olly elworthy 0 Posted May 5, 2006 nearest person to me who can remap my G60 so hope all will be good, should may all my mods work for me,, current spec is, Engine modifications are as follows, Kent 266 camshaft, Front mount inter cooler, sns stage 5.5 chip, Toothed 69mm supercharger pulley kit, G-werks RSR supercharger outlet, Carbon canister and associated pipe work removed, Mocal 13 row oil cooler with stainless steel braided pipe work, Corrado Vr6 clutch kit, RPT solid front engine mount, Magnecour Plug leads, Bosch platinum spark plugs, Supersprint Cat bypass pipe, Scorpion stainless steel 2.5 inch exhaust, Bosch 3.5 bar FPR Standard G60 injectors 40 inlet 35 exhaust big valve head, The main power orientated mods I suppose would be the big valve head, FMIC, cam and smaller supercharger pulley, the motor is currently running a bit rich according to my LM1 innovate wideband lambda controller, ( AFR is low 11:1 under boost), and I think there could be room to increase the ignition timing dude to the new found charge air cooling form the front mount intercooler, please discuss!! :lol: Quote Share this post Link to post Share on other sites
Andy665 0 Posted May 5, 2006 Best person to speak to is Woody, his G60 was re-mapped by Ray West late last year, he is very happy with the results Quote Share this post Link to post Share on other sites
iow_corrado_g60 0 Posted May 5, 2006 good stuff im interested in this as I want to go FMIC soon! Quote Share this post Link to post Share on other sites
olly elworthy 0 Posted May 5, 2006 fmic is a pro alloy item bought directly from them,, Quote Share this post Link to post Share on other sites
_Monkey 0 Posted May 5, 2006 Good luck mate, Recon you should see a decent gain!! Quote Share this post Link to post Share on other sites
olly elworthy 0 Posted May 5, 2006 lets hope so,, shoudl make all my mods work together!! Quote Share this post Link to post Share on other sites
john_wintle 0 Posted May 5, 2006 If you still have the original injectors in the car, then you should think about getting them properly cleaned using an ultrasonic cleaner. That way you will be getting the best out of the car with all the mods done and the remap. This can make quite a difference to the spray pattern on the injector, and will improve pick-up/idling and general running. John. Quote Share this post Link to post Share on other sites
Andy665 0 Posted May 5, 2006 Agree, having my injectors cleaned by JMR later this month, apparently makes a big difference to the car, mine must be pretty iffy after 115,000 miles Quote Share this post Link to post Share on other sites
olly elworthy 0 Posted May 5, 2006 mine had done about 85000 miles,, good idea though I`ll look into it,, Quote Share this post Link to post Share on other sites
NickVR6 0 Posted May 5, 2006 olly, its only 5 miles from me, so if you fancy hooking up on the way i wouldnt mind a nose! heard good things but never been there. Your welcome to make a pit stop here too bud. Quote Share this post Link to post Share on other sites
olly elworthy 0 Posted May 5, 2006 olly, its only 5 miles from me, so if you fancy hooking up on the way i wouldnt mind a nose! heard good things but never been there. Your welcome to make a pit stop here too bud. I`ll have to pop in and say hello, thanks,, :wink: Quote Share this post Link to post Share on other sites
Henny 0 Posted May 5, 2006 yup, heard good things about Ray West too... Should get your motor running as well as it can which should give you some good gains if you're running rich like your LM1 says... 8) Quote Share this post Link to post Share on other sites
woody 0 Posted May 5, 2006 mine started out out 185 and ended up with 212 so that gave me an extra 27 bhp and it felt like a lot more on the way home. Very nice guy ray and was even really helpful after i nearly chopped his thrumb off in the bonnet. Plus you can wander up to the circuit and get some lunch. Quote Share this post Link to post Share on other sites
olly elworthy 0 Posted May 6, 2006 cool,, really looking forward to going up there and seeing what she does when tuned properly,, Quote Share this post Link to post Share on other sites
john_wintle 0 Posted May 8, 2006 Let me know if you are interested in getting the inj's cleaned. They will obviously have to be removed from the car in the first place, and then sent by a reliable courier. John Quote Share this post Link to post Share on other sites
olly elworthy 0 Posted May 9, 2006 thanks for the offer but i`ll probably just get myself an ultrasonic bath and clean them myself as i like to do everything on my car,, and then i`ll have the kit to do all the other Vw`s in the household,, shame i dont have a Rolling Road :-( Quote Share this post Link to post Share on other sites
