bigben 0 Posted March 1, 2004 With £250 to spend is there and engine mod worht doing?? i already have a full system and induction kit Quote Share this post Link to post Share on other sites
kevin 0 Posted March 2, 2004 rolling road session @ (stealth) Quote Share this post Link to post Share on other sites
h100vw 0 Posted March 2, 2004 Exhaust cam as inlet cam, Stealth again. Gavin Quote Share this post Link to post Share on other sites
flusted 0 Posted March 2, 2004 Ive done the exhaust cam as inlet trick.this coupled with a 50mm inlet manifold and full stainless exhaust is brilliant! Stealth can tune the standard 139bhp to 150bhp without any parts.just a tune up Quote Share this post Link to post Share on other sites
kvwloon 0 Posted March 2, 2004 Hmm, this is getting me thinking now, never reaaly considered touching the engine at all til now! So, do you just fit an exhaust cam in place of the inlet (i.e two 'exhaust' cams fitted), is there no downside to that at all, do you have to adjust the engine settings at all? Is the 50mm manifold better for lower revs range, or across the board better than the 45mm? Finally, where are Stealth, and could no-one else locally (Norwich) do the same work, perhaps a Bosch Ignition agent? Mark Quote Share this post Link to post Share on other sites
davidwort 0 Posted March 2, 2004 Ive done the exhaust cam as inlet trick.this coupled with a 50mm inlet manifold and full stainless exhaust is brilliant! Stealth can tune the standard 139bhp to 150bhp without any parts.just a tune up do you have a dynoplot from stealth for this?, would be interesting to compare it to a standard 16v 1.8 plot or other plots with schrick/piper/kent cams. David. Quote Share this post Link to post Share on other sites
Bally 0 Posted March 2, 2004 How much do stealths charge for a tune up then?? Quote Share this post Link to post Share on other sites
davidwort 0 Posted March 2, 2004 How much do stealths charge for a tune up then?? I think you're looking at around 50 quid an hour for a rolling road tuning session, a couple of hours is generally needed to try different settings of ignition advance and mixture and to diagnose any problem components. Good bet is to get the car on the rollers on a forum or club day and if something looks problematic then book it in for a longer tuning session. David. Quote Share this post Link to post Share on other sites
Bally 0 Posted March 2, 2004 Ok cheers David, good idea, think Jedi was organising a session at PTS in luton, see what happens.. Hows your car coming along? Quote Share this post Link to post Share on other sites
h100vw 0 Posted March 2, 2004 Hmm, this is getting me thinking now, never reaaly considered touching the engine at all til now! So, do you just fit an exhaust cam in place of the inlet (i.e two 'exhaust' cams fitted), is there no downside to that at all, do you have to adjust the engine settings at all? Is the 50mm manifold better for lower revs range, or across the board better than the 45mm? Finally, where are Stealth, and could no-one else locally (Norwich) do the same work, perhaps a Bosch Ignition agent? Mark Vince at Scole Engineering could do this kind of thing for you. Not that far to Diss.. 50mm mainfold is better for top end which will mean a loss lower down. I would have the cam first. I had one in my Corrado a while ago, It went pretty well. A good boost on the motorway as you didn't need to change to 4th at 70 to get any acceleration. Gavin Quote Share this post Link to post Share on other sites
kvwloon 0 Posted March 2, 2004 Many thanks Gavin, will get in touch with Scole Engineering. Quote Share this post Link to post Share on other sites
h100vw 0 Posted March 2, 2004 01379 740940 Gavin Quote Share this post Link to post Share on other sites
bigben 0 Posted March 2, 2004 Wher is stelth?? Quote Share this post Link to post Share on other sites
h100vw 0 Posted March 2, 2004 http://www.stealthracing.co.uk Just off the M40 North of Banbury Gavin Quote Share this post Link to post Share on other sites
