robrado974 1 Posted May 26, 2019 As far as I know , a small amount of cutting is needed to make these fit . I’ve had electrical problems recently and one of the causes was water getting into the ECU plug . So I was thinking of buying one . How much work is involved chaps ?. Quote Share this post Link to post Share on other sites
Keyo 47 Posted May 26, 2019 Have you got the rear seal in situation at the back of the scuttle panel Rob ? 535819521 Part no 37 on diagram. http://www.oemepc.com/vw/part_single/catalog/vw/markt/RDW/modell/COR/year/1995/drive_standart/76/hg_ug/823/subcategory/151000/part_id/0/lang/e#sec_37 https://www.ebay.co.uk/itm/CORRADO-Rear-Seal-for-rain-scuttle-tray-Corrado-89-95-535819521-/362151353133 Quote Share this post Link to post Share on other sites
robrado974 1 Posted May 26, 2019 Yeah , it’s all in place Keyo . Quote Share this post Link to post Share on other sites
Cressa 44 Posted May 26, 2019 Be nice if it does fit. I was looking at some Rallye golfs that have a full scuttle panel cover, very nice Quote Share this post Link to post Share on other sites
robrado974 1 Posted May 26, 2019 I presume the Oem plastic cover does sit right on the end of the bulkhead. What I mean is the bit where the pointed end is sits close to the wing .so really it only just covers the ECU plug. Quote Share this post Link to post Share on other sites
seanl82 23 Posted May 26, 2019 I haven't done a search Rob, but from memory there are two types (early & late iirc). One of them is a direct fit, the other needs a little cutting to make fit as it interferes with the wiper motor. Quote Share this post Link to post Share on other sites
fendervg 33 Posted May 26, 2019 Go for the thick hard plastic type if you can rather than the more flimsy one - if you get a LHD and a RHD version it's possible to make an almost complete scuttle cover. Alternatively, there are at least three different types of aftermarket one piece panels around, which might save some hassle unless you are trying for an OEM look. Quote Share this post Link to post Share on other sites
robrado974 1 Posted May 27, 2019 Thanks Sean and Fender . Yes I was going for the Oem look , well as much as you can do with a MK2 scuttle. There are only two on Ebay at the moment, one only has one pic the other doesn’t look great. I will take a look else where and see what I can find . Quote Share this post Link to post Share on other sites
fendervg 33 Posted May 27, 2019 Sometimes you can get them new - check with Classic Parts etc., I know they made a batch of them a while back, and I was able to get both types from the dealer around 6 years ago. Quote Share this post Link to post Share on other sites
robrado974 1 Posted May 27, 2019 Thank you , I will take a look . Quote Share this post Link to post Share on other sites
blue95 0 Posted May 27, 2019 I had a right hand drive one on my old Corrado many years ago, never fitted right to be honest, which was a shame. In the end I trashed it for SWG item, if you can get one cheap go for it, else just buy a SWG andmaybe spray matt grey/black for a more OEM look Quote Share this post Link to post Share on other sites
robrado974 1 Posted May 28, 2019 It could be an option, I’m going to carry on looking for a MK2 part first though. Quote Share this post Link to post Share on other sites
