VAG-hag 0 Posted June 19, 2014 Hi. This is the temp sender cable, who can tell me where the lil stud piece goes? Cheers Quote Share this post Link to post Share on other sites
robrado974 1 Posted June 19, 2014 You will have to elaborate a little more than that Vag . Quote Share this post Link to post Share on other sites
joebloggsVR69 0 Posted June 19, 2014 You mean the one which gives the 'outdoors' temperature on the MFA? That clips inside the bumper IIRC Quote Share this post Link to post Share on other sites
Toad 0 Posted June 19, 2014 Drivers side of the lower bumper grille, there is a little hole it sticks in. Quote Share this post Link to post Share on other sites
Jim 2 Posted June 19, 2014 Drivers side of the lower bumper grille, there is a little hole it sticks in. Correct :) Quote Share this post Link to post Share on other sites
sexybourbon 0 Posted June 19, 2014 All i read was little hole it sticks in ! Am i normal Quote Share this post Link to post Share on other sites
VAG-hag 0 Posted June 19, 2014 Good lord I forgot to add the picture. Dumbass equals me! Quote Share this post Link to post Share on other sites
mic_VR 3 Posted June 19, 2014 The little nubbin just goes into a clip to keep the wire tidy. Quote Share this post Link to post Share on other sites
VAG-hag 0 Posted June 20, 2014 But where is said clip? I can't tell what route it should follow... Quote Share this post Link to post Share on other sites
sexybourbon 0 Posted June 20, 2014 Ill take a look at mine for you today mate , think it just follows the chassis leg then just clips in ill be home soon and on the car so ill take a look Quote Share this post Link to post Share on other sites
VAG-hag 0 Posted June 20, 2014 Nice one dude... I can't see a logical place where the oil white nub goes... Quote Share this post Link to post Share on other sites
seanl82 23 Posted June 20, 2014 Pretty sure it goes right across the front of the block Chris. Just above the oil filter housing and heat exchanger. I can't remember exactly where that clip goes, but it should become clear when it's been routed. Quote Share this post Link to post Share on other sites
seanl82 23 Posted June 20, 2014 Scrub that, it goes across somewhere following the fuel rail, then down the centre of the block to the filter housing. Quote Share this post Link to post Share on other sites
VAG-hag 0 Posted June 20, 2014 Nope, thats the oil temp wire. This is the black water temp wire. Similar looking lil nub though Quote Share this post Link to post Share on other sites
VAG-hag 0 Posted June 22, 2014 Anyone? Its baffling me..... had another look today Quote Share this post Link to post Share on other sites
Toad 0 Posted June 22, 2014 I've got a funny feeling it might fit into a clip that should go round the crack pipe. I've not got that clip and I have a similar looking cable cable tied too it. It's been so long since I've properly been under the bonnet I just can't remember... Soz. Quote Share this post Link to post Share on other sites
Toad 0 Posted June 22, 2014 Finally found it. I think it might be supposed to attach to the plastic bracket on the engine mount that the knock sensors and crank sensor clip to. Mine is just cable tied to that bunch of wires so might possibly have clipped into the original fan cowling if it wasn't supposed to be on that clip. Quote Share this post Link to post Share on other sites
