Rawhide 0 Posted October 24, 2003 My corrado VR6 is totally standard and I am planning on keeping it that way. The front brake disks are pretty knackered and are starting to suffer from fade. Can you guys recommend replacement disk that will go straight in. I don't want race systems or anything radical, and most of my work is town stuff so no disks that need to get heat into them. I'm on a bit of a budget (all my money goes on my bike :roll:) but I like a good set of brakes and don't mind spending a bit if its really worth it! Thanks! :wink: Quote Share this post Link to post Share on other sites
Henny 0 Posted October 24, 2003 one word: VAG I put original VAG disks on my G60 when I bought her and have been more than happy with the results. VAG's got a good price structure in place for these parts and they aren't at normal stealer price levels :shock: Good value and you know that they'll last and do what they're supposed to 'cos that's exactly what they were designed for!... :D Quote Share this post Link to post Share on other sites
steveo29 0 Posted October 25, 2003 ive used ate and zimermann std replacments...no probs ,good quality...and cheep from gsf /ecp Quote Share this post Link to post Share on other sites
Jim 2 Posted October 25, 2003 I used to have Pagid 8 Groove Discs on my 16v and they were rather impressive. Teamed with Pagid pads, braking was never really a problem :) Quote Share this post Link to post Share on other sites
vr6storm 0 Posted October 25, 2003 AtE power-grooves are cheaper and are a O/E standard so there is no insurance penalty(most companies will load your premium if you upgrade your discs btw) Quote Share this post Link to post Share on other sites
Chris VR6nos 0 Posted October 25, 2003 Mine are 288mm Black Diamond grooved & cross-drilled discs with Pagid pads. Takes a few times to warm them up but you can't get break fade easily at all so they make a great setup for not that much! Chris Quote Share this post Link to post Share on other sites
stevemac 0 Posted October 25, 2003 I use Brembo drilled front disks. Same in every way to the VAG ones - only difference is thay they are drilled to help heat dissipation. Readily available from German, Swedish & French (GSF) Quote Share this post Link to post Share on other sites
CazzaVR 0 Posted October 26, 2003 Just fitted Pagid 8 Groove front discs and Pagid Fast Road pads. Still bedding in, but very impressed so far :D Quote Share this post Link to post Share on other sites
Supercharged 2 Posted October 26, 2003 Yes, VAG disks are very good for the price or if you want to uprate them get the Pagid grooved. Pagid fast road Pads will be fine with either choice Quote Share this post Link to post Share on other sites
Banana Man 0 Posted October 26, 2003 I run the ATE Power discs from ECP and at the price they were I am very happy with them. Quote Share this post Link to post Share on other sites
Rawhide 0 Posted October 26, 2003 Wow - what a selection.. now I'm even more confused :? :lol: VAG sounds good to me. I want the car to remain stock. Any idea on prices? Do they use standard VAG? pads? I guess German and Swedish are the place right!? Sorry for the dumbass questions.. I'm stll learning.. Quote Share this post Link to post Share on other sites
stevemac 0 Posted October 26, 2003 Unless you're going to be changing your calipers then the VAG pads will be okay. GSF may offer you 3 choices - Standard, Brembo drilled or I think they do some drilled & grooved ones but I can't remember who makes them. Standard pads will be okay with any of these disks. Just be aware that drilled & grooved discs will shorten the life of your brakepads slightly. For the type of driving that you describe, I don't think Pagid fast road pads would be the best choice. Quote Share this post Link to post Share on other sites
×Ç|®8tËÐ 0 Posted October 27, 2003 Brembo X-drilled and Slotted W/Wilwood Pads! Quote Share this post Link to post Share on other sites
Chris VR6nos 0 Posted October 28, 2003 Let's see a pic of the Wilwood & drilled brembo's then! Chris Quote Share this post Link to post Share on other sites
stevemac 0 Posted October 28, 2003 Let's see a pic of the Wilwood & drilled brembo's then! Chris Maybe ×Ç|®8tËÐ will be able to sort you out with a picture. (My camera's at work). The drilled Brembo disks are almost identical to the original VAG ones - only with holes in !! Available from GSF Quote Share this post Link to post Share on other sites
Sanj 0 Posted October 28, 2003 Just replaced mine a month ago got Zimmerman crossed drilled and padgid fast road pads, all from german and swedish, stops like a dream!! :D Quote Share this post Link to post Share on other sites
JT 0 Posted October 29, 2003 a mate of mine just replaced his vag discs and pads with brembo road racing pads and discs and they do take slightly longer to warm up but once they are they are far more impressive than the standard ones they avoid fade for alot longer than my standard discs and pads...(1.8 16v) both of em btw :D Quote Share this post Link to post Share on other sites
G60Jet 1 Posted October 29, 2003 Mine are 288mm Black Diamond grooved & cross-drilled discs with Pagid pads. Takes a few times to warm them up but you can't get break fade easily at all so they make a great setup for not that much! Chris Anyone Know a good place to buy these in the midlands area as im back in the UK i intend to buy new discs and pads. Quote Share this post Link to post Share on other sites
GRINGOG60 0 Posted October 29, 2003 I use Black Diamond grooved an drilled discs with pagid pads and i think there the dogs danglies! Would reccomed them to anyone- far superior over the standardd set up. Have also used Zimmerman discs and green stuff pads which are also preety good to...... Quote Share this post Link to post Share on other sites
biggrim 0 Posted October 29, 2003 Running Zimmerman X-drilled discs and Pagid fast road pads just now. A bit dusty but other than that they are great. Gonna get Rotor discs all round next time though (once I get some alloys so you can see thm). Quote Share this post Link to post Share on other sites
Chris VR6nos 0 Posted October 30, 2003 Biggrim with little steelies, LOL ;-) No offence! Chris Quote Share this post Link to post Share on other sites
biggrim 0 Posted October 30, 2003 None taken mate. Ya cheeky ba... only jokin'!!! Poor student and all that. Have to save up for my Azev A's. Quote Share this post Link to post Share on other sites
dubster82 0 Posted October 30, 2003 Chris VR6nos, Thats cause its Big - Grim..... not Big - Rim... :lol: Still amusing though. but he has a Cream leather interior, so he gets away with it... :wink: :lol: Quote Share this post Link to post Share on other sites
biggrim 0 Posted October 31, 2003 Cream Storm interior at that Gonna get Big Rim's (liked that wee pun Brian) in the summer so don't panic. The steelies give it that "individual look too :wink: Quote Share this post Link to post Share on other sites
dubster82 0 Posted November 1, 2003 15" steelies are ace :D Quote Share this post Link to post Share on other sites
