Ambulancedaz 10 Posted August 9, 2015 Should I be able to hear/ feel my fuel pump running ??? Thanks Darren Quote Share this post Link to post Share on other sites
seanl82 23 Posted August 9, 2015 Yeah, when you turn the ignition on (but not start the car), you should be able to hear a faint hum where its priming. Do it somewhere quiet to minimise background noise if you can. It'll last about 5 seconds or so, so you should be able to make it out if all is well. Quote Share this post Link to post Share on other sites
GreenRado 10 Posted August 9, 2015 (edited) Not while running, as its very quiet compared to an engine. Are you concerned that you can't hear it or that it's too loud? Edited August 10, 2015 by GreenRado Piece of incorrect information Quote Share this post Link to post Share on other sites
Ambulancedaz 10 Posted August 9, 2015 The car died on me today and I had to be towed home she turns over fine but I can't hear the pump. When I put ing on . So pump or fuse 109 ???? Quote Share this post Link to post Share on other sites
seanl82 23 Posted August 9, 2015 67 or 167 is the relay for the fuel pump. The fuse is shared iirc, but can't remember which one it is. Have a look on the front of the fuse cover for the correct number fuse mate. Quote Share this post Link to post Share on other sites
Jon_vr6 1 Posted August 9, 2015 I dont hear the pump a tall even when mine died there was no warning or dodgy noises. Quote Share this post Link to post Share on other sites
fendervg 32 Posted August 9, 2015 You won't hear a VR6 pump prime as it is in the tank - there is no secondary lift unit like on the other cars. You can feel the relay energise if you put your finger on it when you turn on the ignition. 1 Quote Share this post Link to post Share on other sites
Mawrick 0 Posted August 10, 2015 A bit worried about mine nowasays as I can hear it while the car is idling...........can't remember I could hear the pump in the B3 VR6......is it on it's way out ?? Quote Share this post Link to post Share on other sites
fendervg 32 Posted August 10, 2015 It's a VR6? You shouldn't hear it with the engine running, and without, only in the tank area. If it's another Corrado with a two pump system, one of them could have failed, making the other one work harder. Either way a noisy pump is not a good sign. Replace your fuel filter first if you haven't had it done recently - it could be as simple as that. Quote Share this post Link to post Share on other sites
Dox 23 Posted August 10, 2015 I've posted these pics before, my car cuts on low tank around roundabouts due to the pump / swirl pot assy rubber mounts dissolving, as the pump is now resting on the floor of the tank the pump is noisy and can be heard at idle Quote Share this post Link to post Share on other sites
fendervg 32 Posted August 10, 2015 @dox - what part# is your pump btw? Quote Share this post Link to post Share on other sites
Dox 23 Posted August 10, 2015 I've not been well for the last few days, hopefully I'll pull the pump again tomorrow and swap it either for a G60 housing assy and my current pump or the whole pump assy from my storm. Quote Share this post Link to post Share on other sites
Dox 23 Posted August 11, 2015 @dox - what part# is your pump btw? I cant see a part number on it - probably a label removed when fitted? Anything rubber inside the swirl pot / pump assy is just a melted mess, the G60 pump is seized so I've fitted the whole assy from the storm - this pump is noisy, but not too bad, I can hurl the car around roundabouts now with no starvation and once primed the car seems to start better, but its early days. Quote Share this post Link to post Share on other sites
fendervg 32 Posted August 11, 2015 The original VAG or Pierburg parts number for the whole assembly should be on the round white lid that sits under the plastic flange on top of the tank. There may or may not be a part number on the damned pump itself. Thanks for looking - I'll let you know how I get on. My parts contact has asked Pierburg the 3 or 4 bar question and apparently they are pretty good at coming back to him. Best of luck with yours. Quote Share this post Link to post Share on other sites
