krnau 0 Posted February 7, 2011 LOL!!! Probably one that everyone knows is when turning on the car, press and hold the mfa down then turn the ignition, et voila! secret mfa with constantly updating mpg. Last time I tried to do that, all relays started to click like hell when I cranked the engine LoL. So i never did it again.... it used to work a while ago though... Quote Share this post Link to post Share on other sites
eugopnosaj 0 Posted February 8, 2011 Thats the B3 Passat item if I am not mistaken.. If you have genuine fit electric windows, not all UK 'rados did, then the control module is the brain for both the central locking and the windows/sunroof. As I said originally, if your windows one touch down on both driver and passenger and one touch up on the driver then you will not have any form of closure on the sunroof. If your windows one touch down on both sides but not up then you will have sunroof closure. As for getting full closure inc sunroof on a car without that option I don't know - depends on the alarm fitted and you would need to get the alarm to understand where the sunroof was to send the correct close pulse - tilted or fully back. Not on the earlies my friend, unless you retrofit Relay #99. I think mine is special, I've got an early with the variable intermittent wipe and I'm pretty sure the relay is standard AND I've got full sunroof closure with one touch open both sides and one touch closure on the drivers side Quote Share this post Link to post Share on other sites
boost monkey 0 Posted February 9, 2011 I had one touch closure on a mk2 golf, so I can't see that it's a very new thing. Pretty sure the relay is late only, but hey it's only a relay. Anyone could stick it in! Quote Share this post Link to post Share on other sites
Yandards 0 Posted February 9, 2011 I had one touch closure on a mk2 golf, so I can't see that it's a very new thing. Pretty sure the relay is late only, but hey it's only a relay. Anyone could stick it in! Yep its just the relay that does the intermitant wiper thing. Eugopnosaj, I would love to know what the part number of your central locking control module it, should be behind the drivers side rear passenger door card. Quote Share this post Link to post Share on other sites
corozin 0 Posted February 9, 2011 Curiously I have one touch windows on my '93 VR6 but the full closure works for both windows and Sunroof. I think your manual has an error Yan :) Second point to add re the intermittent wipers, the maximum time is 22s from recollection. Doesn't sound like much but it is on the road. The way I've always set the interval is to wait until the rainfall interferes with the vision and then hit the second wipe (setting the interval). My new added pub fact for the thread is that if you have VR6 with the 205 width wheels, the bucket seats in the rear are actually the perfect size for carrying four wheels upright. It's almost like it was designed that way... John Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted February 9, 2011 Yep, but 8x17s are a bit of a stretch though. My 94 L also has one touch down on offside and nearside, one touch up offside only, and full closure sunroof. And did you know, if you switch to MFA 2, hold the reset button in whilst raising the spoiler with the switch, it dispenses a Capuccino from a small hole in the glovebox? Quote Share this post Link to post Share on other sites
psiburr 0 Posted February 9, 2011 And did you know, if you switch to MFA 2, hold the reset button in whilst raising the spoiler with the switch, it dispenses a Capuccino from a small hole in the glovebox? be careful though cos the earlier models just have a boxing glove on a spring :) Quote Share this post Link to post Share on other sites
corozin 0 Posted February 9, 2011 My Corrado has extra sensory perception. It can sense with uncanny accuracy how much cash I have saved up and magically help itself to all but a few quid of that amount every month. Does anyone else have that feature? I looked on the boot sticker but I can't find the option code for it anywhere. Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted February 9, 2011 You have to look carefully, but the option code is there. It's right in the bottom right hand corner in the 'UK only' designation options list - GAYC. Gimme All Your Cash. Now I realise this code reads as Gay C[orrado], which I can only assume was the German's attempt at humour! Quote Share this post Link to post Share on other sites
mjcp 0 Posted February 9, 2011 You have to look carefully, but the option code is there. It's right in the bottom right hand corner in the 'UK only' designation options list - GAYC. Gimme All Your Cash. Now I realise this code reads as Gay C[orrado], which I can only assume was the German's attempt at humour! The Homburg edition ;-) Quote Share this post Link to post Share on other sites
VRTrickster 0 Posted February 9, 2011 Hmmm......just turned car off and removed keys with Headlights still on (by mistake) and heater fan still ran. Tried the same later and after a couple of seconds fan stopped. Blocks, not another ignition switch gone, or possibly load reduction relay!! I swear my car is reading this topic My heater stays on if I have the lights on, is that normal? Quote Share this post Link to post Share on other sites
Critical_Mass 10 Posted February 10, 2011 NO ^^^ :lol: Quote Share this post Link to post Share on other sites
yacobwood 0 Posted February 10, 2011 The ashtray is perfect for holding an AUX or Satnav cable away from your gearstick :) Quote Share this post Link to post Share on other sites
fla 9 Posted February 10, 2011 The ashtray is perfect for holding an AUX or Satnav cable away from your gearstick :) good idea! Thanks for that. Quote Share this post Link to post Share on other sites
dragon 0 Posted February 10, 2011 The ashtray is perfect for holding an AUX or Satnav cable away from your gearstick :) It works i do that too , also works in a b4 passat :lol: Quote Share this post Link to post Share on other sites
krnau 0 Posted February 10, 2011 I use the glove box for this LoL Quote Share this post Link to post Share on other sites
Jim 2 Posted February 11, 2011 The ashtray is perfect for holding an AUX or Satnav cable away from your gearstick :) I always use the glovebox door / flap for that :) Quote Share this post Link to post Share on other sites
corozin 0 Posted February 11, 2011 I use the glove box for this LoL I use the ashtray myself. Time for a poll! Poll! Poll! Poll! :) Quote Share this post Link to post Share on other sites
stretch. 0 Posted February 11, 2011 The ejector seat handle (height adjuster...) has a perfect space to store a 500ml bottle wedged in between the lever and floor (or seat... can't remember which) Pretty handy. Quote Share this post Link to post Share on other sites
paddy26 3 Posted February 11, 2011 from what i can remember. if you have the keys out of the ignition. put your headlights on and pull the full beam stick the heaters will come back on. when i get home im gonna try it and work it out again! completly useless but one of those things! I believe this was used in the factory for testing purposes. Quote Share this post Link to post Share on other sites
dragon green 5 Posted March 12, 2011 Here's a simple one,the bracket by the washer bottle has a crease in it, just right for the lid to sit in why you refill the bottle ! Quote Share this post Link to post Share on other sites
