Riley 0 Posted September 16, 2006 How do guys... Had a bit of fun with a bike earlier today (on a private back road 8) ) He never got past me but the rado just hasn't felt too lively for a while now... When i got home i just checked under the bonnet for any signs of problems and noticed a lot of dust on the underside of the bonnet above the charger pulley. Im guessing my belts slipping at high rpm? I run a jabbasport adjustable tensioner so just wondering if i should give it a tweak,but im not entirely sure how tight to go? :? Neil. :) Quote Share this post Link to post Share on other sites
Supercharged 2 Posted September 17, 2006 Could be one of those plastic rollers worn out and casuing resistance... Quote Share this post Link to post Share on other sites
Riley 0 Posted September 17, 2006 You think so m8? is the dust a normal side effect of that? There is a slightly noisy roller actually (one of the plastic ones) expensive from gsf? or better from the dealers? Any more info/idea's appreciated. Cheers,Neil. :) Quote Share this post Link to post Share on other sites
Supercharged 2 Posted September 17, 2006 Not sure really but I think you can replace the plastic with 8v cambelt tensioners - darren will know! Quote Share this post Link to post Share on other sites
Riley 0 Posted September 17, 2006 cool,will see if he notices this thread 8) Neil. Quote Share this post Link to post Share on other sites
steveo29 0 Posted September 18, 2006 gsf does the tensioners....but you can pop out the seals and regrease em if your not flush with cash Quote Share this post Link to post Share on other sites
Riley 0 Posted September 18, 2006 You got that right steveo m8 :lol: Ive regreased em a while ago but they have gone noisy again :( Will have to wait on new ones by the looks of it. Does the above pic look like thats my problem? or should i tweak the adjustable tensioner? Cheers,Neil. Quote Share this post Link to post Share on other sites
Tempest 0 Posted September 19, 2006 Ive regreased em a while ago but they have gone noisy again I'd then definitely replace the plastic tensioner rollers. When I changed all the belts on my G60, I also tested the platic tensioner roller for the polyribbed belt, and they were still fine, no resistance, turned smoothly, no noises, but in your case you've got the symptonms of knackered rollers. Tempest Quote Share this post Link to post Share on other sites
Riley 0 Posted September 19, 2006 Aye,they do need replacing really with being noisy...suppose it may be worth replacing the belt too? Is that what the dust will be from? slipping? Cheers m8. Neil. :) Quote Share this post Link to post Share on other sites
Tempest 0 Posted September 19, 2006 Might be, but wouldn't go amiss replacing the belt anyway, given that it's had a higher resistance from the rollers anyway. Tempest Quote Share this post Link to post Share on other sites
flusted 0 Posted September 19, 2006 Not sure really but I think you can replace the plastic with 8v cambelt tensioners - darren will know! Sounds interesting! can anyone confirm? Quote Share this post Link to post Share on other sites
GazzaG60 0 Posted September 19, 2006 bin the tensioner cap and fit the right smaller belt. those caps have been known to not be quite right. Quote Share this post Link to post Share on other sites
Henny 0 Posted September 19, 2006 flusted, that's what the toothed pulley kits use... Dunno if it'd work with the normal belt, but I can't see why not... Quote Share this post Link to post Share on other sites
GazzaG60 0 Posted September 19, 2006 does the tensioner not kinda split a serp belt. a cam belt gets that groove up the middle but the teeth run across to hold strength. with the ribs running along doe it not cause an issue in the center of the middle rib. my mate did use golf 16v ones on a subaru sport he supercharged for a customer. seemed to hold up fine. Quote Share this post Link to post Share on other sites
_leon_ 0 Posted September 19, 2006 am i missing the point here - why not just use the plastic rollers? Quote Share this post Link to post Share on other sites
flusted 0 Posted September 19, 2006 am i missing the point here - why not just use the plastic rollers? Plastic = weak Metal = stronger Would be a good upgrade Ive got a toothed kit coming anyway :wink: Quote Share this post Link to post Share on other sites
Riley 0 Posted September 19, 2006 Cheers guys,ill go for new rollers and see if i still get the dust. Gazza,whats the deal with the adjustable tensioner being crap? i think? it has the right length belt on there and it does tighten up but i dont know how tight it should be... :oops: dont wanna knacker any bearings. Neil. Quote Share this post Link to post Share on other sites
g60bv 0 Posted September 19, 2006 erm the tooth belt sound lovley. but i wouldn;t reccomend them i've used them for a while and dont rate them. they gain you nothing. and can be unreliable. keep with the standard belt. they were designed ribbed for a reason. Quote Share this post Link to post Share on other sites
g60griff 0 Posted September 19, 2006 erm the tooth belt sound lovley. but i wouldn;t reccomend them i've used them for a while and dont rate them. they gain you nothing. and can be unreliable. keep with the standard belt. they were designed ribbed for a reason. is this right, ive only heard good things about the toothed pulley kit, thats why i was gonna invest in one. Quote Share this post Link to post Share on other sites
g60bv 0 Posted September 19, 2006 well i dont like them . the belts can snap super easy. cos you cant use the spring tensioner. you have to you fixed ones. they are noisy. and dont give you ANY performance benifits. oh and cost a lot of money. . ask around who uses them. Quote Share this post Link to post Share on other sites
Riley 0 Posted September 19, 2006 From what i understand... They must be used on a car that has good to perfect tolerances on the alternater/pullies as far as wear... Im gonna wait till the kits are maybe tweaked a bit in the future before thinking about one.I do like the idea of them for eliminating slip at high rpm,the serpentine is a crap design from vw imo. Neil. :) Quote Share this post Link to post Share on other sites
Henny 0 Posted September 20, 2006 Interesting that my car showed improvement on low end, mid range AND top end bhp AND torque using toothed pulleys over standard pulleys on a rolling road, so there IS a performance gain to be had with them... And that was comparing a 68mm non-toothed pulley to a 69.1 toothed one... Eliminating belt slip WILL provide gains in boost and therefore power throughout the rev range... And, as for snapping belts, I've broken 3 since I fitted my kit almost 3 years ago. All 3 of those were within a week of each other after the standard tensioner I'd been using for 18months lost it's dampening fluid and so let the belt slacken and grab which is what was snapping them. The solid tensioner I now run solved that problem and has actually quietened down the whine from the belt substantially... Quote Share this post Link to post Share on other sites
GazzaG60 0 Posted September 20, 2006 must say i never felt i had an issue with slip on the standard pulley type at 65mm as long as the belt was in good condition along with the tensioner spring being relatively stiff. recently the tensioner spring has become a bit worn and now it slips i think. Quote Share this post Link to post Share on other sites
JMC 0 Posted September 20, 2006 My toothed belt was on for about 3 months before the belt decided to part company with the car (on the south circular at 7PM one evening - fun). I'd even fitted the s**t shield from the VR6 on the underside of the belt to try and keep out stones. If it goes again really quickly I'll be going back to the old system. I'm running a 68mm and haven't noticed much if any difference in boost pressure at the top end with it. Bottom line is, some people will love them and be happy with the possibilty of having them break regularly, for others the chance that they could let rip at any time is not enough of a draw... Quote Share this post Link to post Share on other sites
flusted 0 Posted September 20, 2006 surely it would be hard to tell when it slips anyway? at least with the toothed kit your gauranteed it wont. Quote Share this post Link to post Share on other sites
