northernvr6 0 Posted March 13, 2011 Pro's and con's? Also does anyone know any uk distributors i can only seem to find ones in the usa which cost a bomb to get imported ? Can you get the original flywheel machined lighter? Any help would be much appretiated Quote Share this post Link to post Share on other sites
C488ADO 0 Posted March 13, 2011 ive got one one word awesome. yes get the orig lighter should be about 6kg iirc Quote Share this post Link to post Share on other sites
northernvr6 0 Posted March 14, 2011 Where did you get yours from if you dont mind me asking ? Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted March 14, 2011 Standard flywheel is 18lbs (8.2Kg). I use a Schimmel cromoly flywheel, which is half the weight and works very nicely indeed. Haven't found any cons yet.... Quote Share this post Link to post Share on other sites
quicky1980 0 Posted March 14, 2011 Standard flywheel is 18lbs (8.2Kg). I use a Schimmel cromoly flywheel, which is half the weight and works very nicely indeed. Haven't found any cons yet.... Interesting I thought the lighter flywheel would mean higher chance of stalling, Im sure Ive heard of another negative to them but cant remember what. Pro's, it's supposed to give you a better engine response due to the flywheel inertia being reduced. Possibly better fuel consumption?? Quote Share this post Link to post Share on other sites
northernvr6 0 Posted March 14, 2011 thanks Kev ive just had a look at the schimmel one looks very tasty but also a nice price ill be looking at around £350 once paid the P+P and import tax. The only bad thing ive heard is that if you go too light it can effect the drivability of the car but these are just rumors. Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted March 14, 2011 Yep, stock flywheels strike the right momentum / engine speed pick up balance. If the engine slows down too quickly, it can as you say Quicky, cause stalling. It's certainly given me a few tuning headaches (I use the standard ISV on my standalone) but it's never stalled. I think it's the people who go for those silly light 6lb alloy jobbies, that suffer the most. Fidanza is it? A nice steel one causes very few problems. There are always going to be for and against arguments but if you have a modified car and don't mind a few minor sacrifices, a good quality light flywheel is a good thing to have :D Quote Share this post Link to post Share on other sites
poll250 0 Posted March 14, 2011 I seem to remember someone on clubgti I think did lightened flywheels on an exchange basis. I can't seem to find the thread though at the moment. ---------- Post added at 01:26 PM ---------- Previous post was at 01:11 PM ---------- Here's the link: http://www.clubgti.com/forum/showthread.php?t=200146&highlight=lightened+flywheel Quote Share this post Link to post Share on other sites
coullstar 0 Posted March 14, 2011 Probably HotGolf. Quote Share this post Link to post Share on other sites
sleeper16 0 Posted March 14, 2011 i can second hotgolfs flywheels got one from him last year for a 02a for my golf really top fella very very helpful couldnt recomend him enough! but if you want to get yours machined try northeast engines in darlington no phone numbers for the place its call in only. Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted March 14, 2011 He also does gearbox rebuilds and a dab hand at it. Can also supply 3.6 final drives etc for VR6s. And if you're taking the box off to fit a light flywheel, it would be a crime of the greatest magnitude to not swap the final drive. Honestly, the flywheel and the shorter final drive will give such an accelerative car compared to standard. Quote Share this post Link to post Share on other sites
ANDREW 30 0 Posted March 14, 2011 How much would a 3.6 final drive be roughly? Then how easy is it to fit? / Quote Share this post Link to post Share on other sites
northernvr6 0 Posted March 14, 2011 Ive just had a read through that hotgolfs thread looks like he knows what hes doing ill join that forum and get a up to date price. Cheers Sleeper Darlo's only 10min down the road so ill call in see how much they want to do it. Ill post the prices i get to incase anyone else is interested Thanks chaps much appretiated probably saved me about 300 quid lol Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted March 14, 2011 How much would a 3.6 final drive be roughly? Then how easy is it to fit? I got my 3.68 crown wheel from Stealth for ~ £50 some years ago. HotGolf charges about the same IIRC. Otherwise it's £200ish+VAT IIRC from the dealer. You'll need an ARP diff bolt set too, at ~ £100. Hell, why not go the whole hog and fit an LSD at the same time :D To fit it requires seperating the gearbox, taking the diff out, drilling the crown wheel studs out, fit the new crown wheel, press in some ARP studs and then refit. It's not as bad as it sounds, it's just getting access to the right tools that's difficult for some people. Quote Share this post Link to post Share on other sites
Rob_B 0 Posted March 14, 2011 if you take your flywheel to an engine builder or machine shop they will machine it down no problem. had mine done on the 20v for about £30 Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted March 14, 2011 The VR6 one is quite thick and can be turned down, but in doing so you run the risk of it warping from the reduced heatsoaking ability (clutch friction). It's why Schimmel's is made of cromoly. So long as material is removed from the right areas, it should be fine. Quote Share this post Link to post Share on other sites
northernvr6 0 Posted March 14, 2011 Thanks for the help Kev and everyone else think ill get the original lightened for now then after its been back on the road awhile ill look into the schimmel flywheel the 3.6 final drive and fitting an lsd at the same time gimmie chance to save lotsa pennies :-) Quote Share this post Link to post Share on other sites
C488ADO 0 Posted March 15, 2011 Sorry for late reply yea mine is one of the hot golf ones I paid £80 delivered from someone on here... It is an original flywheel which has been lightened and balanced packaging was very good proper box, styrene insert for it all to sit in anyway it's all fitted now and it is a noticeable difference spins up much much quicker not loss of power top end from what I've experiences so far hasn't stalled once either or even thought about stalling Er ok I'm obd2 now (woooohoooooo yes !!!!!). Quote Share this post Link to post Share on other sites
sleeper16 0 Posted March 16, 2011 cool where abouts your from? one thing to watch for is if the machine shop include balencing the flywheel in the price, i know hotgolf ones come ready to go. ---------- Post added at 11:26 AM ---------- Previous post was at 11:20 AM ---------- isnt the final drive of the cdm 3.647 anyway? so the 3.6 would result in a loss of acceleration? Quote Share this post Link to post Share on other sites
northernvr6 0 Posted March 17, 2011 Hi Sleeper from a village near sedgefield m8 Just for an update ive sent my flywheel to hotgolf to lighten and balance it he seems to know his stuff and has done alot of these before so im pretty confindent the workmanship will be top notch. Price is £69 thats to lighten and balance the flywheel and the return postage. Ill get some pics up when i get it back. Quote Share this post Link to post Share on other sites
poll250 0 Posted March 17, 2011 I've just picked up a spare flywheel too that's getting sent straight to HotGolf, look forward to getting it back. He's got a good reputation so I'm sure it will be fine. Quote Share this post Link to post Share on other sites
northernvr6 0 Posted March 24, 2011 Hi Guys ive just got my flywheel back from hotgolf cant believe how much lighter it is. Guys a top bloke great communication and quick turnaround would definatly recommend him. Cant wait to get the engine back together now !!!! Quote Share this post Link to post Share on other sites
eddy.h 0 Posted March 24, 2011 http://www.bar-tek-tuning.com they do lightened flywheels Quote Share this post Link to post Share on other sites
poll250 0 Posted May 25, 2011 Have a standard flywheel going spare if anyone want's to send theirs to get lightened, without having to take the car apart first. Can't recommend HotGolf enough, turnaround was about 4 days! See: http://the-corrado.net/classifieds.php?do=viewitem&itemid=385 Quote Share this post Link to post Share on other sites
StueyB 0 Posted May 25, 2011 An alternative is the HotTuing VR6 lightened flywheel. My brother has one of these in his MK3 Golf and i was seriously impressed by the performance increase after fitting. I originally turned my noise up at it due to the brand but the item that turned up was extremely good quality, not a cheap aluminum item but chrome / molybdenum alloy. Not missed a beat in 20k+ of driving and is now under supercharger'd pressures aswell. Currently priced @ £229.00 which i think is very good value for money. Quote Share this post Link to post Share on other sites
