VT ratios, but they're definately built to easily take the abuse a G60 could throw at it... 20V none T boxes, again, I have no idea about, but I'd guess that they're also better built than G60 boxes as they're somewhat newer... Personally? I'd probably stick in another G60 box as you can pick 'em up pretty cheaply... Give Mike at Golfnutz a ring and see what he's got in stock, he may well have what you're looking for, or know where you can get one... 8) Are you absolutely sure it's the diff? normally when they go they punch a rather large obvious hole in the outer casing and drop gear oil everywhere... :| Quote Share this post Link to post Share on other sites
CaiosG60 PWR 0 Posted April 13, 2005 Well, what do you think from reading the syptoms above? (in first post) The car feels like its getting stuck on something then sudenly free's itself. It is an odd one but with it getting stuck in reverse like that it must be gearbox related. Alough linkage problems may cause it to be stuck in reverse I dont think they would cause the clicking, etc. I'll give golf nutz a ring. :-) :-) Quote Share this post Link to post Share on other sites
Henny 0 Posted April 13, 2005 to me, it sounds more like you've knocked a tooth off one of the cogs and it's floating around inside the box jamming it up every now and then... :| Quote Share this post Link to post Share on other sites
CaiosG60 PWR 0 Posted April 13, 2005 Yeah, sounds more than possible. Other gears are okay so could be a tooth snapped of reverse gear. Think its still a new box though? Quote Share this post Link to post Share on other sites
Rpmayne 0 Posted April 13, 2005 Aren't the bolts holding the diff together prone to shearing like the mk2 golfs? I had one go and it shot one of the heads through the bell housing and let the gearbox oil soak the clutch. Didn't hear anything, only noticed the clutch slipping and a trail of oil back to my house. Maybe a bolt head is ratling around. Quote Share this post Link to post Share on other sites
CaiosG60 PWR 0 Posted April 13, 2005 Yeah could be. I'm sure when the gear box comes off somthings gonna fall out! :-) Quote Share this post Link to post Share on other sites
mrbeige 0 Posted April 13, 2005 Have you tried using Partsgateway ? They are normally quite good for parts. Quote Share this post Link to post Share on other sites
Henny 0 Posted April 13, 2005 Rpmayne, yeah they are, I was under the impression that when they went they tended to punch a hole through the diff housing, I'd never thought that they may punch a hole internally... :oops: Quote Share this post Link to post Share on other sites
mk2_20vt 0 Posted April 13, 2005 There was a chap selling an audi 20v 02J gearbox on the club gti forum a few weeks ago. http://www.clubgti.com/forum/forum_post ... 65382&PN=2 Quote Share this post Link to post Share on other sites
mk2_20vt 0 Posted April 13, 2005 also one on ebay http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 01487&rd=1 Quote Share this post Link to post Share on other sites
CaiosG60 PWR 0 Posted April 13, 2005 Sweet!! Seen the one on ebay. Waiting for him to get back to me on organising a courier to go pick it up for me. Think the one from ClubGti forum is on eBay now too. Email him as well. Just need to know what flanges I need to get? Andy (20v turbo) said 100mm ones. What size are those on a 20v box and aren’t the ones on my G60 box 100mm anyway? (take them off my g60 box, put on 20v box, sorted???) Quote Share this post Link to post Share on other sites
g60bv 0 Posted April 13, 2005 you dont want the 20 non turbo. the gear is way too short. you'll be maxing out at 120. .. but you'll get there pritty quick.! and you dont have to swap the flanges over. i've been told. Q. if you were to get a 20vt box, what flanges do you need to put in. can't you use the flanges from the dead g60 box? Quote Share this post Link to post Share on other sites
