Chuggs1
Wheeler Dealers
AN EXCELLENT BIT OF SOFTWARE for grabbing youtube videos etc and allowing you to save them to your device.
http://clipgrab.org
Go to that link and select English as language. Then download the software (FREE). Now copy and paste the youtube address into the search bar and Grab Clip (Select mp4 Format).
You will have in a few minutes the entire video saved to your hard drive for your viewing pleasure.
Edited by kdub
  Dox said:
Yes underneath, but around the side and up onto the cylinder head?
One of their better shows or it could be rose tinted glasses.
Was the car bought off pistonheads? I seem to remember the pics from the advert
Dox - yes it was the PistonHead shed of the week
http://www.pistonheads.com/regulars/ph-features-sheds/shed-of-the-week-vw-corrado-vr6/31454
Out of interest - can anyone advise - my ABS light comes on but only 10% of the time - most the time its off - any ideas what this might be? Is it likely to be wiring or sensor - would have thought if its the pump it would come on most of the time?
most likely sensor..... do as edd did put a volt metre across the terminals.... but don't measure the voltage like they did on the telly but resistance.... the lowest reading should be the dodgy one.
Sensors aren't £3 either.
It could be anything, mines had sensors, a used pump, new bulb in the light unit and I still have intermittent issues with another sensor and the pedal sensor on the servo. I'll be having another go at it over winter once sorn
Mine does scan with VCDS BTW
If yours is a later car I fairly sure that you can plug into the diagnostic port. My local garage (not a VW specialist) has the equipment and traced the fault to the brake pedal position sensor in the master cylinder. Like yours this was an intermittent fault, but showed 50% of the time.
Had a few crappy days with my car, and certainly wasn't in a good mood with it by the time I got home last night..... might watch this again when it's running slightly better and I'm feeling the love a bit more.
Thanks guys - think I also saw someone mention possible wiring faults but cant remember where the wiring fault was - just under the car somewhere lol?!
Mine had the light permanently on when I bought it, a wheel sensor got me an mot, then the bulb blew and I replaced it. Inlet / outlet valve faults in the pump so I replaced the pump, then more intermittent faults show up with other sensors etc......
ABS is just a pita - mine has a temp related fault and a couple of errors on the pump valves. Could be the wiring, pump itself, or the PCB heating up due to a cracked case (that's my idea now after seeing the program), so will be on the look out for a pump that I can get reconditioned if anyone has one.
I did like the vinyl stickers for refurbishing the front red VR6 badge - I wonder did they get them from Trimsport?
That was a good way of sprucing up the badges, just need to find the supplier now.
I thought it was quite a good idea, but also wouldn't be too hard to do it with paint and flat it back then polish up. I thought if you wet a sponge with red paint and then pressed the badge onto it a few times to build up the paint you wouldn't need a steady hand or any masking.
Shame i don't want a red badge. I have a spare, might paint that and sell it for £100 :lol:
I painted my silver badges red . I used a quality artists brush . Once they are painted and flattened back , they look great .
I got a quote for an ABS pump recon from BBS Raman about a year ago. Iirc it was around the £150 mark but cant be sure. Turns out my pump was good after all anyway.
  delfinis38 said:
"They are awesome these motors"
Yep they are awesome . I never leave for work in the morning , without looking back at my car sat on the drive . The body lines are perfect . And the VR roar always makes me smile , they sound amazing .
  Chuggs1 said:
How did you find out it was good... Did they test it?
No I didn't send it off in the end. I didn't realise initially that you cannot reset ABS error codes on VCDS from the main page. You have to go into the ABS specific menu and do it there. Once I'd done that, there was no other fault code beside the pedal position sensor which fixed the problem. :)
Need to get myself a code scanner to scan and or reset .... Any recommendations or links to decent scanners to buy....Not too pricey
Chuggs you on 56k yet :) sorry no help just read the tag line.
