VAG-hag 0 Posted June 12, 2014 (edited) Am I right in thinking that these are no longer available from dg? Really keen to get hold of some..... Edited July 31, 2014 by VAG-hag Quote Share this post Link to post Share on other sites
Jon_vr6 1 Posted June 12, 2014 Maybe crazydave might be able to help Quote Share this post Link to post Share on other sites
Sean_Jaymo 0 Posted June 12, 2014 He's been asked before and I believe he said he wasn't too interested... Quote Share this post Link to post Share on other sites
sexybourbon 0 Posted June 12, 2014 Adrian metal man Quote Share this post Link to post Share on other sites
VAG-hag 0 Posted June 13, 2014 Adrian metal man doesnt have a lazer Matty..... :( If Dave or Graham are not going to recreate I may ask for the drawings. Quote Share this post Link to post Share on other sites
Sean_Jaymo 0 Posted June 13, 2014 (edited) This conversation came up a while back and as far as I am aware, neither of them really want anything to do with this forum. I hope things may have changed and that they are willing to help. This is the old post asking the same question http://the-corrado.net/showthread.php?t=82829&page=4 Edited June 13, 2014 by Sean_Jaymo Quote Share this post Link to post Share on other sites
sexybourbon 0 Posted June 13, 2014 I thought he had lazer eyes , ill stop clogging up your **** now Quote Share this post Link to post Share on other sites
VAG-hag 0 Posted June 13, 2014 cheers Sean, I will give Dave a call. Quote Share this post Link to post Share on other sites
seanl82 23 Posted June 13, 2014 Personally, I think he over-reacted and was a little childish about it. :| Quote Share this post Link to post Share on other sites
ChrisL 20 Posted June 13, 2014 If someone has a set for a template I have access to CAD, loads of 316L stainless steel and a laser profiler. I'd be happy to sort some out. Quote Share this post Link to post Share on other sites
swiftkid 1 Posted June 13, 2014 I've just drawn the brackets up in CAD (well inventor), just wanting to double check the fitment before anything is made properly. I've designed them based on a 9" and 11" fan which I presume is what most people go for? Quote Share this post Link to post Share on other sites
Sean_Jaymo 0 Posted June 13, 2014 Crazy Dave himself had 11 and 6 inch fans so that he had extra clearance for his short runner intake. Just shows that those 2 sizes could keep a vr6t cool so anything above that can only be a good thing! Quote Share this post Link to post Share on other sites
VAG-hag 0 Posted June 13, 2014 the set I have borrowed are for 9"/11" & are the ones I had in mind. I believe Dave made the 11/6 ones as a one off for his short runner, as you say Sean. I am sure that 9/11 setup using spal or similar will be more than sufficient! So Chris L & Swiftkid, whats the chances of recreating - very excited by this!! Quote Share this post Link to post Share on other sites
ChrisL 20 Posted June 13, 2014 If I can get a copy of the drawing I can get some profiled. 316L stainless so never rust!! Quote Share this post Link to post Share on other sites
Tigerfish 10 Posted June 13, 2014 I'd be interested in a set of these too. Quote Share this post Link to post Share on other sites
Sean_Jaymo 0 Posted June 13, 2014 These are the "very basic" drawings I sent to SwiftKid a week or 2 ago for him to have a base for his drawings. I'll add them here incase anyone else finds them useful. They are based on the OEM supply Denso Marston Radiators and the Revotec Fan I have. Other fans and radiators probably won't work the same. Quote Share this post Link to post Share on other sites
VAG-hag 0 Posted June 13, 2014 Swiftkid, if I get permission to send the set I have borrowed to you to draw up or Chris do you know a guy who can draw them from an original? Quote Share this post Link to post Share on other sites
ChrisL 20 Posted June 13, 2014 Chris, If you can send me them I can draw them up, alternatively lay them on paper and trace them and post me that. Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted June 13, 2014 I bought one of the sets of brackets from Crazydave, have them sat at home, i also do CAD so could draw them up if required. I've been too busy doing other bits to sort out any fans yet. Quote Share this post Link to post Share on other sites
ChrisL 20 Posted June 13, 2014 I bought one of the sets of brackets from Crazydave, have them sat at home, i also do CAD so could draw them up if required. I've been too busy doing other bits to sort out any fans yet. Can you email me the cad file Jim and I'll get some profiled? Quote Share this post Link to post Share on other sites
fla 9 Posted June 13, 2014 i have two 11" fans on mine so perhaps you could do one based on that as an option as well? Quote Share this post Link to post Share on other sites
swiftkid 1 Posted June 13, 2014 (edited) If Chris or anyone else is wanting to make them and there is a demand I'm happy to draw them up, revotec have dimensions on their website I have used for the brackets. My radiator is out at the moment so I'll get some more dimensions tomorrow. Like I said, I've got them drawn up but I want to check they are correct size before I send the drawing out. It will be in any format you want, it's drawn in 3d so ipt, dwg, dxf etc Edited June 13, 2014 by swiftkid Quote Share this post Link to post Share on other sites
ChrisL 20 Posted June 13, 2014 I can get some made, there may be a small lasering charge depending on how many want them but the material will be free. A dwg file will be fine for me. Quote Share this post Link to post Share on other sites
fla 9 Posted June 13, 2014 I can get some made, there may be a small lasering charge depending on how many want them but the material will be free. A dwg file will be fine for me. Chris that's very kind of you, i would be interested in one if you manage to go ahead with this. Quote Share this post Link to post Share on other sites
ChrisL 20 Posted June 14, 2014 Chris (VagHag) is sending me the templates so I can get them drawn up and a set lasered. If anyone wants any they could put their name on here and I can get more sorted. Quote Share this post Link to post Share on other sites
