alip_corrado 0 Posted September 18, 2011 Hi Tim forgot to post in here to say thanks for the coilpack. Arrived promptly and in good working order and good communication. Recommend seller to anyone considering buying from Tim. Ali. Share this post Link to post Share on other sites
kingkenny100 0 Posted September 21, 2011 hi, im interested in the tank straps if they are in good condition and still available? Thanks Share this post Link to post Share on other sites
Jon_vr6 1 Posted September 22, 2011 Have you got the ABS loom in complete uncut order?? Share this post Link to post Share on other sites
alip_corrado 0 Posted September 22, 2011 Hi Tim, received the connectors yesterday. Many thanks again. Ali. Share this post Link to post Share on other sites
TimDoc 0 Posted September 22, 2011 Have you got the ABS loom in complete uncut order?? I prob have, is it the one that comes in from the engine bay on the left and fits into the abs control unit in the left footwell- if not can you tell me exact where it goes from-to or provide the vagcat diagram. Tim Share this post Link to post Share on other sites
Jon_vr6 1 Posted September 22, 2011 I prob have, is it the one that comes in from the engine bay on the left and fits into the abs control unit in the left footwell- if not can you tell me exact where it goes from-to or provide the vagcat diagram. Tim Yeah goes from abs ecu to abs pump and to the wheel sensors and to the fusebox and abs light Share this post Link to post Share on other sites
TimDoc 0 Posted September 22, 2011 Defo got it, will dig it out this weekend and get it packaged up. Tim Share this post Link to post Share on other sites
dragon green 6 Posted September 24, 2011 Mine came this week,thanks for a quick delivery,and as always,very well wrapped. Share this post Link to post Share on other sites
edd 0 Posted September 25, 2011 interested in the ht leads and a clutch master cylinder, (one that attaches through to clutch pedal) if you have still have it. Share this post Link to post Share on other sites
Jon_vr6 1 Posted September 25, 2011 Any news on the abs wiring loom fella? Share this post Link to post Share on other sites
TimDoc 0 Posted September 25, 2011 On the case with all outstanding today - PMs coming your ways re payments etc by this pm Tim Share this post Link to post Share on other sites
TimDoc 0 Posted September 25, 2011 Any news on the abs wiring loom fella? Got it out - is attached to a lot of the power loom for the rest of the engine bay - fans etc, quite heavy as a oner unless you want me to cut the two pieces that join it to the power loom and you can solder it back together?? Let me know and i'll sort out a price for you. Tim ---------- Post added at 02:14 PM ---------- Previous post was at 01:51 PM ---------- interested in the ht leads and a clutch master cylinder, (one that attaches through to clutch pedal) if you have still have it. Both available and for posting tomorrow. Master cylinder £30 HT Leads £5 as advertised - used but still working The whole lot posted for £40 Tim Share this post Link to post Share on other sites
edd 0 Posted September 25, 2011 deal how'd you want paying - paypal?? ill pm postal adress Also dont suppose you have a n/s passenger side front hub all connected i.e. hub/bearing/bearing housing?? All in good working order obviously! Edd Share this post Link to post Share on other sites
Jon_vr6 1 Posted September 25, 2011 Got it out - is attached to a lot of the power loom for the rest of the engine bay - fans etc, quite heavy as a oner unless you want me to cut the two pieces that join it to the power loom and you can solder it back together?? Let me know and i'll sort out a price for you. Tim Give me a price for the lot and then ill cut it down myself if needs be Share this post Link to post Share on other sites
TimDoc 0 Posted September 25, 2011 Give me a price for the lot and then ill cut it down myself if needs be £35 posted as going to loose at least £10 to postage. Tim Share this post Link to post Share on other sites
Jon_vr6 1 Posted September 25, 2011 £35 posted as going to loose at least £10 to postage. Tim Yep sounds good to me fella, ill send payment through paypal gift so as to avoid fees for you PM me fella Jon Share this post Link to post Share on other sites
VWVW 1 Posted September 27, 2011 Hi Tim...responded to your pm regarding rear beam. Will be in Bristol tomorrow after work so not too far away from bath. Share this post Link to post Share on other sites
Portent 0 Posted September 28, 2011 All of them! - name what you'd like - or you can have the lot - make me an offer! Tim The relays I'd be after are: 18, 21, 53, 72, 99, 109, 167 £13 delivered? Share this post Link to post Share on other sites
VR6Pete 0 Posted September 29, 2011 Hi mate, I've got some bad rust on my car around the top of the filler neck / cap behind the petrol flap.... beond rescue so was going to simply weld a new peice of pannel and spray up. I dont suppose you have this available? Share this post Link to post Share on other sites
TimDoc 0 Posted September 29, 2011 Hi mate, I've got some bad rust on my car around the top of the filler neck / cap behind the petrol flap.... beond rescue so was going to simply weld a new peice of pannel and spray up. I dont suppose you have this available? Pete - that is a defo possibility, if in a weeks time noone has piped up and asked for the whole shell then will cut off all the typical rust spots and scrap the rest - this part will come your way. Lets say - Saturday week i start cutting! Tim Share this post Link to post Share on other sites
VR6Pete 0 Posted September 30, 2011 That would be awesome. not entirely sure where the best place would be to cut it, presumable on the rear qtr around that area so ive got stuff to play with when fitting it :) let me know mate :) Share this post Link to post Share on other sites
