20vturbo
corrado 20v turbo, finally finished
just read this thread though, god knows how ive missed it... and WOW!!!
bet you cant wait to drive it, such good work keep it up!!
that is looking sweet! how comes you have changed the throttle body? what was wrong with the old one? Will it need recalibrating on the ecu
the old agu throttle body is 2" where as the abf one is 3" so it will flow more air :thumbleft:
i havent talked to qpeng about it yet so im not sure if the ecu will need re-calibrating
i see! i think it will need recalibrating, i had a mk3 8v one to start with but ben @ qpeng said it wouldnt work unless the ecu was recalibrated. Are you selling the old one? i could do with one as my one is ugly lol
Nice work fella 8)
As for the throttle, think its more to do with the throttle position switch and connector that needs to be matched on the ecu & loom.
i have three or four other looms so ill put the right conector on the loom and go from there. its getting custom mapped on a rolling road so if i do need to adjust anything it can be done then.
Mine needs a remap as well TBH, the generic qpeng map is good to get going with but it defo needs a remap.
But thats it will flow more air upto the next restriction which will be the valves, if your not changing/working the head then there wont really be much benefit.
when people put on performance intake manifolds too flow more air they usually dont bother doing any headwork beacuse the 12 intake valves seem to more than able to handle the extra air flow.
this is the first load of stainless steel mikalor clamps. these one are for the smaller pipes around the block
dont mind the wiring, its not connected i just left it on the engine to keep it safe
heres some of them fitted to the engine
still looking good bud still the best thread on the forum and you have some great skills
i sandblasted the servo
the master cylinder
the front engine mount support
this is the radiator support before i sand blasted it
everything painted
the loom for the headlights was in a compete mess so i replaced some wires and checked the continuity of everything
then wrapped it up
i got the old brake resivoir cleaned up which took forever
all in the bay
Just shaking my head in pure disbelief at the work done and skills/knowledge shown. Good luck with the rebuild keep the posts coming
what did you clean the brake reservoir with buddy? cant wait to see this finished...
i left it in the parts washer over night and then flushed it out with a heavy duty alloy wheel cleaner to get the black gunk off it
im in california at the moment so i wont update the thread until i get home. im bringing home loads of tasty bits for the corrado so i will have plenty of new parts to fit :D
ALL TOGETHER NOW.......................OH WHY ARE WEEEEEEEEEEEE WAITING HO WHY ARE WEEEEEEEEE WAITING!
Give the boy a chance, we are all waiting to see this thing of perfect engineering. :D
But yes we all need an update PLEASE !
i haven't updated the thread in awhile because i have been in california so heres a pic of some of the stuff i brought home for the car
while i was there i got to have a look around one of these (thats me sitting in it)
then we just happened to be passing this place
and luckely there was a show with stuff like this in it
and the famous cork screw
