Cressa
Headlight adjuster part
If anyone has one please get in touch. If it comes with the housing that's better (mines cracked anyway) as I can swap my lens and reflector over thanks
Cress, they are Absolute sods to remove mate, 99% of the time you so much as try turning the things they crack, believe me, I've done loads..
I'll check again if I have a good housing WITH the horrid manual adjuster still attached.
Thing is that the plastic of the adjuster is just too brittle, guaranteed it'll break if you disturb it but if it's still attached they are normally fine.
If I have the housing( I'm sure I do, somewhere amongst all the other spares) I'll include the two rubber bush things along with the housing.
Get back to you tomorrow morning with more photos.
Edited by VEEDUBBED
Cheers mate. My offside was fine so thought I just had a bad one on the passenger side. ..oh well. Thanks for your time
