classic 0 Posted October 26, 2011 Hello guys, i'm in desperate need of one of these clips that attach the Vacuum actuator + door rod to the door lock, It looks like this: And it needs to be not broken! Quote Share this post Link to post Share on other sites
quicky1980 0 Posted October 26, 2011 Forums from vw, cheap as chips but was a while back. Give them or tps a try. Quote Share this post Link to post Share on other sites
dragon green 5 Posted October 26, 2011 [ATTACH=CONFIG]49854[/ATTACH]Is it part number seven in the pic ? if yes,still available Quote Share this post Link to post Share on other sites
quicky1980 0 Posted October 26, 2011 Stupid mobile phone keyboard. Sentence should have started as, got mine from.... Quote Share this post Link to post Share on other sites
classic 0 Posted October 26, 2011 i'll go into work tommorow and ask, thanks for the help guys! Quote Share this post Link to post Share on other sites
Supercharged 2 Posted October 26, 2011 pennies from VW! Quote Share this post Link to post Share on other sites
24V Renshaw 0 Posted October 26, 2011 I need them too. Anyone got a part number handy save me loading up ETKA. Jay Quote Share this post Link to post Share on other sites
robrado974 1 Posted October 27, 2011 (edited) Part no is 357837083 and 357837084 .Got mine from tps , 51p each . Still have not fitted mine looks like a right pain in the arse. Edited October 27, 2011 by robrado974 Quote Share this post Link to post Share on other sites
tony_ack 0 Posted October 27, 2011 Part no is 357837083 and 357837084 .Got mine from tps , 51p each . Still have not fitted mine looks like a right pain in the arse. It is a bit of a pain unless you have long stick arms. Loosen the door latch mech from the side of the door, attach both of the rods to the clip (obviously you need the door card off), then manoeuvre both the mech and the clip until the clip slides onto the locking latch. Quote Share this post Link to post Share on other sites
robrado974 1 Posted October 27, 2011 The problem i have is mine were broken off . Really need a pick to see which way round they fit . Quote Share this post Link to post Share on other sites
fla 9 Posted October 24, 2016 Just the info I needed. The rod has come out of mine since goodness knows when. Is there a way to do it without taking the door card off? Quote Share this post Link to post Share on other sites
Will.I.Dub 11 Posted October 24, 2016 Just the info I needed. The rod has come out of mine since goodness knows when. Is there a way to do it without taking the door card off? No Quote Share this post Link to post Share on other sites
robrado974 1 Posted October 24, 2016 No , it has to come off Hasan I'm afraid . Quote Share this post Link to post Share on other sites
fla 9 Posted October 24, 2016 Yes you're both right, thanks. Next question, how does the rod actually stay retained in the plastic clip? There is a slot on top but i qould have thought that the bottom hooked end would catch into a recess of sorts? Drivers side by the way. Quote Share this post Link to post Share on other sites
robrado974 1 Posted October 24, 2016 It's a little hard to explain Hasan . I would take a look at the manual or the parts page ?. Sorry mate I would be to long winded and confuse you more !. Quote Share this post Link to post Share on other sites
krishen 2 Posted October 24, 2016 Are these clips still available? Quote Share this post Link to post Share on other sites
robrado974 1 Posted October 25, 2016 I would think so . If you give your local TPS a ring , they will tell you . If not give Heritage a bell . Quote Share this post Link to post Share on other sites
Will.I.Dub 11 Posted October 25, 2016 Next question, how does the rod actually stay retained in the plastic clip? There is a slot on top but i qould have thought that the bottom hooked end would catch into a recess of sorts? Drivers side by the way. The clip has a forked part on it, in the above pic one of the forks is broken off. When the rods and clip are in position the forks stop the rods from coming out of the holes. Quote Share this post Link to post Share on other sites
fla 9 Posted October 25, 2016 Another really fiddly task and yes Rob you're right its not easy to describne how its done. I'll make an attempt here though: remove door card and lock drop pin through top opening with the loop at end pointing to the right (ie towards the door lock) shine some light into the top opening to see the plastic clip and steer the rod into the slot at the top of the clip rotate the rod 90deg anticlockwise for it to now point towards the hole in the plastic clip Carefully manoeuvre the rod back and forth maintaining its position until it pops into the 'locking hole' Hard to take pics because its so dark in that part of the door! Quote Share this post Link to post Share on other sites
