quicky1980
Re: Quicky's Corrado - Audi 3.2
loving the choice of wheels :D
are they 5x100?
the dishes suffering from laquer peal?
if they are then i strongly recomend you send the dishes to a specialist
striped mine with nitromors when i got them then sent them off
a guy i know.
came back like this!
Oh no! Really? Whats the best setup then?
Dont know if it helps mate, but mine are 17x7.5 ET30 and i have an easy cm room to spare in the arches. I would have thought ET40 8 inch would fit ok but you may have to roll the arches.
Cool, that does help. Currently I'm running 17x7.5 ET35 wheels all round. Lowered roughly 50mm?? Hard to tell but I have arches rolled anyway and all clear pretty well.
Front (vr6 hubs/wishbones without spacers)
Rear 16v rear cross member with 20mm spacers making ET15 if I understand correctly.
I'm going to get some 20mm spacers and have my fingers crossed.
are they 5x100?
a guy i know.
images deleted
Yeah, I love the look of these wheels, yours are the rarer 4 stud versions mine are 5x100. I was going to refurb them myself but depends who did yours and how much for. Did they do the centres too?
no just the dishes im affraid
the barrels were in real good nik
had to replace the center caps too as they were fcuked!
cost me 20 quid per dish to get them to a perfect mirror finish
tried doing them myself but was a ball ache to get rid of the grainy lines
splitting them down and refitting was fun as never done it before...turned out well though luckily-no leaks :D
i would doubt if an 8in ET40 wheel would clear the suspension.
the only reason for saying it is that an ET40 wheel will be 5mm closer to the suspension (ie. less clearance on the inner side of the wheel, not from the outer side to the arch). and then if its an 8in vs a 7.5in then it is 12-13mm wider overall, or 6+mm wider either side.
so, in total, an 8in ET40 wheel will be 11mm or more closer to the suspension than the ET35 7.5in wheel. arch clearance would be fine with this, and you say they're rolled anyway, but its the other side you need to be thinking about with high offsets - ie clearance on the springs of your suspension.
obviously it partly depends what tyres you're running too and if you have more than about 12mm with at least some suspension compression then you'll be ok, just saying its worth checking thats all. normal ET for an 8in wheel would be more like 32 (or halfway between 30 and 35 as Coullstar was saying.)
Who's the guy? :grin:
Andrew Handshaw Unit 3, Metherell Avenue, Brixham, Devon TQ5 9QB
01803 882130
top bloke
sure he would mind if you sent them in the post
otherwise i just dropped them off in person
:wink:
Will keep him in mind if i get bored of refurbing the ZW1's.
Just checked my front wheel and I seem to have roughly 15mm clearance from rim and strut. Im on coilovers so I may have more clearance?
I will have a think about it and figure out what adaptors to go for.
Had a new part arrive today, been on the look out for one for ages and finally got one........OE centre console gauge. Will get it wired up soon but looks great in the car! :clap:
thanks, im sure i tried a 9mm and 10mm socket but they didnt fit well and did want to risk damaging the chrome bolts. will look again later
just to add some info re sizes and offsets. my wheels are 8" ET35, needed at least 10mm of spacing (i put 15mm on, soon to be 20mm). I'm on coils....
Did your ZW1s come with the factory spacers? If so you should end up with et35. All ZW1s come from the factory as et60, RH just send the right adapter for the car, so if the previous owner specced them for a rado they'll be spacers which give et-25. So you end up with et35 once the adapetrs are on (et60 - 25) if that makes sense.
Any more positive et than 35 and you'll start having issues with the car fouling suspension components, any more negative and the wheels will stick out of the arches quite a bit (I run et35 and the wheel face sticks out a few mm more than the arch but the car is ok legality-wise as the tyre is stretched and therefore the tread sits behind the arch line.
Standard width is 8" and at this width regarding ride height you can run them pretty much fine on the back even slammed but the fronts will rub if your arches are standard and you go low. Be sensible and they'll be fine, run them like I did at Stonor and GTI Fest (see pic) and they'll rub over all bumps and even when you corner...! Hope that helps
thanks Jack, they arent new and didnt come with the standard adaptors. I did just buy some rh spacer, unfortunately now after reading your info I think i may have the wrong spec. have ordered 20mm and 30mm spacer making et 40 and et 30. will just suck it and see when they turn up. My arches are rolled so may help. plus im still on 16v rear cross member which is narrower than the vr6 version so may have some slight differences to you.
Must say your wheels look great against the blue. I have decided after stripping the paint off one ready for polishing to go colour coded with maybe some gold plated bolts. keeping the polished rims obv
what tyre width are you using?
are you sure??
mine have a 35et standard
wow really? Ive always known them to be et 60
Pretty sure all are ET60 then the RH specific adaptors work as mentioned above. Should be fine with a 5mm spacer behind the spacer which will take you back to ET35.
I wouldn't worry too much, just have to see when you get the spacers as you say. With rolled arches et30 should be ok and even et40 might work, but that all depends on the coilovers you're using. As Coullstar recommended though, I'd probably just put a 5mm spacer on there. My tyres are 205/40s, but I'd be interested to see if 215/35s would result in you having more/less tyre rub
well, been a bit lazy and have only stripped one RH wheel down. Took most of the paint off ready to polish up the centres but thinking I may go colour coded....still to decide.
Bought some new suspension mounts/bushes today, hopefully will tighten the handling up even more.
1J0412249 - Bearing
357412331A strut mounting (vr6 version)
191512335 - rear mount
191512333 - rear mount
and the following to help wire up the OE centre console
1JO972704 4 pin plug
000979133E - wire set
Replaced the leaking rear strut yesterday for the MOT later this morning. First one since the 24v swap so am apprehensive but heres hoping
Took it out for a drive yesterday with the new rear bushes and the "cough" jamex rear struts. Handles much better now but is a bit too firm for my aging body so will start to consider what suspension to go for. Would need to try some out first before shedding out on a decent kit. I looked at air ride, but this comes in at £3k!! I like the idea of being low for general driving and then raise it up for bad roads and speed bumps.....may have to make my own hydraulic setup me thinks
Any way, wish me luck today
Good luck for the mot chap.
Had considered air ride for mine cause I want to lower but my estate has massive humps so struggle at the minute to clear them. So air ride was a solution but just too expensive at the minute.
Anyway looks like you have done a good job on the conversion so sure no probs with that :salute:
cheers lifuzzer
Well guys and gals....it failed the MOT :mad2: .....offside parking like not working!......so I went away and sorted it out, took it back and.......it passed! :clap:
The guy testing was very complementary, and we chatted for a bit. A few minor advisories inc slightly corroded pipes so will put that on the list of things to sort out before the next test
What I was most please is the emissions, decatted I got 0.21% CO and 231ppm Hydrocarbons. The max allowed were 3.5% CO and 1200ppm HC! So my worrying about the emission test wasnt needed. :luvlove:
Still not happy with how firm the rear jamex struts are, makes the whole car ride like a go kart. any one got any good sugestions with coilovers that are close to OE comfort? :shrug:
I have heard good things about kw v2 if you adjust the rebound setting slightly they are supposed to be quite compliant. I have never tried them myself though! I am really going to take my time deciding which coilovers to get as i am sure you are aware fen roads are terrible on hard suspension!
cheers lifuzzer
Not sure if its what suits you, but Dukest has Koni TAs and H&R springs and the ride is more comfortable than normal, with the added bonuses of better handling and better looks. Just a thought?
