Supercharged Junkie
Rounded off allen bolt
What will remove this bolt?
47 members have voted
  1. 1. What will remove this bolt?
    • Irwin Bolt grippers?
    • Torx bit?
    • Removing the engine?
    • I like Ham?
    • Cheese?
    • Suckling at it gently?
    • Fire!
    • A stuffed otter?
    • Hammer?
      0
    • Mallets Mallet?
    • Drill out and replace?
    • Scrap the car?
    • Some sort of mechanical pecker?
    • Buying it a drink and gently stroking it's buttocks?
    • Ask it to read one of Corrado_Sunderlands posts?
Hi Guys
Gonna change the valve cover gasket soon as oil running down the back of the engine block, So i ordered a new gasket from VW today, and thought i`ll get a head start by swapping out the m8x20 bolts that go from the rocker cover to the inlet manifold with some new ones i got.
Problem is managed to remove two of the four, but the other two have been completly rounded off, and of course theres no room to get anything on the bolt itselfs :brickwall:
Anyone got any ideas on the best way to remove them?
Thanks,
Ian
get an allen key that is slightly bigger than the rounded off hole (like 0.5mm- 1mm bigger) and smack it in. turn the bolt clock wise to break the seal then unscrew. oh sure u ken but wd40 is allways a good idea :D
Have you tried swearing at them?
:lol: can you get a bigger allen key and hammer it in? or try imperial?
try irwin easy outs, I had the same problem with caliper carriers. they worked a treat
Mole grips? :shrug: Have you tried swearing at them?
No room for mole grips, and YES i sweared quite alot at them with no real joy :censored:
Supercharged, do you think theres enough room to use bolt grippers on it? (Sorry for the bad pictures, camera couldn`t focus on it for some reason)
looks a bit tight for the irwins, i'd try a larger allen key socket or drill the head off and hope you can get something on the remainder when you take the rocker cover off...
get a big bastid drill on it and hack the top off the bolt, Irwins are for :camp:
:lol:
u feel threatend by irwins don't u?!??
make u feel less of a man? :camp:
