sparks
G60 max bhp all put your figures in
Hi all
just wondering as i thought a little while ago you could get 300 bhp from the little pg whats the average bhp from the engine
so here it is please post your recorded bhp from rolling road or best guessitmate (make sure you state flywheel or wheels power)
i know most have the spec of the car on the signature but if not just a brief one then we all know what we are aiming for with what mods
cheers
stu
ill start it off
68mm pulley ,sns chip,straight though exhaust , 168bhp at wheels about 180bhp fly wheel
cheers stu
ill start it off
cheers stu
With 168bhp at the wheels I recon your pushing more than 180bhp at the fly more like 190-195bhp.
Do you mean PG engine on it's own (therefore allowing for a turbo to be used as per Mr. Junkie) or the G60 engine as a whole, limiting the bhp claims to those using the original G-Lader?
I would like to see all PG really, that way it will give people an idea about the advantages of a turbo and see if it is worth doing, from what I've heard it is not much more than the price of a g-lader re-build and stage 4 porting so might be worth it as a turbo rarely needs re-building and when it would finally come round to need it you will probably be thinking about a bigger turbo anyway :D
I half own a Corrado G60 with my brother in law, we took it up to the Stealth rolling road day a few months back.
Got something like 174BHP at the flywheel, it's totally standard too :lol:
Was very impressed with that.
1.9l, forged pistons, Golf G60 FMIC, flowed throttle body, stage 4 charger, Piper 285 cam, 68mm pulley, red tops, custom map.
196 bhp at the wheels (233bhp at the fly, and 203lbft). Will be more when I get the proper cam in there, lol.
There used to be Silver Mk1 doing the rounds, stripped out for sprinting that supposedly had 274 bhp. Can't remember the exact spec of the bottom end, but was running a Eurospec head and heavily ported charger.
    68mm pully.
    sns stage 5 chip
    Full blend charger.
    De-Cat on standard system.
    Self polished/ported throttle body.
    Sierra cosworth fmic.
    4 year running problem.
206 @ the fly recorded at Awesome Gti. :)
Standard block/internals.
Neil.
feck me thats a good power figure riley! in fact they all are. I dont know what mine is seeing as its not running now so i estimate about 60 bhp lol
Aye, really happy with it, and even more happy with the torque curve...super smooth! Its on awesomes website somewhere, video and graph :)
Its a nice tight engine, just a shame ive had/having so much grief with it :(
Neil.
My Old G60 rado made 252 bhp @ the flywheel with the following ;
1.8 PG
Jabbasport Big valve Cylinder Head
Schrick Cam
65mm Toothed pulley setup
Red top injectors
Full G-werks Exhaust and Manifold
Boost retrun mod
Water/Methanol Injection
Still miss it !
My Old G60 Rado ; http://the-corrado.net/.archive/forum/viewtopic.php?f=11&t=25353&p=270404#p270404
1.8 PG
Schrick Cam
Red top injectors
Boost retrun mod
Still miss it !
:shock: What was that making at the wheels then...
with sns chip
68mm pulley
milltek exhaust and de-cat
ported charger
and blanked off boost return , one or two other small tweaks it made 170 bhp at the wheels and 177lbs-ft torque, now for sale :(
I just make, hhmmmmm, a hell of a lot from the PG but dont like to shout about it too much. lol
Power is nothing without control.
(engine was freshley rebulit)
1.9 big bore
flowed head
std pully
std chip
fast road cam
reground crank
full stainless system
cat bypass
1/2 ruined charger
powerboost vlave
blank off plate
bloked off boost return inlet
raceland manifold
new injector seals
(few otherthings that i done that aint springing to mind)
came out at 187BHP flywheel 192 lbft
Frankinstein Motorsport
when i did the formula of max lbft x rev (at the point of highest lbft) divided by 5252 it came out 211BHP
(192 x 6000 devided by 5252)
But now got the BBM charger on (63mm pully), jabba chip on and injectos on the way so it will be interesting.
1.8 PG
Schrick Cam
Red top injectors
Boost retrun mod
Still miss it !
I cant remember exactly, it was something like 205 at the wheels i think
I had the RR print somewhere, but i think it went when i sold it to the guy that has it now unfortunatley.. balls
1.8 PG
Schrick Cam
Red top injectors
Boost retrun mod
Still miss it !
/quote]
wow what did you replace it with ? rallye ? vr6 super charged ,or house and baby !!!
stu ...
I bought a Mk2 Golf Edition One G60 in my Sig! http://www.edition38.com/forums/index.php?showtopic=89060&st=0
I built it to have pretty much the same spec as the rado ;-) So pushing 240 - 250bhp.
Although that is now sold and being collected end of this month... amazingly mint car, just couldnt use it as a daily anymore, its just too mint, i spent an absolute fortune on it! will be a sad day when that goes :(
Then i can start work on my VR Rado ;-)
So that's 187bhp at the wheels then?
Not sure if mine counts as its not a PG.... but still has a G-lader....
2l 16v ABF + G60 + Lots of other bits n bobs....
Been run hundreds of times on the dyno while i was mapping it
280-290bhp at the fly with 250lbft.
245.5 BHP at flywheel, 175.5 BHP at wheels, 200 ft-LBS torque (this was with a worn gearbox, slipping clutch, no lsd and running 9x16" wheels all round) [This was when engine was fitted in my white rado G60, now in my blue one].
PG Corrado engine block
RS G-lader conversion with upgraded apex seals and bearings
65 mm alloy pulley
SNS Stage 5.5 custom chip
Schrick 268-276 degree asymmetrical camshaft with Piper adjustable vernier pulley
lightened and balanced G60 flywheel
lightened and balanced knife-edged crank
Pace Products custom fabricated front-mounted intercooler
custom 2.5
