Dox 23 Posted October 27, 2022 (edited) Dave16v recently bought a pump replacement for around £70? halfway down the page Edited October 27, 2022 by Dox Quote Share this post Link to post Share on other sites
Crasher 3 Posted October 28, 2022 Remember pre 95 VR6 Golf and Corrado are 4 Bar and post 95 Golf VR6 3Bar. Quote Share this post Link to post Share on other sites
fendervg 32 Posted October 28, 2022 I think the moral is still to stump up for the VDO pump if you can find one. Quote Share this post Link to post Share on other sites
ABV-VR6 12 Posted October 28, 2022 3 minutes ago, fendervg said: I think the moral is still to stump up for the VDO pump if you can find one. Yes I agree and that's where I am leaning as well. I don't want to cheap out especially on this part. There's lots of VDO for sale on ebay, just twice as expensive than the others. Am I right to think the factory sender clips right into the VDO swirl pot or need a VDO sender? That's one of the thing I'm not 100% sure... Quote Share this post Link to post Share on other sites
ABV-VR6 12 Posted October 28, 2022 22 minutes ago, Crasher said: Remember pre 95 VR6 Golf and Corrado are 4 Bar and post 95 Golf VR6 3Bar. Thanks, I know for sure I have a 4 Bar system. Quote Share this post Link to post Share on other sites
Crasher 3 Posted October 29, 2022 I use the Febi 4 Bar unit and it is fine. Quote Share this post Link to post Share on other sites
ABV-VR6 12 Posted December 11, 2022 On 4/23/2019 at 6:25 AM, fendervg said: If your sender is working fine and is the correct late one for the VDO pump body, I would just swap it over - they tend to be pretty clean sitting in petrol all day long. Just be careful when removing it from the old swirl pot, as sometimes the plastic can be brittle and breaks easily. or for peace of mind and at that price I'd get a new one (I had to anyway as mine was a Pierburg) and keep it as a spare or give it to someone else who is upgrading their pump. Fen, Before I commit can I please have your confirmation that I understand correctly? -On a late 95 VR6 with a 1H0919651Q, if I swap the swirl pot for a VDO E22041060Z, I CAN reuse the same fuel sender the car came with 535919673C and it should technically be in good shape. -If I decide to buy a new sender, either oem 535919673C or the VDO 221833002011Z are the two options. Do I get this right? Thanks for your time! Quote Share this post Link to post Share on other sites
fendervg 32 Posted December 12, 2022 Hi - a late 95 car should already have a VDO pump in it, as the Pierburg was only used for about 18 months for the early VRs. Your fuel gauge sender and float should just swap straight over on to a new VDO pump or swirl pot. 1 Quote Share this post Link to post Share on other sites
ABV-VR6 12 Posted December 13, 2022 On 12/12/2022 at 3:23 AM, fendervg said: Hi - a late 95 car should already have a VDO pump in it, as the Pierburg was only used for about 18 months for the early VRs. Your fuel gauge sender and float should just swap straight over on to a new VDO pump or swirl pot. Thanks so much for sharing the knowledge, now I know for sure what I need and better be at this price! Cheers Quote Share this post Link to post Share on other sites
fendervg 32 Posted December 14, 2022 No worries - are you buying the full pump and swirl pot? I may have some pics that show the VDO setup - leave it with me Quote Share this post Link to post Share on other sites
ABV-VR6 12 Posted December 14, 2022 27 minutes ago, fendervg said: No worries - are you buying the full pump and swirl pot? I may have some pics that show the VDO setup - leave it with me Yes mate, pump and swirl pot. I thought it was almost impossible to buy just the pump. This is what I found the cheapest and will buy. Cheers! Quote Share this post Link to post Share on other sites
fendervg 32 Posted December 14, 2022 That's the one - so from a late car running the VDO originally the sender will just swap over on to the new swirl pot housing. Quote Share this post Link to post Share on other sites
ABV-VR6 12 Posted December 14, 2022 7 minutes ago, fendervg said: That's the one - so from a late car running the VDO originally the sender will just swap over on to the new swirl pot housing. That's great, thank you for confirming this I appreciate it! Quote Share this post Link to post Share on other sites
fendervg 32 Posted December 15, 2022 Here’s some photos of the VDO set up: Quote Share this post Link to post Share on other sites
mnmv12 2 Posted December 15, 2022 Ordered one from these guys recently and they responded to all my questions to confirm VAG/VDO part numbers , arrived all ok albeit it took a month to actually arrive. Quote Share this post Link to post Share on other sites
ABV-VR6 12 Posted December 15, 2022 Thanks guys for the pictures and the link. I guess I better shop around! It's "funny" how in the US, they are advertised as VR6 2.8, I thought the pump would be different since those are not a 4 BAR like the ABV? Quote Share this post Link to post Share on other sites
fendervg 32 Posted December 15, 2022 2.8 pump would be 3 bar - but runnning a higher pressure pump would work fine as the fuel pressure regulatero would take care of the difference - not so convinced it would work the other way around though. Quote Share this post Link to post Share on other sites
ABV-VR6 12 Posted December 15, 2022 57 minutes ago, fendervg said: 2.8 pump would be 3 bar - but runnning a higher pressure pump would work fine as the fuel pressure regulatero would take care of the difference - not so convinced it would work the other way around though. Reading this, that makes a lot of sense yes! Quote Share this post Link to post Share on other sites
mnmv12 2 Posted December 15, 2022 I did check with Pelican that it was a 4 bar pump and they confirmed it was. Bought from the US in the end after getting fed up of Uk supplies saying they had them in stock taking the order then 3 weeks later saying they don’t. Quote Share this post Link to post Share on other sites
ABV-VR6 12 Posted December 16, 2022 7 hours ago, mnmv12 said: I did check with Pelican that it was a 4 bar pump and they confirmed it was. Bought from the US in the end after getting fed up of Uk supplies saying they had them in stock taking the order then 3 weeks later saying they don’t. Thanks for letting me know! I may contact them to see how much they would charge me for shipping, the price is definitely good! Cheers Quote Share this post Link to post Share on other sites
mnmv12 2 Posted December 16, 2022 Just remember you will need to pay the Vat on top, the UK shipping agent will send you the bill. Quote Share this post Link to post Share on other sites
ABV-VR6 12 Posted December 16, 2022 1 hour ago, mnmv12 said: Just remember you will need to pay the Vat on top, the UK shipping agent will send you the bill. No VAT for me mate but I'll still pay duty fees and big shipping cost as I am in Canada! Quote Share this post Link to post Share on other sites
daves16v 1 Posted January 9, 2023 On 10/29/2022 at 12:27 PM, Crasher said: I use the Febi 4 Bar unit and it is fine. Where from please? Quote Share this post Link to post Share on other sites
