Jon_vr6 1 Posted December 8, 2006 Edit read last post!! ** **Page 4 for pics of the offending part!** Just another quick question is it normal for there to be steam coming from the front grille after a drive out with the car reaching between 90-100 oC theres also a bit of condensation on the front grille?? The engine was hot and i imagine the fans had been on and they definately work!! Quote Share this post Link to post Share on other sites
Jon_vr6 1 Posted December 8, 2006 it was when i came to a stop at my house i noticed it! Quote Share this post Link to post Share on other sites
Tekara 0 Posted December 8, 2006 You shouldnt have any steam coming from the engine unless there's water to evaporate and its got to come from somewhere. Either its been blasting down with rain or you've got a leak. Check the water level in the res, check the rad for leaks through the grill, might be worth removing to inspect have the engine on for this. Quote Share this post Link to post Share on other sites
Henny 0 Posted December 8, 2006 how wet was the road you drove down? could just be road water evaporating off the radiator... Check the coolant level in your expansion tank to check it's not dropped any and keep an eye on it until you're happy it's not dropping any and that it was just rain water steaming off the hot radiator... ;) Quote Share this post Link to post Share on other sites
Jim 2 Posted December 8, 2006 I had this once on my old valver after i'd been driving and it started to lash it down.. I guessed it was rain sizzling on the radiator! If it does it often (and not when it's been raining!) then there is something wrong! Quote Share this post Link to post Share on other sites
Jon_vr6 1 Posted December 8, 2006 could water have got trapped on the sill between the radiator and the front grille and heated up causing the steam?? I had it started the other day to double check that the fans come at the right time and they did and there was no steam then!! So most probably water gettin trapped will double check the resevior to see!! Quote Share this post Link to post Share on other sites
Jon_vr6 1 Posted December 8, 2006 it rained the other day and i put the car straight in the garage and didnt use it yesterday so most probably water build up! And it is cold so more noticable! If it was the radiator leaking there would be water under the car wouldnt there?? And there isnt any! Quote Share this post Link to post Share on other sites
Jon_vr6 1 Posted December 8, 2006 Rite seems as tho ive got a leak from a pipe or the radiator has had it how do i know which one it is??? Quote Share this post Link to post Share on other sites
tonedef 9 Posted December 8, 2006 Check all the plastic mouldings around the thermostat housing, temp sensors etc. I had a whole load of fun with those last year and ended up replacing the lot. I'd done the rad the year before too! Just get your engine hot, ticking over with the thermostat open and look around everywhere with a torch, chances are you'll see it squirting out somewhere. What's the system pressure like, can you squeeze the hoses OK? If not, and you haven't already, swap to a blue expansion tank cap as you could be running too much pressure. Quote Share this post Link to post Share on other sites
adevr6 0 Posted December 8, 2006 that little 's' bend pipe is good for perishing.the one off the front crack pipe.'o' rings inside the crackpipe/thermo housing are good for splitting.and jubillee clips dont seal alway round under pressure on a modded vr-trust me i know.spring loaded does the job. Quote Share this post Link to post Share on other sites
kongo127 0 Posted December 9, 2006 I hate water issues on cars!!! :bad-words: They´re such a pain to fix! :snipersmile: Quote Share this post Link to post Share on other sites
GIXXERUK 0 Posted December 9, 2006 the one off the front crack pipe.'o' rings inside the crackpipe dood was the crack pipe an optional extra ? i didnt get one on mine - denied :afro: Quote Share this post Link to post Share on other sites
adevr6 0 Posted December 9, 2006 BIG DAVE sells em,along with potnooddle! 8) . Quote Share this post Link to post Share on other sites
tonedef 9 Posted December 9, 2006 BIG DAVE sells em,along with potnooddle! 8) . Can I get a bacon and egg sandwich instead? Quote Share this post Link to post Share on other sites
Jon_vr6 1 Posted December 9, 2006 rite definately a radiator prob gettin my mate who works for audi to price one up are they aukward to fit?? Quote Share this post Link to post Share on other sites
tonedef 9 Posted December 9, 2006 Did mine without taking the front panel out, took me 6 hours, a real nightmare! Then I saw how the front panel came out, reckon you'd do it easilly in half that time. Grill off, headlights out, bumper off, front panel out and it's there in front of you. Quote Share this post Link to post Share on other sites
Goldie 2 Posted December 9, 2006 Cant imagine itll be too difficult but as tonedef has said itll take some time. Might be a good idea to get some help from someone, an extra pair of hands would be ideal. Quote Share this post Link to post Share on other sites
Jon_vr6 1 Posted December 9, 2006 will do ill have my mechanic mate doin most of it as a foreigner rather give him the money for doing a job then it goin into the company he works for if im honest! Fully qualified mechanic passed recently and is now managing the repair shop at audi stockport and is still getting a trainees salery what a load of crap! Quote Share this post Link to post Share on other sites
Goldie 2 Posted December 9, 2006 Sounds like a handy man to have on your side. Sure itll be tickety boo... How much the rad set you back?? Quote Share this post Link to post Share on other sites
Jon_vr6 1 Posted December 9, 2006 he said tops 100 quid!! we'll see!! Quote Share this post Link to post Share on other sites
Goldie 2 Posted December 9, 2006 That seems a good price, id have imagined a VR radiator to be dearer than that..... Quote Share this post Link to post Share on other sites
Jon_vr6 1 Posted December 9, 2006 he gets it trade tho so that might be why!! How much are they usually for a VR??? Quote Share this post Link to post Share on other sites
Goldie 2 Posted December 9, 2006 Not sure mate, therell be someone around here that knows. Quote Share this post Link to post Share on other sites
NickRStorm 0 Posted December 9, 2006 I paid £146 six months ago & they had to get it from Germany! Quote Share this post Link to post Share on other sites
Tekara 0 Posted December 10, 2006 I paid £112+vat (parts club price) for a VAG radiator about a month ago. Not a fun job to do, i pulled it all out through the engine bay took many attempts swearing it wasn't possible, then all of a sudden it just popped out as though it was made to do so. Quote Share this post Link to post Share on other sites
