The_Dude
Cupboard clearout - loads of parts inside - No Longer Available
Contact me via PM for quickest reply. Prices do not include postage, photos available on request as I can't be arsed resizing them in this new, wonderful for sale section that we have. :(
Drivers air vent housing 10
Passenger air vent housing 10
Passenger air vent 8
Centre vent (passenger side ) 8
Centre vent (driver side with hole cut for standard gauge) 10
Driver vent 8
Driver vent (hole cut for gauge) 10
Bonnet cable with handle 5
Speedo surround 5
Curved inlet pipe 5
Offside fog 30
Offside fog/indi housing 10
Offside indicator (glass chipped and loose) 10
Drivers fog 30
Drivers indicator (chipped) 20
Drivers fog/indi housing 10
Crack pipe 5
Drivers mirror, moonlight blue 15
Black plastic cover that goes by the mirror but I don't know what its called (1driver 2 passenger I think) 3 each
Fuel filter 5
Oil cooler 5
CL pump and loom 5
Brake fluid reservoir 5
Washer fluid reservoir 5
Power steering fluid reservoir (no cap) 5
Passenger roof grab handle 3
Plastic spark lead guide (2,4,6) 3
Stack mechanical boost gauge 20
Aux belt tensioner 10
Passenger dash undertray 10
Drivers dash fuse box tray 10
Kick panel 10
Another kick panel 10
Thermostat housing with sensors 10
Power steering pump 10
Starter motor 20
Coilpack 30
Random cooling pipe 5
Dashboard 30
Ashtray (used) 5
Heater Loom 5
Wiper Loom 5
ABS Loom 5
Early passenger speaker cover (tabs intact) 15
Interior door handle surround both sides 3 each
Wiper motor and linkage 15
Gearstick surround & boot 10
Centre tray (that gearstick surround clips into) 10
Late standard speaker door tray with speakers, both sides 10 each, 15 pair
Steering column surround 5
Window controller ecu 10
16v badge (flat back) 15
Behind dash heater pipes (all 3) 5
2.5" Stainless Powerflow exhaust, oval tailpipe decat (still managed to pass emissions!)
3 slat badged grill (2 closed) 125 Collection only.
Centre console 2 heater tabs broken just wedge it behind and it stays there, small hole and crack in bottom storage bit. 30
Speedline centre cap, one tab broken 10
List Date: 5/12/2014
For more info, click here to view the original listing: Cupboard clearout - loads of parts inside
This item is no longer available.
ga.aspx?utmac=MO-29521689-5&utmn=1577876528&utmr=-&utmp=ForumThread.html&guid=ON
Mobile friendly version: Cupboard clearout - loads of parts inside
Edited by The_Dude
If it's late model, driver's fog please. And Speedline centre cap, thanks.
I can pay via paypal, not sure how the classified thing works...
Emma
Are these late and fully intact? If so I'll take them please, posted to Glasgow.
Oh and if so, how did you get the fog lights out?
Cheers
Martin
Cheers
Martin
uhhhh, might have screwed up here. I didn't actually check to see if they come out and it looks like a real ballbuster. Sorry dude, going to have to deny you this one as the fogs are pretty hot right now.
Is the abs loom for a vr6 and intact and uncut? I assume this is full loom for pump/abs ecu/abs light/fuse box? If so, how much posted please mate.
Jim do you have the water hose with the one way valve near the throttle body?
Sorry Chris, don't have it.
Boooooo :lol:
No worries mate
Black plastic triangle cover that goes by the mirror but I don't know what its called (1driver 2 passenger I think) 3 each
Are these for the inside or outside of the door please?
Would the '2.5" Stainless Powerflow exhaust, oval tailpipe decat (still managed to pass emissions!) 125 Collection only.' fit a late VR6?
Yes, that's what it came off.
Any chance of a few photos? What condition is it in?
Its in good nick. A bit dirty, but no holes, dents, rust, etc.
do you have the vent that goes between the heater matrix and windscreen plz?
Yes. Do you just need the middle one or all 3?
just the middle bit plz, ive mislaidmy one :-/ is it a single piece or does it connect to another bit which in thrn connects to the actual matrix housing? i cant remember
goes straight on afaik.
not that bit, its the one that goes on the top for the windscreen demist function im sure its a different looking bit. ill try and find a picture
I don't remember seeing that in the pile o'crap that I've got. I'll double check over the weekend but I think you'll have to look elsewhere.
