Jonny777 0 Posted September 3, 2016 Evening all, I'm after a full conversion to 288mm front brakes for my Rado VR6. Close to West Yorks as possible! Cheers. Quote Share this post Link to post Share on other sites
lilfuzzer 1 Posted September 3, 2016 Shame I have 312 set up. I may also have a 288 set up in my mates unit inside the BlackBerry can check tuesday if you like Sent from my SM-G357FZ using Tapatalk Quote Share this post Link to post Share on other sites
Jonny777 0 Posted September 3, 2016 Shame I have 312 set up. I may also have a 288 set up in my mates unit inside the BlackBerry can check tuesday if you like Sent from my SM-G357FZ using Tapatalk Whats the difference with fitting the 312 as opposed to the 288? You have everything I need to do it? :D Quote Share this post Link to post Share on other sites
lilfuzzer 1 Posted September 3, 2016 I opnly have calipers and carriers you'll need pads and discs too and 6mm washers to space out Quote Share this post Link to post Share on other sites
Jon_vr6 1 Posted September 3, 2016 And bigger alloys Sent from my SM-G900F using Tapatalk Quote Share this post Link to post Share on other sites
Dox 23 Posted September 3, 2016 16 inch plus generally speaking Quote Share this post Link to post Share on other sites
Jonny777 0 Posted September 3, 2016 I've got tons of wheels so that's not a problem. Haha. I know they don't fit under 15s. Pads and discs are easy, how much you after? Is there a thread with How To fit the brakes? Have searched and couldn't find anything! Quote Share this post Link to post Share on other sites
Dox 23 Posted September 3, 2016 http://wiki.the-corrado.net/312mm_brakes.html Quote Share this post Link to post Share on other sites
Jonny777 0 Posted September 4, 2016 Cheers for that Dox, probably a bit too much effort, looking for straight fit really. If anyone happens to have a a 288mm set up I am still interested too! Ideally one that I could pick up Monday/Tuesday! Quote Share this post Link to post Share on other sites
AngusL 10 Posted September 23, 2016 Hi Jonny - I'm in Worksop and have a set of 288 mm calipers with the carriers to fit and pad spring retainers. I have done this upgrade and am still running it. I can't remember why but I ended up with two sets. They are rusty as hell having been cleaned up once but left bare in the garage for about a year - The seals were all good and I'm fairly certain a good cleanup and possibly a service kit and they will be usable again. They were off someone on here via ebay and are Golf MK3 no clue what year from but I don't think it matters. Believe me they made a big difference to my braking but I did upgrade to Stainless braided pipes too. Let me know if you are still looking and you can collect tomorrow if you are in a hurry. £40.00 The rust is free. Get the discs on ebay. Not too expensive but don't buy too cheap. Cheers Angus Quote Share this post Link to post Share on other sites
Jonny777 0 Posted October 16, 2016 Haven't been able to get any of these in the end, so bump for this please! Quote Share this post Link to post Share on other sites
MZpog 10 Posted October 17, 2016 Hi Jonny, I can't help with the conversion but would question if it's worth it for 8mm larger discs. I recently went from 256mm to 280mm and there is a bit better bite to them, but it's only really noticed if pressing on a bit. Quote Share this post Link to post Share on other sites
seanl82 23 Posted October 17, 2016 Having gone from 280mm standard to 288mm - admittedly with braided hoses too, I can say there is a big difference in stopping power. Its not so much the disk size difference as to the pad. Its in the region of 25% addional friction surface that makes the difference in this, and really does help. :thumbright: Quote Share this post Link to post Share on other sites
MZpog 10 Posted October 17, 2016 Having gone from 280mm standard to 288mm - admittedly with braided hoses too, I can say there is a big difference in stopping power. Its not so much the disk size difference as to the pad. Its in the region of 25% addional friction surface that makes the difference in this, and really does help. :thumbright: Then this may be of use well the callipers at least - http://www.ebay.co.uk/itm/288mm-VW-CORRADO-GOLF-CONVERSION-FRONT-REAR-BRAKE-CALIPERS-DRILLED-AND-SLOTTED-/172361850925?hash=item282191202d:g:nvIAAOSwFV9Xyaqd Quote Share this post Link to post Share on other sites
