beastie4126 0 Posted March 6, 2011 Refiited the head, cams and drive shafts. Quote Share this post Link to post Share on other sites
shaunVR6 0 Posted March 6, 2011 Took n/s/f wheel off and started the arch cleaning getting ready for the new wheels mmmm Quote Share this post Link to post Share on other sites
krnau 0 Posted March 6, 2011 out wit the old while the new one is waiting :norty:^1000 Quote Share this post Link to post Share on other sites
emu 0 Posted March 6, 2011 took door cards out for cleaning and repainting, one is almost repainted, few more coats and will do, next one tomorrow Quote Share this post Link to post Share on other sites
mjcp 0 Posted March 7, 2011 Whats the new one? Is it *new* or a refurb (looks very well refurb'ed if it is)? Quote Share this post Link to post Share on other sites
James14100 10 Posted March 7, 2011 Fixed the speed sensor so I now have a fully functioning speedometer Quote Share this post Link to post Share on other sites
leeeeshad 0 Posted March 7, 2011 Fixed the speed sensor so I now have a fully functioning speedometer Did it take long? my speedo goes mental occasionally Quote Share this post Link to post Share on other sites
boost monkey 0 Posted March 7, 2011 his was just an unplugged sensor. Quote Share this post Link to post Share on other sites
Laser Mark 0 Posted March 7, 2011 Buggered both rear ABS sensors trying to get them out the stub axels! Well there's another job to do! I DID have some spare cash, it seems to have been swallowed up rather quickly :brickwall: Quote Share this post Link to post Share on other sites
Laser Mark 0 Posted March 8, 2011 Purchaced 2 new ABS Sensors. Thanks to Purple Tom for the heads up on where to get them. Less than £33 each, not bad considering the VW dealer wanted £157 EACH! Also fitted cleaned stub axels, fitted rear disc's and drivers side calipers and carriers. Although not done everything up nice and tight as I need to get everything checked. First time I've done it so want everything double checking, and I can't remember how it came apart :scratch: Quote Share this post Link to post Share on other sites
krnau 0 Posted March 9, 2011 it's a professionally rebuilt one. everything's been replaced (pistons+rings, valves, etc)... :D oh, and it's an ABF. Quote Share this post Link to post Share on other sites
cheesy 0 Posted March 9, 2011 recieved my uprated headlight loom collected a complete b4 sunroof assembly Quote Share this post Link to post Share on other sites
OllieVR6 0 Posted March 9, 2011 Fitted the drivers side coilover and removed the passenger side shock ready for the coilover tomorrow. Got my 2 new rainsport 2s fitted. Quote Share this post Link to post Share on other sites
cheesy 0 Posted March 10, 2011 fitted moon roof Got the glovebox & boot lock to work from the key Fitted new seal to the heater ventilation in scuttle bay Tracked down the abs fault sort of, blown bulb & tested with test lght shows bulb illuminated all the time so need to get that read Quote Share this post Link to post Share on other sites
swiftkid 1 Posted March 10, 2011 Well past week I have been swapping door handles and mechs around. I am now in the possession of 6 door handles and 4 mechs, none of which I can use and I still have a broken drivers side (which means a 6ft+ man climbing in from the passenger side). Also picked up my new wheels, trial fitted them and don't like them so back to square one now. Quote Share this post Link to post Share on other sites
James14100 10 Posted March 12, 2011 Took the G-lader off ready for a rebuild that I'll be doing myself. Also removed the throttle body for porting and polishing and dewedge of small outlet chamber butterfly. I will be doing a progress thread soon with everything I'm doing Quote Share this post Link to post Share on other sites
Rob_B 0 Posted March 12, 2011 Fitted some weitec anti roll bars today. Fitted a fixed steering column earlier this week. Might do a members thread one day! Quote Share this post Link to post Share on other sites
James14100 10 Posted March 13, 2011 Took the cam cover off ready for a respray. Removed all the crappy subwoofer cables. Removed passenger door handle which needs replacing after initial inspection Quote Share this post Link to post Share on other sites
bristolbaron 11 Posted March 13, 2011 Took the 8v daily to ultimate dubs.. still impressed with performance and fuel consumption.. And thought about selling the G60! Quote Share this post Link to post Share on other sites
rado-steve 0 Posted March 14, 2011 Won Best Corrado at UD :) Quote Share this post Link to post Share on other sites
v8rumbler 0 Posted March 14, 2011 Won Best Corrado at UD :) Well done mate!! Any pics? Sent from iPhone 4 using Tapatalk Quote Share this post Link to post Share on other sites
C5 OEM 0 Posted March 14, 2011 Won Best Corrado at UD :) well done mate Quote Share this post Link to post Share on other sites
rado-steve 0 Posted March 14, 2011 Well done mate!! Any pics? Sent from iPhone 4 using Tapatalk Cheers, there is a few here: http://www.flickr.com/photos/40868936@N05 Or this one after i'd cleaned it.... ---------- Post added at 02:07 PM ---------- Previous post was at 02:06 PM ---------- well done mate cheers dude, suprised me TBF! Quote Share this post Link to post Share on other sites
domwells27 0 Posted March 14, 2011 Got my new black sebrings fitted after getting 4 new Toyo T1-Rs for £158 fitted! Oh, and found out my top mounts are loose :suprised: Quote Share this post Link to post Share on other sites
krnau 0 Posted March 14, 2011 dropped the abf engine in, just to realize that PAS pump sits too far from the crank pulley that I'll need a longer belt, as well as PAS Pulley not being aligned with crank pulley and so I'll need to use some washers in order to move it away from the pump.... no comment there...!!!! water pump pulley needs to be mounted the other way round so it lines up with crank pulley. is there anyone who did an abf swap, keeping KR k-jet and all kr pumps etc????????????????????????????????????? I was told it was pretty plug+play but it's not! Quote Share this post Link to post Share on other sites
