Keyo 47 Posted December 21, 2020 (edited) On 12/21/2020 at 7:48 PM, 1xshaunx1 said: I think I have fitted with a copper washer before though I fitted Wahler fan switch 6017.95D If you look at NO 9 the one with B last digit (late vr) there is no evidence of an O ring for a VAG one. https://volkswagen.7zap.com/en/rdw/corrado/cor/1995-76/9/959-238000/#9 Edited December 21, 2020 by Keyo Quote Share this post Link to post Share on other sites
1xshaunx1 27 Posted December 21, 2020 On 12/21/2020 at 7:52 PM, Keyo said: If you look at NO 9 the one with B as last digit there is no evidence of an O ring for a VAG one. https://volkswagen.7zap.com/en/rdw/corrado/cor/1995-76/9/959-238000/#9 True, but I think it better if one is fitted or something in the thread otherwise your relying on the brass to aluminium insert thread to seal it, hopefully forever. Quote Share this post Link to post Share on other sites
Keyo 47 Posted December 21, 2020 On 12/21/2020 at 7:58 PM, 1xshaunx1 said: True, but I think it better if one is fitted or something in the thread otherwise your relying on the brass to aluminium insert thread to seal it, hopefully forever. If it leaks I will get some sealant string but VW must of tested it from factory otherwise they would of supplied a washer - the issues might arrive from housing it in an aftermarket rad. Quote Share this post Link to post Share on other sites
fendervg 33 Posted December 21, 2020 There was never a seal or o-ring on mine, and none of the ones I bought had one. I can't see it doing any harm though. Quote Share this post Link to post Share on other sites
Cressa 45 Posted December 22, 2020 I thought it strange that mine didnt have one. To be on the safe side I added some pfte tape and have never had a leak Quote Share this post Link to post Share on other sites
Cressa 45 Posted December 22, 2020 https://www.ebay.co.uk/itm/324426439089 Vr6 radiators are suddenly like buses 😂 Quote Share this post Link to post Share on other sites
seanl82 23 Posted December 22, 2020 On 12/22/2020 at 12:48 PM, Cressa said: https://www.ebay.co.uk/itm/324426439089 Vr6 radiators are suddenly like buses 😂 Didn't last long! Quote Share this post Link to post Share on other sites
ger040 3 Posted December 22, 2020 On 12/22/2020 at 7:16 PM, seanl82 said: Didn't last long! On 12/22/2020 at 12:48 PM, Cressa said: https://www.ebay.co.uk/itm/324426439089 Vr6 radiators are suddenly like buses 😂 i bought it Quote Share this post Link to post Share on other sites
Cressa 45 Posted December 22, 2020 Glad it went to a forum member 👍 Quote Share this post Link to post Share on other sites
Keyo 47 Posted December 22, 2020 On 12/22/2020 at 7:26 PM, ger040 said: i bought it Looks the same as mine- you got that for half price you lucky bugger. 🙄 Quote Share this post Link to post Share on other sites
ger040 3 Posted December 22, 2020 On 12/22/2020 at 7:46 PM, Keyo said: Looks the same as mine- you got that for half price you lucky bugger. 🙄 The seller is in the motor trade and had it for his own car that he had and its german !! Not very often you get anything corrado related for decent money these days!! Quote Share this post Link to post Share on other sites
ger040 3 Posted December 22, 2020 On 12/22/2020 at 7:27 PM, Cressa said: Glad it went to a forum member 👍 thanks starting to collect parts for a future project Quote Share this post Link to post Share on other sites
Dox 26 Posted December 23, 2020 On 12/22/2020 at 12:48 PM, Cressa said: https://www.ebay.co.uk/itm/324426439089 Vr6 radiators are suddenly like buses 😂 Has an ECP part number on it, googled it https://www.clubgti.com/forums/index.php?threads/corrado-passat-vr6-front-rad-and-fans.84646/ Quote Share this post Link to post Share on other sites
Keyo 47 Posted December 23, 2020 On 12/23/2020 at 12:07 AM, Dox said: Has an ECP part number on it, googled it https://www.clubgti.com/forums/index.php?threads/corrado-passat-vr6-front-rad-and-fans.84646/ Euro car parts - I wonder if they still sell one- Heritage was selling ine aswell that looked the same as the Dasis but it was £200 I think x bit iof a mark up. Quote Share this post Link to post Share on other sites
Keyo 47 Posted December 24, 2020 (edited) First drive in the VR today with the new Dasis radiator fitted- please note my old rad was missing the plastic airducts but sourced some used ones to fit on the new rad. Temp today 5 degrees - car ran top at 82 degrees - got home to inspect radiator and no leaks what so ever- car is running cooler . Verdict so far excellent. Edited December 24, 2020 by Keyo Quote Share this post Link to post Share on other sites
1xshaunx1 27 Posted December 24, 2020 On 12/24/2020 at 1:27 PM, Keyo said: First drive in the VR today with the new Dasis radiator fitted- please note my old rad was missing the plastic airducts but sourced some used ones to fit on the new rad. Temp today 5 degrees - car ran top at 82 degrees - got home to inspect radiator and no leaks what so ever- car is running cooler . Verdict so far excellent. What was your oil temp? Quote Share this post Link to post Share on other sites
seanl82 23 Posted December 24, 2020 (edited) I think despite it being awfully made and leaking, I doubt you'll see a great deal of difference in temps. As above, oil temp is what you need to monitor really. The thermostat opens at 87 degrees so water temps shouldn't really rise above that unless there are genuine problems or it's really hot weather. You don't really want a standard motor running much lower either - even though some fit lower temp stats - as the oil won't be in the optimum performance range and the map will be compensating to those temps so over fuelling. Edited December 24, 2020 by seanl82 Quote Share this post Link to post Share on other sites
fendervg 33 Posted December 24, 2020 Where are you measuring coolant temperatures to 1 degree accuracy? Only way to do that is to read off the ECU - even the MFA oil temps tend to jump up in leaps of 2 or 4 degrees at a time. 90-100 is decent coolant temp, remember that coolant will boil at a lot higher than pure water. Quote Share this post Link to post Share on other sites
1xshaunx1 27 Posted December 24, 2020 FYI at 5 degrees outside Temp under normal driving, not track/spirited yours would seem normal water temp wise you shouldn’t hear the fans kick in. just wondered what the oil temp was Quote Share this post Link to post Share on other sites
Keyo 47 Posted December 24, 2020 (edited) I was only looking at the water temperature on the cluster and concentrating on that to make sure the cooling system was staying with in tolerance levels - more over checking there were no leaks and working as it should. The car has had all new genuine coolant senders and fan switch - also a new water pump + thermostat + engine rebuild not sure that would make difference = car was running cooler then I remember ever has done then before - I will study oil temperature next time. I left the car run on the drive when I got home to check the fans came on which they did. I think putting on the factory radiator trims on helped as I believe it ducts the air into the radiator. You can still buy one trim new but it aint cheap - the other side is obsolete. So yes Sean my fans did not kick in today whilst driving. Edited December 24, 2020 by Keyo Quote Share this post Link to post Share on other sites
fendervg 33 Posted December 24, 2020 The coolant gauge in the cluster can't really be considered accurate at all - the tech is too old, as are the gauges themselves - the only real way to tell is to plug in VCDS and compare the reading there with the gauge - the ECU takes its signal from the blue temp sender in the thermostat housing. I think the dash gauge should be read as cold=>warm=>worried=oh sh*t! Newer cars are designed so that the temp needle will sit centered on 90 no matter what when warm, unless something is seriously wrong with the cooling system - I think this is done so as not to alarm drivers if the needle fluctuates too much. My other car does not even have a temp gauge any more, just a warming up light, and then a warning lamp for over heating. Quote Share this post Link to post Share on other sites
Keyo 47 Posted December 24, 2020 (edited) My gauge cluster in new tbf. Got a new circuit board last year from classics. . Edited December 24, 2020 by Keyo Quote Share this post Link to post Share on other sites
Dox 26 Posted December 24, 2020 On 12/24/2020 at 6:24 PM, fendervg said: The coolant gauge in the cluster can't really be considered accurate at all - the tech is too old, as are the gauges themselves - the only real way to tell is to plug in VCDS and compare the reading there with the gauge - the ECU takes its signal from the blue temp sender in the thermostat housing. I think the dash gauge should be read as cold=>warm=>worried=oh sh*t! Newer cars are designed so that the temp needle will sit centered on 90 no matter what when warm, unless something is seriously wrong with the cooling system - I think this is done so as not to alarm drivers if the needle fluctuates too much. My other car does not even have a temp gauge any more, just a warming up light, and then a warning lamp for over heating. I had a conversation with someone in design at LR who confirmed what you say above re manufacturers fixing temps at 90 degrees until the point of boiling over. I’ve witnessed this in one of my own cars that went fro 90 - 130 instantly as it puked pink coolant all over a traffic jammed multi storey car park one summer. I’m not sure how relevant this is to Corrados but mk4s definitely have this strategy From the factory. Quote Share this post Link to post Share on other sites
Keyo 47 Posted December 24, 2020 (edited) Seems daft by the manufacturers- a gauge should be a gauge and what it reads should be gospel. What about the VDO gauges I might get a coolant temperature for my Votex instead of oil temp which I have om the MFA anyway, The corrado has a sensor just for the binnacle I believe from memory so might be accurate to a certain degree duh duh bad joke sorry. Edited December 24, 2020 by Keyo Quote Share this post Link to post Share on other sites
Keyo 47 Posted December 24, 2020 Just noticed this- think its the plug that has the securing clips that always brakes which is plugged into the rad fan. https://www.ebay.co.uk/itm/1H0973204-1H0-973-204-4-WAY-CONNECTOR-KIT-Inc-Terminals-and-Seals-4-AC278/233324341480 Quote Share this post Link to post Share on other sites
